Old 05-23-2014, 12:33 PM   #1
JMoore412
Drives: 2014 Scion FRS, 2014 GTI, 2013 Golf
Swift Spec R with Bilstein B8 shocks?
Does anyone know if the Swift Spec R springs will work well the the Bilstein B8 shocks? I was told by somebody that the Spec R springs would wear out the B8's. I don't trust the person telling me that so figured I would ask on here.
JMoore412 is offline   Reply With Quote
Old 05-23-2014, 12:48 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The B8's are designed by Blisten to be used with lowering springs. The description is on their website.
http://www.bilsteinus.com/products/p...passenger-car/
Old 05-23-2014, 01:00 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Should work no problem. I run RCE Yellows on B8s.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-23-2014, 01:52 PM   #4
CSG David
CSG David's Avatar
If Spec-R wears out the B8s, then every spring paired with B8s will wear out the B8s.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Jmonty (05-24-2014), RehabJeff86 (05-23-2014)
CounterSpace Garage || JRZ|KW|Tein|Bilstein|Ohlins|MCS|SPL|Swift|Raceseng || CounterSpace Garage Brakes, Suspension, Chassis 45 11-01-2016 11:44 AM
**NEW**Bilstein B8 HD Struts and Shocks Released FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 09-12-2016 01:54 PM
FS: swift springs (brz spec) with koni yellow sport shocks Mersd Brakes, Suspension, Chassis 8 04-20-2014 06:12 PM
Bilstein shocks & struts Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-31-2013 02:56 AM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
