Old 05-21-2014, 12:30 PM   #85
350matt
Drives: toyota mr2/ Toyota GT86
To be honest chaps I doubt that 250Bhp is possible without increasing the revs and from what I've seen the valvetrain will spit its dummy out along with its followers if we stray much over 7700rpm
heavier springs obviously help but I think its going to need some different design of followers in there to cope with more revs
350matt is offline   Reply With Quote
Old 05-21-2014, 12:36 PM   #86
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Do you have any proof of this? There is one supercharged car running around on the stock block revving out to 8000. I would think with a built NA block, new cams, and new valve springs, we should be able to safely get the revs OVER 9,000!!!!
Luckrider is offline   Reply With Quote
Old 05-21-2014, 01:16 PM   #87
BRZealot
Drives: 2013 SWP BRZ
Originally Posted by mid_life_crisis View Post
I live north of Raleigh. According to the map I checked, I'd need to go to Durham or the south side of Raleigh. Both are considerably out of my way.
I live about 5 minutes from an E85 pump that's on glenwood where it hits duraleigh. It's a brand new station and I think it's a BP.
BRZealot is offline   Reply With Quote
Old 05-21-2014, 02:27 PM   #88
mid_life_crisis
Drives: FR-S 10 #103 AT
That is too far out of my way. I work by Triangle Town Center and live north. If there were one in between or near either, I would go for it, but just not close enough for me.
I keep seeing references that it took a couple of tankfulls for the car to show a real improvement. Is this what you experienced?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 05-21-2014, 04:27 PM   #89
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by tahdizzle View Post
Yup. haven't heard a thing about it either.
The innovate thread hasn't been much help trying to gleen more information about it.
Delicious tuning have one, Also one on the Sprintex R&D car here in Perth Australia.
pm me if you want any information, i bug them on a regular basis.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 05-21-2014, 04:43 PM   #90
youcantseeme24
youcantseeme24's Avatar
Drives: 2013 subaru brz
But how many miles will it last?
youcantseeme24 is offline   Reply With Quote
Old 05-21-2014, 04:48 PM   #91
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
What does money have to do with any of this? Just because you can't afford it doesn't mean someone else can. Arguing against Cosworth because of money is like arguing against HRE or a BRZ because their a options that can do more with less money.
Cosworth sometimes takes a long time to release parts, because sometime engineering a part to the degree you want takes a bit of time. It's just how that works.
Here's Eri Hsu, who I respect more than most FFF, talking about the Cosworth VR38DETT piston:
http://www.motoiq.com/MagazineArticl...omponents.aspx
Here's some case studies by the firm producing these parts:
http://cosworth.com/about/case-studies/
Now please show me the history of whoever the hell else you are arguing is better because they're cheaper.
P86RAVES is offline   Reply With Quote
The Following 2 Users Say Thank You to P86RAVES For This Useful Post:
Calum (05-21-2014), s2d4 (05-23-2014)
Old 05-21-2014, 06:16 PM   #92
350matt
exactly
the very occasional run on the street to high revs doesn't mean the engine is going to last 20K miles with 8000rpm +
having seen the follower arrangement there's no positive location for the follower
1 end sits on a cup the other end on the valve stem with the cam pushes against the roller it all relies on the forces balancing and good valve control
put the revs up past so the spring cover is marginal ( ie past 7650rpm) and the valve control will drop away and vibration will pass up from the valve seat impact and literately shake the follower off its post
now heavier springs will help but it really needs some positive location / hinge for the follower so it can't wiggle about and jump off its post
Old 05-21-2014, 11:09 PM   #93
xwd
I know one car locally here by a well known tuner who floated a valve at high RPM with a turbo setup. Less than 8000 RPM but he's making 500+WHP. He just replaced the springs with a set of Kelford ones.
Old 05-21-2014, 11:14 PM   #94
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Yup and moved the f*ck on to make more power. No care at all.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-22-2014, 07:08 AM   #95
Luckrider
Luckrider's Avatar
My post was half a joke and half a wish with no proper prospect of it coming true. Even that supercharger's owner admits that he doesn't run it up past 7k much.
Old 05-23-2014, 02:15 AM   #96
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
A little bird told me that cosworth dealers already have some pricing and they are having some sort of release party on the 31st.
Also no final power numbers are out.
That's all I could get out of my guy, and it may be false info. :P
Just wanted to post and hopes ill be right?
clayrush is offline   Reply With Quote
Old 05-23-2014, 04:16 AM   #97
Levi
Drives: Toyota
I don't think Cosworth will disappoint as does TRD. At Cosworth there is alot of R&D before somethign gets to the market, thus the time to market and the high price, but worth the quality and the benefits.
Levi is offline   Reply With Quote
Old 05-23-2014, 12:31 PM   #98
350matt
yep there's an owners club event / official launch
http://www.gt86ownersclub.co.uk/foru...topic6333.html
Vortech SC + Vishnu OFT300 power package Garrett@Openflash Forced Induction 22 03-15-2016 12:04 PM
DeatschWerks Power Package available at RallySport Direct! RallySport Direct Engine, Exhaust, Bolt-Ons 1 11-27-2013 07:51 PM
MAGNAFLOW CATBACK + AFE POWER/INJEN INTAKE PACKAGE DEAL!!! NJA Engine, Exhaust, Bolt-Ons 5 12-11-2012 09:05 PM
