#1149 | |
Professional Smartass
Drives: White Out FRS
And don't forget to clamp the hoses under the intake manifold unless you want those to blow off. |
#1150 |
I'd say optimal is yes to all, but you could get away with none of them.
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#1151 |
Drives: A bunch of 'em...
What's the ramification of running no on all (but clamp the living crap out of every hose under the hood).
#1152 | |
That Guy
Drives: 2013 asphalt FRS MT
#1153 |
#1154 |
So checkvalves are a must then. That's why I ask people...
Wonder where the fuck I'm going to find those in MX. What about brass ones from a hardware store? Don't those work too? |
#1155 | |
#1156 | |
NASA SpecE30 Racer
![]() You just run a hose up from the barb on the engine block and into the can. Then I used the open spot on the intake manifold to feed my vacuum manifold.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1157 | |
can we start a new thread for catch can and crank ventilation discussion? though worthy, this discussion has hijacked this thread |
#1158 |
I am also not running a vented catch can. Hence my discussion of check valves lol. I just wanted to say hey, if you don't run a catch can, or you run one that isn't vented, get a check valve.
#1159 | |
NASA SpecE30 Racer
http://www.ft86club.com/forums/showthread.php?t=24340
- King Tut
The Following User Says Thank You to King Tut For This Useful Post: | Calum (05-21-2014) |
#1160 | |
That Guy
The stock PCV valve should act as a check valve already, but I haven't confirmed that. You may want to before you bother buying additional parts. Running the PCV system completely untouched will allow the engine to suck in and burn the blowby gasses from the crank case and pull a vacuum on the crank case during . Those gasses will include some atomized oil. The atomized oil can leave deposits and can lower the effective octane of the fuel you're running. Not perfect right. Running a vent to atmosphere catch can eliminates the down side of the PCV system by completely preventing any oil deposits from entering the intake. But it also eliminates the up side of the PCV system. Running a vacuum in the crank case actually has a dramatic effect on sealing the rings, when there is vacuum available. Before you start thinking you're putting a forced induction kit on your car, it'll always be in boost, think about YOUR driving. If you're racing, that would likely be a correct assumption. But if you're building a fast street car, you're still likely going to be driving with the intake manifold under vacuum most of the time. By sealing the rings better you help to prevent blowby. Blowby gasses, if not removed from the crankcase, will contaminate the oil much faster than if they are removed. There's also some efficiency and emissions benefits to maintaining a vacuum in the crankcase, but those are secondary effects to the primary purpose of the PCV system. Running an air oil separator (or sealed catch can) gives the best of both worlds. You eliminate the VAST majority of the harmful gasses from entering the intake, and you maintain a vacuum in the crankcase. The common method of advertising VTA catch cans is the run one on a car and then after a while show how much oil it has caught. But remember, there will be a lot more blowby and thus more oil caught by a catch can, if the crankcase inn't being run in vacuum. Now the question of how many AOS's you need. A PCV system has two hoses, one the runs from the crankcase to the intake manifold after the throttle body. This is the line that draws a vacuum on the crankcase and is the line that is going to see the majority of the harmful gasses. This line also has the PCV valve to prevent the crankcase from getting pressurized and to adjust the amount of air flow to prevent poor engine running during high vacuum such as idling. Running an AOS or catch can in this line is a must if you're going to do anything. The other hose runs from the crankcase to the air intake before the throttle body. Most of the air moving through this hose is going into the crankcase through an orifice. But under full throttle gasses can move in either direction in the line depending upon which side has a more positive pressure. I doubt any FI kit would plumb this to the pressurized side of the compressor, but I can't confirm that. Personally I would put a breather filter on the crankcase end of this line and cap off the intake side. The only reason this line is plumbed to the intake before the throttle body is to ensure the air entering it is filtered. Using the main air filter is cheaper than running a second filter, but does give another opportunity for blowby gasses to enter the intake. The other options are to leave this line as is, which isn't that bad of an idea as it should see very little air flow. Or you can put either kind of catch can in the line. I would argue that running a catch can in this line is a waste of money, but I'll leave that to you. As for an oil cooler, running your oil too cold can be just as bad as too hot. I haven't done sufficient research to know what the best temperature range is. We've all heard arguments for an against oil coolers. I think your best bet will be to log your oil temperatures and then go from there. Unless you're racing, I doubt you're going to run into any catastrophic failure situations before you can determine the correct course of action. |
#1161 | |
That Guy
Clearly I've stated my understanding of the systems operation in my last post/gem style wall of text. If you're willing to explain things I'm happy to learn. |
#1162 |
Drives: 2016 Subaru WRX
I also run a non vented catch can and have one of these nice Boomba Racing check valves.
(This is not an advertisement for Boomba Racing, just what I personally run) http://www.boombaracing.com/check-valves/
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
The Following User Says Thank You to evo4g63 For This Useful Post: | post_break (05-21-2014) |
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
