Old 05-16-2014, 07:53 PM   #1
knipple
Drives: 2013 Ultramarine Scion FR-S
Ground Control Complete coilovers vs RCE Tarmac T2
What are the differences between the Ground Control Complete Coilovers and the RaceComp Engineering (RCE) Tarmac T2 coilovers?
knipple is offline   Reply With Quote
Old 05-16-2014, 10:52 PM   #2
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by knipple View Post
Differences? ..The RCE's are better.
Stock length shock bodied Konis don't sound appealing to me (I want more travel..not lose travel after lowering). Also read Koni have a problem with leaking from multiple users. Lastly, read that GC coilover sleeves don't ride so great. Also, read there is problem with max lowering range. Just read too many problems with Koni and GC to even want to deal with it or try them.
Mechanically...completely diff than each other. T2 are compression and rebound double adjustable, a true coilover, doesn't come with upper mounts, motorsports oriented/focused. GC is single adjustable, stock length stroke/travel/shock body, a koni shock with an integrated GC coilover sleeve (not really a true coilover), comes with upper mounts and strut bar.
fooddude is offline   Reply With Quote
Old 05-17-2014, 12:35 AM   #3
wootwoot
Drives: FRS
Wow.... So much misinformation I am not sure where to start....
GC uses custom valved koni's for each build. They are built by koni to GC's specifications. The fronts offer an additional inch of travel as they are not stock length. The rears are stock length, but additional travel can be gained by purchasing their rear mounts. They can also be purchased without the camber plates and truss bar. The standard package is rebound adjustable only, but you can upgrade to double adjustable if you like. GC makes each set to order according to your specifications. This way you don't get an over the shelf generic unit but rather a system set up from the factory to your needs.
Not saying one is better than the other. Just clearing up some of the information....
The Following User Says Thank You to wootwoot For This Useful Post:
gtslow (04-11-2015)
Old 05-17-2014, 12:57 AM   #4
fooddude
I didnt really, nor meant, to misinform..I just forgot to mention the front design does add travel over stock design; but from the top plates from what I know (I did not know they too used a shorter body damper like other coilovers...I just always thought they gained travel from the top mounts only). Also forgot to mention they are custom valved. Sorry.
What I said about leaking, harsh ride and doesn't have a big/low ride height range (on the sleeve-only reviews; not the entire kit) isn't misinformation..do a search and you will read the same things from other threads.
Me saying that the RCE's are better was just my opinion and me being bias and a bit arrogant, lol.
Old 05-17-2014, 02:19 AM   #5
wootwoot
Drives: FRS
I have never seen a GC strut leak. I have seen off the shelf koni's leak. I have also never seen a GC strut snap. I have seen off the shelf koni's snap.... Again, GC =\= off the shelf koni.
Old 05-20-2014, 07:48 PM   #6
knipple
Does anyone have any information pertaining to this question?
Old 05-20-2014, 08:10 PM   #7
CSG David
CSG David's Avatar
GC = Inserts valved to spring specification with threaded bodies to allow you to adjust height.
RCE = revalved KW V3.
Just different methods of packaging a coilover kit. In pretty much most things in tuning, you get what you pay for.
Old 05-21-2014, 10:03 AM   #8
sprintamx
Is that a comment on GC or Koni?
sprintamx is offline   Reply With Quote
Old 05-21-2014, 10:37 AM   #9
Racecomp Engineering
I don't think I have anything bad to say about GC.
Only thing I'll say is that it looks like you can only get double adjustable fronts in that kit, and the rears will be singles (I could be wrong). That and it doesn't look like they come with helper springs or dustboots.
But I generally like Koni shocks and run them on my own personal car.
- Andy
CSG David (05-21-2014)
Old 05-21-2014, 11:01 AM   #10
Wepeel
Drives: '13 BRZ Ltd
I *think* adjusting the rebound on the rears of the GC Konis requires removing the shock, or at least unbolting it, and twisting it. Someone please correct me if I am wrong.
Wepeel is offline   Reply With Quote
Old 05-21-2014, 11:05 AM   #11
wootwoot
Drives: FRS
No. Adjusts at the top. Remove carpet in trunk and turn from there.
Wepeel (05-21-2014)
Old 05-21-2014, 11:13 AM   #12
sprintamx
Adjustment of the rears requires turning the rod while holding a locking button under a cover plate at the top of the body. That pretty much requires the shock to at least be unbolted at the top, though it will be a two-person job if left mounted to the LCA. Awkward and inconvenient to say the least.
The explanation I have heard for this setup is that the overall length of the insert is shortened to fit the BRZ dimensions and is "too" short to allow for a more standard adjustment fitting at the top of the rod; which the fronts do have. I'm no engineer, so take that for what ever it may be worth. I have the GC Koni package, but don't know if every Koni rear adjustable insert will have the same adjustment mechanism.
The GC front housings (and their camber plates and truss bar) are excellent. Having the top mount adjustment makes dialing-in the fronts easy. The rears are obviously a pain in the a-- since trial and error adjustment is sooooo tedious.
The Following User Says Thank You to sprintamx For This Useful Post:
Wepeel (05-21-2014)
Old 05-21-2014, 11:16 AM   #13
sprintamx
If by that you mean that you can put a wrench / socket on the locking nut on the top of the rod, that doesn't always turn the rod/shaft. At least that has been my experience.
Old 05-21-2014, 11:24 AM   #14
TemeCal
Drives: 86
I adjust the rebound on my rears in seconds (literally). The adjuster is at the top. There is no need to use a wrench, socket, etc... It's just a matter of using the Koni knob provided. Are we talking about the same thing here?
The rears are rebound adjustable only, so I can't imagine we're talking about something different.
TemeCal is offline   Reply With Quote
Ground Control Coilovers for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 46 07-03-2014 01:25 PM
FS: Ground Control complete coilover kit bombardius Brakes, Suspension, Chassis 13 05-22-2014 09:25 PM
Ground Control Complete Coilover Suspension Kit and Adjustable End Links Eric1855 Brakes, Suspension, Chassis 12 05-26-2013 12:02 AM
Ground Control Complete Coilover Kit D1cker Brakes, Suspension, Chassis 2 04-06-2013 10:05 PM
Ground Control Complete Kit Install and Initial Thoughts Eric1855 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 03-21-2013 10:52 AM
