| Northern California NorCal |
Mfg Recall #WQC39
Welp . . .
I know - if I want to play, I have to pay!!! WQC39 is mandatory proof of correction required from the dealership I've been able to totally avoid the dealership so far My car is modified, not as much as some others, but . . . So, I've got until August to come up with a plan Anybody have any ideas?
| The Following User Says Thank You to SLEEPER WRX For This Useful Post: | ZionsWrath (05-20-2014) |
#2 |
Drives: 2013 Scion FRS
What is the mandatory recall?
| The Following User Says Thank You to RC51ed For This Useful Post: | ZionsWrath (05-20-2014) |
#3 | |
Proud of BOXER
Drives: Subaru Boxer
| The Following User Says Thank You to Clipdat For This Useful Post: | ZionsWrath (05-20-2014) |
#4 |
Must go to dealership
Must have ECU flashed for whatever their reason is I read it's coolant temp related - Capitol Subaru says it's emissions related You get a proof of correction certificate that then allows DMV registration to happen |
#5 |
Drives: 2013 WhiteOut FR-S
Is this only for BRZ?? I hvnt heard anythingn like this from Toyota??
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
| The Following User Says Thank You to RehabJeff86 For This Useful Post: | ZionsWrath (05-20-2014) |
#6 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Scions is just a TSB, not a recall. Both are simply ecu flashes I believe.
| The Following User Says Thank You to finch1750 For This Useful Post: | ZionsWrath (05-20-2014) |
#7 | |
#8 |
So, here's what I get to do;
- reflash ECU back to stock - take car to dealership and have them do their WQC39 thing - reflash ECU back to stage 2 I guess not so bad - first world problems |
| The Following 2 Users Say Thank You to SLEEPER WRX For This Useful Post: | RehabJeff86 (05-20-2014), ZionsWrath (05-20-2014) |
#9 | |
Proud of BOXER
You forgot a fourth item: Do not physically let your car out of your sight when you take it in - insist that you get to watch the service from start to finish.
I can only imagine the field day the techs will have with your car when you bring it in. They will probably be fighting and arguing who gets to "road test" it after the ECU update - best to shoot that down before it starts. ![]()
#10 |
No idea. They did mine when I took it to get a tail light replaced so I couldnt tell you if it holds up reg.
#11 | |
Drives: Grocery cart
That's only if it's an emission failure tsb, and based on what I found out it is, there is a correction notice you should receive from the dealer upon completion.
SOLD: 2014 BRZ Limited WRB 6 Speed.
| The Following User Says Thank You to HapaHaole For This Useful Post: | ZionsWrath (05-20-2014) |
#12 |
Thanks
I guess I coincidentally didn't get hassled because I avoid dealership.
But I really needed the GPS fix and tail lights replaced so they updated it when I took it for those things. If you can't go back to stock fuk it just take the car in. If you have a tune bring your tune device when you pick it up and reflash before you drive off.
#13 |
Here is a copy from Subaru,
APPLICABILITY: SUBJECT: IMPORTANT - All Service Personnel Should Read and Initial in the boxes provided, right.  SERVICE PROGRAM BULLETIN 2011-12MY All Models 2013MY BRZ Engine Control Module (ECM) Reprogramming NUMBER: WQC-39 DATE: October 2012 REVISED: 11/30/2012 This Campaign only applies to vehicles with motor vehicle registration in the States of California, Connecticut, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont and Washington. INTRODUCTION Subaru of America, Inc. has determined that vehicles affected by this Service Program require ECM reprogramming. A modification to the Engine Control Module software has been developed to correct a deficiency in the OBDII system thermostat monitoring logic. This software change will not adversely affect fuel economy or performance. AFFECTED VEHICLES • 2011-2012MYAllModels • 2013MYBRZ Affected vehicles are identified in the VIN range chart below. NOTE: Not all vehicles in the VIN ranges are affected. Prior to performing repairs, confirm coverage by using the Vehicle Coverage Inquiry function at Subarunet.com.  BRZ VIN Range : D*600007 ~ D*603007
| The Following 2 Users Say Thank You to HapaHaole For This Useful Post: | RehabJeff86 (05-20-2014), ZionsWrath (05-20-2014) |
#14 |
Thanks
That says all 2011 and 2012 subarus and first 3000 vin BRZs?
Damn if thats true lol, what exactly is wrong with the "thermostat monitoring logic"?
| TSB / Recall | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 390 | 09-11-2023 12:24 PM |
| Recall # WQC39 - ECM Reprogramming for Coolant Thermostat | WRXcellent | Issues | Warranty | Recalls / TSB | 190 | 03-10-2013 03:18 PM |
| Recall I think so!!!! | RWD-boxer | Issues | Warranty | Recalls / TSB | 16 | 10-07-2012 10:39 AM |
| FRS recall? | totally | Issues | Warranty | Recalls / TSB | 8 | 08-30-2012 12:01 AM |
| Recall! already | earthsscum | BRZ First-Gen (2012+) — General Topics | 1 | 06-07-2012 07:00 PM |
