Old 05-16-2014, 09:45 AM   #71
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Luckrider View Post
On top of that, many people don't have $20k to lay down to buy a brand new car and throw FI mods at it right away. If you can afford that, you can afford the $75k corvette.
Lots of people don't need another belly button though
Guesses? I'm saying this PD blower setup alone is 9-10k as a guess.
Old 05-16-2014, 11:06 PM   #72
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Originally Posted by OICU812 View Post
How many are prepared to do a full motor build to handle that though? What would be nice is a SC in between their existing one and the 335. That and hopefully one that runs MUCH cooler.
There is such a blower. It's called the Eaton TVS900. Same displacement as the Sprintex, but it revs 26.7% higher and thus flows more air than the Sprintex 210. It's also just as efficient, but with larger efficiency islands so it will ultimately run a little cooler. Judging by Cosworth's advertised horsepower numbers, I'd say that is the blower they are going to use since the calculations I did for the TVS900 were spot on with those numbers. For me, it's bittersweet, because that's exactly what I wanted to do: same mounting location and all. I just haven't had the funds to do it.
What would be interesting is if they use the standard Eaton case. If so, there would be some additional room for improvement with a better case design to get better VE across the board along with higher adiabatic efficiency. Even with the standard Eaton case, it should beat the snot out of the Sprintex blower up top while matching it nicely in the low end and midrange torque.
Also, from everything I've seen, the Sprintex supercharger kit has what looks to be an extremely restrictive intercooler setup. A more conventional heat exchanger would have less pressure drop across the intercooler core without much of a sacrifice in heat exchanger effectiveness. In fact, for the same pressure drop, a conventional exchanger design would be more effective than the Laminova setup Sprintex is using.
I have a feeling the Cosworth setup will perform well...pricing on the other hand will just have to be a "wait and see".
Sithspawn is offline   Reply With Quote
Old 05-16-2014, 11:50 PM   #73
OICU812
Just a dude
OICU812's Avatar
Good info and after looking into this abit more I don't think you're far off at all on your assumption. Wait and see yes we will indeed.
Old 05-17-2014, 03:22 PM   #74
350matt
Drives: toyota mr2/ Toyota GT86
whats wrong with the standard Eaton case?
You'd think that Eaton with all their resource would have this pretty well developed?
350matt is offline   Reply With Quote
Old 05-18-2014, 05:58 PM   #75
Sithspawn
From a strictly manufacturing perspective, there is nothing wrong with the case. From a performance perspective, however, there is much more that can be done to increase the VE and adiabatic efficiency. Eaton, like every company on the planet is in the business to make money and the law of diminishing returns makes it such that further increases in performance result in substantially higher costs to manufacture. The bottom line is that if you want more performance than the standard Eaton case provides, you gotta pay to play.
Old 05-20-2014, 07:55 AM   #76
350matt
What sort of mods then? would they need a new case or could they be done with inserts and the like?
I'm presuming your talking about a less sudden expansion of area out of the blower exit?
Old 05-20-2014, 03:44 PM   #77
peebking
Drives: BRZ limited
If they come out a NA 250WHP package, it will be more interesting for my car
peebking is offline   Reply With Quote
Old 05-20-2014, 05:24 PM   #78
OICU812
Just a dude
OICU812's Avatar
Well it's a nice dream, and if remotely close I'll bet ya that would be double the cost of what a Turbo that would give you 350 would cost.
Old 05-20-2014, 05:37 PM   #79
peebking
Drives: BRZ limited
I know fi is easy to get horses, but I am not a fan of fi, so I rather do na mod
Old 05-20-2014, 05:41 PM   #80
OICU812
Just a dude
OICU812's Avatar
Cool well as long as your wallet is "Cosworth" fat you'll be golden.
Old 05-20-2014, 08:50 PM   #81
Ruckus
Ruckus's Avatar
Drives: Firestorm FR-S
Nameless and cosworth ftw
Ruckus is offline   Reply With Quote
Old 05-20-2014, 09:33 PM   #82
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
i'd luv to see them make a intake manifold for our cars or even only possible....individual throttle bodies on a flat 4 motor I can only dream.....
Panda Mao is offline   Reply With Quote
Old 05-21-2014, 03:13 AM   #83
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
This is what goes on inside my head every single day as I decide what to do with my BRZ.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 05-21-2014, 10:40 AM   #84
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I'd love to get 250 NA.
Vortech SC + Vishnu OFT300 power package Garrett@Openflash Forced Induction 22 03-15-2016 12:04 PM
DeatschWerks Power Package available at RallySport Direct! RallySport Direct Engine, Exhaust, Bolt-Ons 1 11-27-2013 07:51 PM
MAGNAFLOW CATBACK + AFE POWER/INJEN INTAKE PACKAGE DEAL!!! NJA Engine, Exhaust, Bolt-Ons 5 12-11-2012 09:05 PM
