Old 05-20-2014, 01:37 PM   #15
CSG David
CSG David's Avatar
Originally Posted by Scooby South View Post
I am running a Guard Transmission Diff in my car. Lockup and Decel is way more adjustable than a Giken. Its a bit more money but the benefit of getting on the gas earlier and staying on it longer for a couple of 10th's is worth it.
http://www.guardtransmission.com
Bill
Guard LSD. Epic jizz.
The Following 3 Users Say Thank You to CSG David For This Useful Post:
dp1 (05-20-2014), drewbot (08-09-2015), Scooby South (05-20-2014)
Old 05-20-2014, 01:38 PM   #16
simpleisbest
Senior Citizen
Drives: Scion FR-S
Bill
How is it more adjustable? Tech details, please?
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
dp1 (05-20-2014)
Old 05-20-2014, 01:50 PM   #17
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Lockup and Decel are independently adjustable.... its based off wheel speed of the inner and outer during turns.
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
dp1 (05-20-2014)
Old 05-20-2014, 01:57 PM   #18
simpleisbest
Senior Citizen
Drives: Scion FR-S
Bill
Interesting. Any pictures of their internals, on how they do that?
The last GT unit I had my hands on looked no different than your average clutch type diff....
dp1 (05-20-2014)
Old 05-20-2014, 02:22 PM   #19
wparsons
wparsons's Avatar
Originally Posted by dp1 View Post
Also, the page with "manual transmission only":
http://www.frsmod.com/products/os-gi...al-for-frs-brz
Link isn't loading for me.
If the LSD comes with the ring gear on it, then it is transmission specific. If you're using the stock ring/pinion it doesn't matter.
You *could* run the manual final drive with an automatic too, but then you would have to pull the pinion from diff pumpkin.
flickr
dp1 (05-20-2014)
Old 05-20-2014, 03:31 PM   #20
dp1
driving smoother faster
Drives: Sold
Ok, just talked to @CSG David and I'll get their Cusco setup configured the way @CSG Mike likes it
Now the big question that will be addressed tomorrow: will Scion want to replace the diff and in the process open up and install Cusco bits, or will they just install the new diff as is and I'll get someone else to install Cusco...crossing fingers...
Much appreciate all responses
dp1 is offline   Reply With Quote
Old 05-20-2014, 03:32 PM   #21
Scooby South
Conedancer
Talk to Matt.. don't have any internal pics.. But its based off Ratio's.
Bill
Old 05-20-2014, 04:48 PM   #22
CSG Mike
CSG Mike's Avatar
Both Cusco and OSG headquarters are within 30 minutes of CSG We've been using the Cusco differential, but you can't go wrong with either unit.
By request:
OSG
Cusco
Shankenstein (05-20-2014)
Old 05-20-2014, 04:58 PM   #23
dp1
Drives: Sold
Cusco it is, with middle-of-the-road settings and whipped cream on top, thank you
Old 05-20-2014, 09:29 PM   #24
wparsons
wparsons's Avatar
Are they installing it under warranty, or are you paying them to install it?
If it's under warranty, there's no way they'll replace OEM with aftermarket IMO. If you're paying for the replacement, they'll install whatever you want.
flickr
Old 05-20-2014, 09:54 PM   #25
dp1
Drives: Sold
Yeah, I talked to CSG today and we agree that it's best to have diff replaced under warranty and then I'll have an experienced diff shop install Cusco LSD into the pumpkin afterwards.
Old 05-21-2014, 05:00 PM   #26
dp1
Drives: Sold
No warranty replacement of the diff, Scion refused due to modifications. No big deal as Cusco is going in. Apparently some clip from the 600HP DSS axle (http://www.driveshaftshop.com/featur...-in-rear-axles) damaged some seal but it's not a differential seal but the axle seal...unclear, will get more info soon when I pick up the car. Also, this is causing the rear right axle to separate...
Old 05-21-2014, 05:31 PM   #27
CSG Mike
CSG Mike's Avatar
Damn.
Well, at least we know you have a solid upgrade coming.
Old 05-21-2014, 05:42 PM   #28
dp1
Drives: Sold
Aftermarket differential (LSD) options for automatic transmission (AT)?
Damn.
Yeah, no big deal, comes with the territory. I am a little bit concerned about DSS axles, as the first set I got was leaking axle grease from both (probably just the metal ring wasn't tightened enough, it can happen)...but now this axle pin damaging axle seal and the axle separating...let's see what happens...I don't really want to go back to stock axles as that is a weak point with more power and tracking...hope this gets sorted out with DSS.
I don't blame scion for their course of action as it appears that failure may have been caused by an aftermarket part.
I know that @PrimeMotoring will take care of me, just scheduled seal replacement and putting in original axles on Tuesday.
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
