Old 05-19-2014, 10:32 AM   #1401
Racecomp Engineering
Originally Posted by Teo View Post
Thanks Andy,
What do you think about 0.00 toe also on the rear ?
I like a little toe in, but not a lot.
- Andy
Old 05-19-2014, 10:38 AM   #1402
Teo
Teo's Avatar
- Andy
How much you suggest?
I forgot to say that I have OEM sway bars, but front and rear cusco tower bar (if this may affect in someway)
Teo is offline   Reply With Quote
Old 05-19-2014, 10:49 AM   #1403
See if you like what you have now.
- Andy
Old 05-19-2014, 10:58 AM   #1404
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
So I autocrossed yesterday with my new suspension, Bilstein B8 shocks with RCE Tarmac springs. Front camber is 0 and the rear is -1.8-2.0 with stock wheels and rubber.
I noticed a significant amount of understeer; I believe a decent amount of that is due to no camber in the front. This leads me to two questions for you guys.
1) I daily drive this car in addition to autocross; what is a good compromise in terms of front camber to be decent at both driving aspects?
2) How much will adding negative camber to the front reduce oversteer / increase oversteer?
Thanks in advance!
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-19-2014, 11:03 AM   #1405
0 camber is no bueno.
1. You could easily go -1.5 to -2.0 up front without worrying about tire wear depending on your commute, especially with very little or no toe. Think about how much your rear has right now/from the factory, and the front needs it even more. I'd expect worse and more uneven wear with 0 camber to be honest.
2. The change will be pretty huge. You need that camber bad!
- Andy
Turkish (05-19-2014)
Old 05-19-2014, 11:34 AM   #1406
was385
Drives: MT WRB BRZ Limited, 2007 911s
- Andy
Just to add on to this, I've been running 245 ZIIs this season on maxed out OEM camber bolts (about -1.3 I believe) and also daily drive the tires on a pretty substantial commute. It only took a couple of events before I was seeing significant wear on the outer edge of the front tires. I just ordered HVT camber plates because it just wears way too fast without enough camber up front.
was385 is offline   Reply With Quote
The Following 2 Users Say Thank You to was385 For This Useful Post:
Racecomp Engineering (05-19-2014), Turkish (05-19-2014)
Old 05-19-2014, 11:47 AM   #1407
andrew20195
Drives: 2013 Subaru BRZ
- Andy
I'd like to add that in street driving, running your tires with low air pressure will have a huge effect on treadwear, especially if you do a lot of highway driving. Check your air pressure often!
andrew20195 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew20195 For This Useful Post:
Old 05-19-2014, 12:42 PM   #1408
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
newbie question @Racecomp Engineering @CSG Mike
after I installed my coilovers, I took my car to the alignment shop after I drop the car about 1.5" all around the guy told me I got -2.5 and -2.8 in the rear and around -1.5 and -1.2 at front wheels so I asked him to give me more camber by adjusting the camber plates and I was able to see -3.0 on front L/R afterwards, after I attended the track event I think my ride height dropped a little bit maybe it settled a bit or the camber plates ( since it changed the angle a bit) or the combination of both.. so my question is
Can I raise the car a little bit and if I do, Do I have to take it for another alignment? I assume I might lose some camber in the front but I am looking for 1.5" drop all around and it's almost 2" now
Thanks in advance
glamcem is offline   Reply With Quote
Old 05-19-2014, 01:43 PM   #1409
Thanks in advance
Changing camber up front can affect ride height, but it sounds like it was a combination of that and maybe a little spring settling.
As for if you need another alignment after raising it back up a half inch...it depends how anal you are. I'd do it, and I'd get some rear LCAs and sort out your rear camber while you're in there and then I'd be happy.
- Andy
glamcem (05-19-2014)
Old 05-19-2014, 04:45 PM   #1410
CSG Mike
CSG Mike's Avatar
Thanks in advance
If you purely lost height, then restoring it ot the height at the time of your alignment will restore the alignment; your alignment changes on a curve based on height, so you're just moving along that curve. Changing cam bolts, arms, camber plate settings, etc will alter that curve.
glamcem (05-19-2014), SirBrass (05-19-2014)
Old 05-19-2014, 04:55 PM   #1411
Ah yeah that. Good point.
- Andy
Old 05-19-2014, 05:37 PM   #1412
glamcem
glamcem's Avatar
Great, I will raise it about .5" since it seems like it dropped about .5" or so so hopefully it won't hurt the cambers or toes
thanks
Old 05-19-2014, 06:33 PM   #1413
CSG Mike
CSG Mike's Avatar
thanks
Just use a tape measure to verify toe, and you'll be good to go.
glamcem (05-21-2014)
Old 05-20-2014, 05:50 AM   #1414
BrandonB
Drives: 2014 Whiteout Monogram Frs
would you guys recommend rce yellow/ swift springs on bilstein b8? or with rce tarmac/swift spec r? why?
and what is a basic coilover that can be fitted with swift springs from the factory?
BrandonB is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
