Old 05-19-2014, 04:58 PM   #1
vestal52
vestal52's Avatar
Drives: Whiteout FRS
no cel after catless header install
ok I just recently installed an OFH about 2 weeks ago, drive it every day with prolly a little over 100 miles yet no cel? I haven't tuned it either, will be getting on oft soon anyways.
just wondering why my car hasn't put out the CEL, thought it was going to happen since everyone seems to get it right after header install
vestal52 is offline   Reply With Quote
Old 05-19-2014, 05:03 PM   #2
ramiram1984
Drives: 2016 STi DGM
every car/eng is diff...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-19-2014, 05:12 PM   #3
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Maybe you are just lucky? In fact, CEL usually pops-up after some prolonged drive with stable speed and RPMs - like 20-30 km motorway ride. If you do just town rides with stop-and-go traffic it might not appear at all. But, as rightly said above, it's case-by-case and depends whether you are lucky or not
Efferalgan is offline   Reply With Quote
Old 05-19-2014, 05:30 PM   #4
vestal52
vestal52's Avatar
ok thanks, trying to figure out if I have a leak as well.
idle it's quiet, but under acceleration it sounds like its breathing/ blowing air.
not sure if that's normal or what not
Old 05-19-2014, 05:38 PM   #5
ramiram1984
Get under your car and feel for exhaust leak...better if you had access to a lift.
-2014 SSM BRZ MT
Old 05-19-2014, 05:59 PM   #6
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Mine didn't throw a CEL until quite a while later (say about a half week to a week), and then after it was cleared it was actually close to a month till it threw the CEL again.
^GT5 Replay Photo Mode^
Old 05-19-2014, 06:07 PM   #7
Trunksse
Drives: Firestorm FR-S
I am thinking its normal from the noise generator as I have the same noise with mine but I have no leaks. Also the blowing sound is only heard in the cabin, but not on the outside.
Trunksse is offline   Reply With Quote
Old 05-20-2014, 01:43 AM   #8
vestal52
vestal52's Avatar
so it's normal? well I'll check tomorrow first thing in the morning for leaks anyways.
never had that sound before the header was put in, how would that be able to affect the noise generator in the cabin?
Old 05-20-2014, 09:10 AM   #9
Trunksse
I think so, but others can with the header can also verify. There is a hole in the cabin where the noises come from; I am planning on plugging that up to see if it helps with that. Also, I recently realize the noise is there with stock, just that it's very very faint, you can barely hear it.
Sent from my Nexus 7 using Tapatalk
Old 05-20-2014, 09:13 AM   #10
FR-S Matt
It will eventually throw a CEL, but the amount of miles may vary when it does. It all depends on when the rear O2 starts reading the same flow pattern as the primary O2 then you will see the light come on and the engine will run in a closed loop mode real rich. It normally happens when you are cruising at the same speed down the highway for a good period of time rather than WOT or just simply shifting gears.
Old 05-20-2014, 02:43 PM   #11
calibrz
Turbo 86
Drives: GT86
CEL will be going on depends how soon the sensor takes it.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-20-2014, 11:32 PM   #12
NoobTron
Drives: 2014 Scion FRS, Argento, 6MT
I have a Borla catless.. Loud in a odd way for about a week before the Ecu "settled" and went about 3-4 weeks before I threw a CEL.
NoobTron is offline   Reply With Quote
Old 05-20-2014, 11:39 PM   #13
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
I have almost a year without the CEL
uspspro is offline   Reply With Quote
Old 05-22-2014, 02:52 AM   #14
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
Slightly OT but do you guys think a front pipe with a 200 cell cat or even a catless FP would throw a CEL without a tune?
Fortis is offline   Reply With Quote
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Catless header... o2 bungs before/after front pipe cat? Thorpedo Engine, Exhaust, Transmission 5 11-18-2013 12:59 PM
EJ20R 2.5" OEM Catless Header... On a FRZ? Kostamojen Engine, Exhaust, Transmission 0 09-21-2013 04:00 AM
SRT header back exhaust catless w/ tip A serial gixxer Engine, Exhaust, Bolt-Ons 6 12-05-2012 12:00 AM
