#169 |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I have lusted for an RX8 since they came out, and the R3 even more so.
But what kills it for me: Price - the car is 40K+ in Canada. MPG - my v6 SUV does better Flood - I know it's been addressed, but you still can't move the car from garage to driveway and turn it off. Floods. Doors - I LOVED the suicide doors, until I considered how to get into it in a tight parking space or garage. You can't open the back without the front open, and once you do that you're kind of stuck half-closing it to get the kid through then open again to get it. BAH. Trunk - I will not drive a car without a spare. Fix-it-gunk/Roadside works in Europe but not here where it can be 2+ hours of waiting if you even have service. If you get the optional spare, the trunk is virtually full. Reliability - I'm ok with the oil consumption (by design) but the fact is the engine design means rebuilds and that means specialists. $$$ FRS is similar looks/speed/handling with usable trunk/spare and normal coupe doors and a backseat that kids can use. Great mpg, standard simple NA motor. And it's 28K all in, vs 45K. |
#170 | ||
Drives: 2013 DZE/01 (sold for MX5 ND1)
Code:
Metric RX8 BRZ 0-60 MPH (s) 6.4 6.4 1/4 mile (s@MPH) 14.8@94.3 14.9@95.5 skidpad (g) 0.88 0.90 slalom (MPH) 67.1 - (Insideline's BRZ slalom = 69.1) Anyway, the FT86 ought to be almost as quick. In both cases, they're momentum cars, which generally don't put up impressive numbers. More important is that the RX8 was widely praised for being much more fun than its times indicated, and the FT86 is getting even more praise. The difference is 289 pounds if you compare a fully loaded USDM RX8 (3065 pounds) to the BRZ Limited. But if you compare other trims, the difference is considerably less. What I posted at NASIOC a couple weeks ago (FWIW since it was about the 2004 RX8): Quote:
#171 |
Drives: Attitude
American everything is always bigger and fatter, woot!
#172 |
Drives: '23 BRZ
Never seen a reported curb weight for the RX-8 less than 3000 lb., have seen them at up to 3100 lb. Weight difference vs. FR-S/BRZ is ~300 lb. as far as I can tell...
#173 | |
MazdaUSA only published the loaded GT's curb weight (with sunroof, etc). The 2004 RX8 base 6MT was 2889 pounds JDM. The base 6MT USDM shouldn't have been more than 50 pounds heavier, if that (and it didn't gain much over the years). There's been much speculation as to why MazdaUSA never released specs for the lower trims. Perhaps they knew the engine was slightly over-rated and an official lower weight would've called attention to that? The difference between the 2011 USDM RX8 Sport and the BRZ Premium seems to be ~200 pounds (though the RX8 lacked a spare). To be fair, the USDM BRZ isn't much heavier than a similarly equipped JDM 86. |
#174 |
Drives: Attitude
#175 | ||
Drives: '23 BRZ
3000 lb. min, 3100 lb. max is what i've seen. FWIW, in the motorcycle world it's a given that manufacturers LIE about their "dry" weights. I'm guessing that the 2889 lb. figure you have is at the very least an exaggeration... [/quote]There's been much speculation as to why MazdaUSA never released specs for the lower trims. Perhaps they knew the engine was slightly over-rated and an official lower weight would've called attention to that?[/quote]220hp and 3050 lb. gives 95.5mph in the quarter. That was the RX-8. Quote:
#176 | ||
Drives: Attitude
An earlier assertion I made that Subaru's published curb weight of the BRZ is just a wee bit higher than any model would actually be. Not a significant amount, mind you, but enough such that you won't find one in the wild with a full tank of gas, spare + tools, all fluids, and no objects on the inside that weights that amount. Or, the pre-prod weights simply don't match the actual production weights. |
#177 | |||
Some magazine articles only listed ranges (2900-3000, 3000-3050) or approximate values (2950, 3000). It was also widely reported as weighing 29xx pounds by owners that put it on scales with nothing removed (check out rx8club.com). Scales can vary and folks weren't consistant about how much fuel they had, but it supported the notion that the base and sport models were significantly lighter than the 2004 GT's 3029 pounds (from MazdaUSA's site). Quote:
It's worth noting that formula only provides an approximation as it doesn't account for things like traction, temp, air density, and CoD (which is quite low for the FT86). |
#178 | |||
Drives: '23 BRZ
All I can say is, I've been keeping an eye on the RX-8 since before it came out. I've NEVER seen an actual magazine-measured test weight below 3000 lb.
I'm positive that the 2933 lb. in that January 2003 M/T article linked above wasn't from actual data that they measured, it was tech data from Mazda. They also "estimated" 250hp for the 6-speed in that article! Wrong again... I've seen rwhp reports for the RX-8 in the 185-190rwhp range. ~220hp at the flywheel. Quick search on "RX-8 road test" http://www.caranddriver.com/reviews/...ormance-page-2 Quote:
(96mph/234)^3 * (3060 lb. + 200 lb.) => 225hp. http://www.caranddriver.com/reviews/...take-road-test Quote:
Curb Weight Automatic - 3,053 lbs. Manual - 3,029 lbs |
#179 | ||
Drives: '23 BRZ
Mazda lied about the RX-8's hp, but not by THAT much! [edit]Oh yeah, the formula is for flywheel power, not rear wheel. RX-8 rwhp ~185-190 from what I've seen. Quote:
Some mags correct 1/4-mile results for temperature and air density. Minor differences in drag (Cd*A) won't change results much. The equation *is* a quick/dirty approximation/estimate. But it's a very good one for getting in the ballpark. Last edited by ZDan; 04-05-2012 at 09:35 AM. |
#180 | |
The others are approximations, are taken from the MazdaUSA site (GT), or are for the R3 (with 19" rims). The official 6MT numbers I know about are: JDM 2004: 1310 kg (2888 lbs)I saw other magazine numbers between 2933 and 2960 for the base and Sport, and given the JDM spec and the lack of a sunroof and other extras, they made sense. Last edited by Deslock; 04-05-2012 at 05:46 PM. |
#181 | |
#182 |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
I like everything about the rx8 the looks are way better than the frs the interior is amazing but the engine is shit and that is why ill take.a frs
