Old 05-12-2014, 07:59 PM   #29
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by fstlane View Post
I replaced my old ZII's this week with the V2's and love everything about them so far. The on road ride quality and noise level is far better then the ZII's. I ran an autocross event today and they were superb. I missed taking top PAX time by .016 seconds which is better than I ever managed on the Dunlops. Interestingly, I had less roll over on the V2's even though the sidewalls are softer and I was running 3psi less than the ZII's. Overall I'm very pleased with the R-S3 V2's.
http://lvrscca.org/race-results/auto...ound07_pax.htm
Did you get them shaved or not?
neurokinetik is offline   Reply With Quote
Old 05-12-2014, 08:55 PM   #30
fstlane
fstlane's Avatar
Drives: BRZ Limited
They're unshaved.
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
neurokinetik (05-13-2014)
Old 05-13-2014, 04:45 PM   #31
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I run 245/40R17. On the ZII's I had to run 36-37f/34r to keep from rolling the fronts. On the R-S3's I dropped the pressures down to 34f/32r and they felt great.
I'm running 255/35 18 ZIIs ... and 36 feels like I'm rolling on granite tires ...
The sidewall obviously is stiffer on mine compared to yours due to the lower profile, however.
I actually like the feel and performance of mine at about 32 in the front and back, which means at my NASA events (because I don't use nitrogen) I have to bleed down to about 29 after my first session so that I get up to 32 after a couple laps.
I'm toying with the idea of a pound or two more up front to begin with at Heartland Park, Topeka at the end of the month. Yet after 4 events on these tires I haven't shown any rolling over in the front. Again, my guess is the stiffer sidewall from the lower profile.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
fstlane (05-13-2014)
Old 05-18-2014, 10:46 PM   #32
neurokinetik
Finally got to try out the V2 RS3s for the first time this year. They don't feel any different than the old tire, which IMO is good. Temperatures at today's event were about 58 degrees. I never felt like I was lacking grip, the tires seemed to be working pretty well, despite never being more than slightly warm to the touch (but enough to reach my desired pressures - which were the same as I ran on the old version of the tire). I ended up running pretty close to my benchmark drivers (though it took me way too many runs to remember how to drive this car properly, or even turn off the TC/ASC for that matter).
Last year I ran the old RS3s in 245/40-17, this year I decided to try them in 255/40-17. Other than that, and a slightly better alignment (used ballast this time and did a better job measuring - front is now dead-on, and matched both sides, but rear camber mismatch is still 1.3 degrees, FU Subaru.)
We'll see how they do when the temps are actually warm, but so far, so good!
The Following User Says Thank You to neurokinetik For This Useful Post:
fstlane (05-18-2014)
Old 01-23-2015, 09:03 AM   #33
FTemplar
Drives: BRZ Sport-tech 2013
Hi, I'm considering these tires but would you still recommend them for street only driving?
Thanks & regards
FTemplar is offline   Reply With Quote
Old 01-23-2015, 09:08 AM   #34
vroom4
Kind of overkill, and are terrible in the cold.
vroom4 is offline   Reply With Quote
Old 01-23-2015, 11:45 AM   #35
FTemplar
I'm from Canada so obviously would drive with winter tires, so cold is not an issue. I'm more curious about the lifespan of these tires.
Old 01-23-2015, 11:50 AM   #36
Thorpedo
The SquadWhisperer
Thanks & regards
For the street I really like the re11a, great grip and handle the wet. Fairly quiet compared to other similar tires.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following User Says Thank You to Thorpedo For This Useful Post:
sw20kosh (01-26-2015)
Old 01-23-2015, 12:05 PM   #37
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
And a rather good track tire too
Sleepless is offline   Reply With Quote
Old 01-23-2015, 12:14 PM   #38
Thorpedo
The SquadWhisperer
Yep! Both my autocross championships were won on them!
Old 01-23-2015, 11:56 PM   #39
Kostamojen
These are backordered to infinity in the size I want... Kinda pissed. I'm going to have to go with something else for this season.
Old 01-26-2015, 05:27 PM   #40
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Which tire are you thinking then?
G_Ride is offline   Reply With Quote
Old 01-26-2015, 06:21 PM   #41
sw20kosh
Drives: 2013 Black FR-S
RE-11a is a fantastic tire.
Old 01-26-2015, 07:15 PM   #42
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Call AutoRND in Fremont, they might have a set
cactus is offline   Reply With Quote
The Following User Says Thank You to cactus For This Useful Post:
tahdizzle (01-26-2015)
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 12:23 AM
Getting rid of 225/45/17 Hankook RS-3s Propaganda NY / NJ / CT / PA 5 12-05-2013 01:49 AM
FS: hankook rs3 215/45/r17 $350 thaiguy8904 Wheels and Tires 1 05-30-2013 05:51 PM
FS NJ: 255/35/18 hankook RS3 VSGTS14 Wheels and Tires 0 02-14-2013 05:14 PM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 06:59 AM
