#57 |
Drives: 2022 BRZ Limited
hmm..it seems like I'd better do this before I put my KW kit on the car, since it will be harder to reach and more work.. Thanks for the heads up
Can anyone post some better pics showing the best way to reach those hoses underneath the intake manifold or better yet create a DIY for this? I think this thread should be sticky since it seems like many people run into same issue
#58 | |
Seems Legit
Drives: Toyota
The best pictures are those posted by @rb6freak thanks to @ptuning turbo installation guide which states to clamp the hoses. With the accessory belt off and the AC compressor sitting either on top of the manifold or the oil filter, with a shop light, you can get the job done in 30-40 minutes, depending on your setup. I suggest clamping as soon as you remove whatever intake you're using whether its stock or CAI. At that time everything front of the throttle body is wide open (i.e. no intake charge pipe in the way, no big honking turbo, no supercharger, etc.). With a supercharger installed this task becomes infinitely more involved as you have even less space to work with. In any case these are the steps one would take in order to gain access to the vacuum lines to clamp. Removing Stock Airbox http://www.ft86club.com/forums/showthread.php?t=7975 Removing Accessory Belt http://www.ft86club.com/forums/showthread.php?t=10227 With that done you can proceed to removing the AC Compressor. There are 3 14mm bolts that must be removed in order to swing the compressor out of the way. 2 are below the compressor pulley, one on each side, loosen and remove these first. If you have a front mount turbo installed the best tool to use to remove these bolts would be a ratcheting wrench as it works wonders in tight spaces. The 3rd is behind the compressor, loosen and remove it last. The AC compressor can now be moved to the side. You'll need at least 4 9/16" spring clamps and 3 1/2" spring clamps. I found the best tool for the job was a pair of long, skinny, but sturdy needle nose pliers. By far the most difficult clamp was the throttle body clamps. All the others are cake. Refer to @rb6freak's post for the location of the hoses that will use the 9/16" clamps and 1/2" clamps. http://www.ft86club.com/forums/showp...1&postcount=35 1 hose next to the port injectors - 9/16" clamp 1 hose underneath throttle body - 9/16" clamp 2 hoses underneath intake manifold at the EVAP solenoid - x2 9/16" clamps 2 hoses on top of intake manifold (underneath plastic boxer cover) - x2 1/2" clamps 1 hose behind motor on top of trans - 1/2" clamp. Give each hose a nice tug and you'll notice they aren't going anywhere. Reassemble in reverse order ensuring the accessory belt is seated within the teeth of each pulley before starting the car.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#59 | |
Thanks for the detailed reply. I will definitely install all the clamps as you suggested right before the SC install to avoid double efforts. While at it I'll try to take better pictures for those who might need
#60 |
Drives: Moped
Vote for a sticky so this thread doesn't get buried....
#61 |
Subaru Certified Sales
Drives: '13 BRZ Premium, '05 WRX STi
You don't need to move the AC compressor. Just pull the throttle body. It's four 10mm bolts. And removing the solenoid with the 10mm nut on the back side of the manifold makes it so much easier to clamp. The throttle body being off also makes it easier to access the port near there. And, yes, a good pair or two of needle nose makes everything awesome.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85 [Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s [Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans "The only thing that I trust in this world is cars!" - Don 'The Goods' Ready |
#62 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Sticky this
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
| The Following User Says Thank You to kiichiro For This Useful Post: | Lonewolf (04-20-2014) |
#63 | |
Drives: FRS
#64 |
It's possible to do without pulling anything with the right hands
SOLD THEM BOTH
#65 | |
Which one is the solenoid?Are you referring to a boost control solenoid included in one of those turbo kits?
#66 | |
Drives: Toyota 86
Shine a flashlight on the holes in between the intake manifold runners. You'll be able to see the hoses from there. I used worm clamps on mine since I couldn't find any spring clamps. Tigthened them up using a screwdriver inserted through the holes between the runners. Moving the AC compressor out of the way makes the job 100x easier. |
#67 |
Best thing to do is just pull the manifold and completely remove the solenoid. Then you only have one place to cap/clamp. It's not a very difficult job, and will make sure the problem doesn't show back up down the road. If you don't do that, make sure that you use real clamps and not zip ties.
| The Following User Says Thank You to jamesm For This Useful Post: | glamcem (05-18-2014) |
#68 | |
Thanks again
#69 | |
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
#70 |
I just used the first part of the innovate install manual as a guide. The only other thing I remember taking off is the shielding over the port injectors.
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
| Heads Up BRZ Available In So Cal | ZmZMWagon | Southern California | 17 | 06-18-2012 03:10 PM |
| Photos: Toyota FT-86 at the 2010 Paris Motor Show (including undercarriage photos) | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 11-29-2010 01:51 PM |
