05-18-2014, 01:28 AM | #29 |
Drives: '91 MR2
Nice wheels! Can anyone confirm if the details are silver or white?
Tada-san: Oh so cooler than the concept.
05-18-2014, 07:27 AM | #30 |
Trim the Fat & add Boost
Drives: sometimes I fly
Looks white under bright lights, but is actually machined silver... no paint.
05-18-2014, 07:28 AM | #31 |
05-20-2014, 08:15 PM | #32 |
crew chief
Drives: Race car FR-S
well i said i would post pics so here they are, not on the car though and it will take a while before i do, race car build in progress, i am in a wiring nightmare right now.
For those wondering, the inside is silver, it is just machined in fact but under strong light it does kind of look like white. That would be a good place to paint though to give the same accent as your car's color... guess what we will do anyway, we used to run Enkei RPF1 on our race car but the bolt pattern isn't the same so we can't reuse them, we needed new wheels and decided to try something else. So here is a little comparo with the RPF1. First, they are both the same spec, just different bolt pattern, 17x9 Et +35 The RPF1 weight 15,6 lbs the GPF1 weight 16,8 lbs so this is a 1,2lbs advantage for the Enkei. Price, well the GPF1 is litterally half price. The finish is good, they are made in China but they still look good. They are a tiny bit wider. The lip on the outside is thicker and seems more solid. The RPF1 are weak and break easily with such a low weight, let's hope the GPF1 are more solid. GPF1 also have dual tire valves, this will help in the pit taking quick pressure. I wish they would offer them in different color though like silver at least. |
The Following 11 Users Say Thank You to puma For This Useful Post: | Anorexic 86 (05-21-2014), chris x sway (05-22-2014), DAEMANO (05-20-2014), Fly Guy (05-21-2014), GaN-MaN (05-20-2014), hmong337 (05-21-2014), JonAvalon (05-20-2014), mit_peid (05-22-2014), paddleshifter (05-22-2014), Pekingduck (05-23-2014), SWPinATL (05-20-2014) |
05-21-2014, 01:53 AM | #33 |
Thanks puma!
Weight list updated... |
05-21-2014, 10:51 AM | #34 |
Just the tip
Too bad the hub bore isn't correct. Hub center rings are needed from Amazon, which are cheap.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
05-22-2014, 09:38 AM | #35 | |
Drives: 2014 FR-S in Mayonnaise
Thanks in advance.
05-22-2014, 10:55 AM | #36 | |
Just the tip
Plastic ones will crack and break easier so I went with metal.
The Following User Says Thank You to stockysnail For This Useful Post: | RehabJeff86 (05-25-2014) |
05-22-2014, 12:00 PM | #37 | |
Drives: UK GT86 in White with alcantara
Cheers. |
05-22-2014, 01:27 PM | #38 |
Just the tip
[ame="http://www.amazon.com/pieces-Hubcentric-73-1mm-Aluminum-Hubrings/dp/B00CH8MDNA/ref=sr_1_1?ie=UTF8&qid=1400779642&sr=8-1&keywords=Aluminum+hubcentric+rings+73.1mm+OD+to+ 56.1mm+ID"]Amazon.com: 4 pieces - Hubcentric Rings - 73.1mm OD to 56.1mm ID - Aluminum Hubrings: Automotive[/ame]
05-22-2014, 02:34 PM | #39 |
Drives: none yet
where to order these rims?
The Following User Says Thank You to johnnyfast11 For This Useful Post: | RehabJeff86 (05-25-2014) |
05-23-2014, 03:11 PM | #40 |
Drives: WRX
More pics please, I would like to see how concave they are...
Thanks. |
05-23-2014, 05:05 PM | #41 |
Mine hit the tarmac at Gatwick airport, London next week. I went with 18x9 and I'll post some pics asap.
The Following User Says Thank You to steveoexige For This Useful Post: | DAEMANO (05-24-2014) |
05-25-2014, 02:35 AM | #42 |
Drives: 2013 WhiteOut FR-S
No 5x100??
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
Similar Threads | ||||
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 06:32 PM |
FT86 Canada HRE Flow+Form - SimplyTire 2014 | Zook@SimplyTire | Canada Classifieds | 4 | 06-07-2014 11:05 AM |
Your Top Three Form of Automotive Racing, From Two to Ten Wheels. | LBC Por Siempre | Other Vehicles & General Automotive Discussions | 14 | 02-24-2014 11:09 AM |
New SSR Flow Formed wheels available for FRS - Not bad on price! | ModBargains.com | Wheels and Tires | 21 | 01-13-2014 11:27 AM |
Lightweight wheels or wide wheels | Moetivegt86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 11-06-2013 10:57 PM |
