Old 05-17-2014, 05:15 PM   #309
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by Tromatic View Post
Sanity check, then. If I use the ECUFlash to flash the latest B01C ROM, I can still use the OFT as well, correct? I'd zero the OFT and read the B01C from the car. IIRC, though, the ECUFlash will do just about any ROM, and is NOT idiot (moslty) proof.
Am I close?
Sounds like you'd be spending as much as an ecutek.
Don't quote me on this but I think the tatrix can upload OFT tunes somehow. My guess in a couple years the tatrix will upload anyones tune (not saying that's ethical.)
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 05-17-2014, 10:26 PM   #310
steve99
Drives: FT86
Am I close?
Yes that about sums it up
Write you stock rom from oft back to car.
That will allow you to erase oft effectivly unmarrying oft
Write updated stock calibration rom to car with tactrix
Read updated stock calibration with oft this will marry oft to new stock calibration
Upload tune files for updated rom to oft
Flash new tunes based on updated rom id with oft
Neither oft or tactrix/ecuflash encript rom or change seed keys or change rom structure or embed licence info, unlike ecutek, brz edit which do one of more of these.
A stock rom flashed with oft or tactrix/ecuflash is a completly stock rom exactly what a dealer would flash
Old 05-17-2014, 10:41 PM   #311
regal
except I think there is a flash date. If the dealer see's a date your car wasn't in their garage its probably bye bye warranty without a receipt from another dealer for that time period.
Mods:
Old 05-17-2014, 10:50 PM   #312
steve99
Drives: FT86
If you could point me to this date location ?
In techstream i have only found time since DTC reset and miles since last reset ,no counters or date info just elapsed time
This reset could occurr with removal of batt terminal or fuse or flat battery.
Please enlighten me :-)
xjohnx (05-18-2014)
Old 05-18-2014, 12:46 AM   #313
Tromatic
Close, I guess. I already have the OFT. All I want is the latest freakin' ROM.
Old 05-18-2014, 09:59 AM   #314
steve99
Drives: FT86
added latest stock roms from each series to ecuflash/tactrix guide ZA1JB01D is now their think thats the one your after thanks to Td-d for roms :-)
http://www.ft86club.com/forums/showthread.php?t=62332
Tromatic (05-18-2014)
Old 05-19-2014, 08:29 AM   #315
regal
You are correct I worked on this over the weekend tatrix flash= same as dead battery to the dealer IMHO.
Mods:
The Following User Says Thank You to regal For This Useful Post:
steve99 (05-20-2014)
Old 08-10-2014, 09:52 PM   #316
Brinks
Brinks's Avatar
[ame]http://www.youtube.com/watch?v=LqOZUlfgluk[/ame]
Got some major VVT Noise, on the other hand the car pulls good and the revs are smooth. Just sounds like shit.
OFT Stage 2 EL E85 V2.3
Nameless EL Header
Nameless mid/over with Helmholtz Resonator
Perrin 2.5 Resonated Cat Back
K&N drop in filter
Brinks is offline   Reply With Quote
The Following 2 Users Say Thank You to Brinks For This Useful Post:
Dezoris (08-12-2014), DocWalt (12-07-2014)
Old 08-14-2014, 12:10 PM   #317
Brinks
Brinks's Avatar
Took the nameless downpipe out and replaced it with the stock one. No more VVT noise ! I can tell it's still there, just not audible anymore. Hopefully it's not hurting my gains but from the dynos I've seen on here it seems replacing the stock exhaust doesn't really net you any discernible gains.
EDIT!!!!!!!!
I recant my last statement. After driving around most of the day I notice that the stock over/front is definitely restrictive and drones. The revs aren't as quick, kinda the whole point of a ELH. I've read a couple post that getting the non resonated nameless downpipe covers the sound up, Hopefully it doesn't drone too or I will be back to square one minus 2-300 dollars.
Old 12-07-2014, 08:16 PM   #318
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Nameless EL Header
K&N drop in filter
My car has the same horrid noise, but I have a JDL UEL header and factory catback. I figured the Nameless pipe with the helmholtz resonator wouldn't be too bad, but it sounds like that. It's a LOT louder outside the car, and made me think the pipe was touching something. I think there's something about certain exhaust combos (maybe the OFT tune? I highly doubt that) that causes the noise. I'm going back to stock stuff until I get JDL replacements. It doesn't feel faster with the Nameless pipe anyway.
Old 03-21-2015, 08:10 PM   #319
ztan
Drives: Toyota 86
EL Comp smoothing
I did have the rasp noise between 3500-4000 rpm running Shiv's 1.59 settings. Improved a little bit with MAF rescaling and PII balancing, improved quite a lot after adusting for trims on EL comp table during closed loop operation, leaving VVT settings untouched.
Not sure exactly why it helped; I had rasp with foot flat which was in open loop operation and it was much better after adjusting the table.
My final EL comp changes compared to stock A01G ROM before FI:
ztan is offline   Reply With Quote
Old 04-06-2015, 02:34 AM   #320
steve99
Drives: FT86
Just interested in the philosophy behind adjusting the EL Comp tables ie why/how is is done.
I don't get the noise as on UEL header.
do you think the noise reduced as adjusting the el comp table put ecu into different load cell hence different vvt cam angles applied , hence reduced resonance ??
Old 04-07-2015, 01:34 AM   #321
ztan
Drives: Toyota 86
EL comp adjusts for erratic differences in flow/VE based on manifold pressure and RPM (like a Speed Density compensation for the MAF). To adjust it, I used closed loop operation trims (like scaling a MAF under 2.5V) and adjusted each load/RPM cell based on the trims. Data processing all done using MatLab scripts.
Load cell and hence VVT timing may have changed, though at WOT at 4000, my EL comp was only changed by <2%. I'm still not sure why adjusting this made a difference, though it was the only thing I altered at the time.
The Following 2 Users Say Thank You to ztan For This Useful Post:
steve99 (04-07-2015), Wayno (04-07-2015)
Old 04-07-2015, 04:31 AM   #322
donoman
donoman's Avatar
Drives: '13 FR-S
Sounds to me like valvetrain noise. Or a cam chain. Something like that. It's not a good sound.
It does sound "raspy" like the old E46 M3's... not sure if that's a good thing though.
donoman is offline   Reply With Quote
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 05:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
