Old 05-17-2014, 07:51 PM   #575
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by milhouse View Post
Its actually much easier than it seems from reading - now that all the info has been posted, though I didn't install an Aux adapter. I do have the USB adapter and a backup camera and they are working with my BRZ now. Mine is also completely reversible. Unfortunately it seems my unit is defective (no AM reception and the volume knob doesn't work) so I need to setup a replacement.
When I reinstall the new unit maybe I will take some photos and do a DIY.
I understand that it may not be very difficult, and I'm an electrician by trade so I doubt I would have trouble. I already own all the tools and that's not the problem, I'm sure I could figure it out. However, I do like to come prepared for a task, and they say more time spent in prep saves you hours of pain later. I was hoping somebody had more detailed pictures and diagrams of just what they wired to where.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 05-17-2014, 08:56 PM   #576
jeffsquared
Drives: 2013 FR-S 10 Series #1186
More straight forward detail and not convoluted instructions would be excellent! It would certainly push me closer to ordering one of these units. Not bashing anyone specific here but in general it seems like HU install tutorials are usually wordy and don't get to simple step-by-step instructions.
jeffsquared is offline   Reply With Quote
Old 05-17-2014, 09:47 PM   #577
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Deathalo View Post
Should've just bent it instead of filing man, bending it with a wrench took all of 5 seconds and minimal effort.
I kind of tried that, but it being so close to the hole I needed to use made me nervous.
Prog is offline   Reply With Quote
Old 05-17-2014, 10:14 PM   #578
xjohnx
Grip>Slip
xjohnx's Avatar
i just used a dremel to trim the fronts of the brackets, and used a drill to get rid of the little bumps.
Old 05-17-2014, 10:27 PM   #579
Prog
Prog's Avatar
If I would've already had a file, it would've taken me 5 minutes total, so not a big deal.
Old 05-19-2014, 10:49 AM   #580
inositle
Drives: Subaru BRZ Limited WRB
I just ordered one of these units, thanks for all of the great info! I ordered the antenna adapter, but I wasn't sure if I need a wiring harness as well (Metra 70-1761 ?). I have a fully stock car, so I just need radio/speakers/USB plug to work for now.
This is probably already answered in here, but I haven't been able to find it yet. Thanks!
inositle is offline   Reply With Quote
Old 05-19-2014, 11:21 AM   #581
Prog
Prog's Avatar
Since this is a Toyota universal model, the harness that comes with the Ca-Fi already fits the car. You may have to repin a few things depending on which car you have (your profile says Taurus, but since you bring up the Metra harness I'm assuming you've since got a twin and haven't updated your profile yet). Also if you want the stock USB/Aux ports to work, you'll need a couple extra adapters.
Old 05-20-2014, 08:44 AM   #582
DC2R
Drives: 2014 Scion FR-S
Anyone get Equalizer working? Can't find any place to set the sound effects app in settings. I don't mind using built in but I can only access it from built-in music app
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-20-2014, 08:54 AM   #583
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
I think its only availabe in the Music App, but if you are rooted, you can use the instructions here to install Viper which is a much nicer equalizer that does control system audio.
http://www.ft86club.com/forums/showp...&postcount=487
milhouse is offline   Reply With Quote
The Following User Says Thank You to milhouse For This Useful Post:
DC2R (05-21-2014)
Old 05-20-2014, 10:01 AM   #584
morphius88
R0GUE
morphius88's Avatar
Drives: 2013 Whiteout Scion FR-S
Do you happen to know which adapter will be needed? Im about to drop the dollars on this unit as well.
morphius88 is offline   Reply With Quote
Old 05-20-2014, 10:32 AM   #585
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
So weird thing started happening to my unit, when I turn on the car and the unit wakes up on radio, nothing starts playing until I change the radio channel. I've tried restarting the unit completely but it keeps happening, it never used to do this until a few days ago. Also, Pandora keeps crashing even though it's not open (and no widget), has anyone who updated to the latest version experienced less app crashes, particularly pandora? I'm thinking of updating in the next day or so. I'm also still worried about the bug where the HU white lights stay on when my lights automatically shutoff at night when locking the car.
Deathalo is offline   Reply With Quote
Old 05-20-2014, 11:24 AM   #586
charged86
charged86's Avatar
I feel like i cant puchase this radio because i dont understand how to build and service a computer
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
DC2R (05-21-2014)
Old 05-20-2014, 11:41 AM   #587
Prog
Prog's Avatar
The aux adapter is a modified steering wheel adapter. SHIFTER linked to it somewhere in this thread. The USB adapter is a standard Toyota adapter that requires no modification, just plug and play. I believe it's this one [ame="http://www.amazon.com/Axxess-AX-TOYUSB-Adaptor-Retain-Vehicles/dp/B00EAYYQDO"]Amazon.com : Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles : Vehicle Audio Video Power Adapters : Car Electronics[/ame] , but someone should probably confirm that. Ignore the bad review on it, dude probably bought it for a car it doesn't work with.
The Following User Says Thank You to Prog For This Useful Post:
morphius88 (05-20-2014)
Old 05-20-2014, 01:21 PM   #588
morphius88
R0GUE
morphius88's Avatar
The aux adapter is a modified steering wheel adapter. SHIFTER linked to it somewhere in this thread. The USB adapter is a standard Toyota adapter that requires no modification, just plug and play. I believe it's this one Amazon.com : Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles : Vehicle Audio Video Power Adapters : Car Electronics , but someone should probably confirm that. Ignore the bad review on it, dude probably bought it for a car it doesn't work with.
Thanks Prog. I think I found the adapter for the aux but I probably won't get it at this time as I almost never use aux. USB is a must though.
Sent from planet Mars using HTC One
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
