Old 05-17-2014, 12:14 AM   #1205
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by SirBrass View Post
How do you shut off the annoying beeping of the seat belt alarm when using the harness?
Route the stock belt around the back side of the seat and click it in so it's out of the way.
Old 05-17-2014, 12:18 AM   #1206
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by ATL BRZ View Post
Very secure in the seat now, to the point where my driving has improved because I have more feedback through the seat into my body as one unit.
After safety mods (which may include brakes and rubber), this is the most important mod you can make. When the wheel/pedals/shifter/chair combo is optimized for him or her, the driver has more attention to devote to everything else. And the faster you go, the more attention everything else demands - that's not optional. It's hard to really get until you've got it set up right, and then it's like..."Wow, so this is what they were trying to tell me!"
dradernh is offline   Reply With Quote
Old 05-17-2014, 12:48 AM   #1207
CSG Mike
CSG Mike's Avatar
The HANS device (or equivalent) is what so many people skip... great setup @ATL BRZ
Old 05-17-2014, 12:57 AM   #1208
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
And how much does a HANS device cost?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-17-2014, 12:59 AM   #1209
SirBrass
SirBrass's Avatar
Only if it doesn't interfere with the harness routing behind the seat.
Old 05-17-2014, 01:00 AM   #1210
CSG Mike
CSG Mike's Avatar
http://simpsonraceproducts.com/shop-...straints/hans/
Old 05-17-2014, 01:30 AM   #1211
DatApex
Drives: 2013 WRB BRZ Limited
The actual temps will go up as you drive, the goal is to make the spread of temperatures as small as possible.
Outer edge higher = need more camber. Inner edge higher = need less camber
Center too high = lower pressure. Center too low = lower pressure
Inner higher than outer and center = need less toe (if you can manage it)
38 hot is a good guide; adjust to taste and by temp
Awesome, that helps a TON. First track event of my season at Gingerman Memorial Day weekend. Hopefully I'll have everything set up by then.
DatApex is offline   Reply With Quote
Old 05-17-2014, 04:21 AM   #1212
CSG Mike
CSG Mike's Avatar
Originally Posted by solidONE View Post
So you'd have to buy a compatible helmet to go along with it?
Or drill holes into your current one (and make sure the mounting points are properly braced/reinforced.
Old 05-17-2014, 09:25 AM   #1213
buddy32
Drives: WRB Subaru BRZ Limited
Tracking on plugged/patched tires?
buddy32 is offline   Reply With Quote
Old 05-17-2014, 10:28 AM   #1214
dradernh
Not a good idea, assuming it's allowed in the first place. Be sure to check ahead of time.
Old 05-17-2014, 10:54 AM   #1215
wparsons
wparsons's Avatar
Originally Posted by AZP Installs View Post
I don't suggest doing any HPDEs with the stock all-season prius tires. That's just me.
I disagree, especially for inexperienced drivers. The primacys make it MUCH easier for a novice to feel out the handling of the car at lower speeds. They're predictable, and howl to let you know when you're pushing too hard for their liking. Going straight to sticky tires will make it much harder to teach someone how to balance the car with their inputs.
Most places are fine with it as long as the tire is patched properly from the inside and not just a plug inserted from the outside. I picked up a screw in one of my tires and the local sanctioning bodies have zero issues as long as the hole was in a safe place, and it was fixed right.
flickr
Old 05-17-2014, 10:55 AM   #1216
CSG Mike
CSG Mike's Avatar
Patched? ok! Plugged.... skeptical.
This lap is actually on a patched tire... picked up a nail on the way to the track.
[ame="https://www.youtube.com/watch?v=XU4Sa3RCCV4"]Willow Springs International Raceway BRZ/FRS/GT86 lap record 1:30.778 - YouTube[/ame]
Old 05-17-2014, 06:03 PM   #1217
ATL BRZ
ATL BRZ's Avatar
Yeah I wouldnt trust a drilled helmet... Probably better idea to get a compatible lid then.
@ATL BRZ how much was the set up, if you don't mind me asking?
Every helmet with HANS anchors either out of the box or later is "drilled" to fit the anchors. As long as the measurements are correct and the anchors are legit with the proper reinforcements, you can trust it. I had a professional drill and install anchors for $55. Worth it to me to keep using my SA2005 for a while longer.
Price breakdown:
Agency Power bolt-in harness bar: $600
Schroth Profi II ASM FE 4-point harnesses (black/pull down with clip-in lap belt ends and 01324 hardware kit): $354
My HANS sport II is a hand-me-down from my dad since he sold his race car but they are $585 new
G Force Pro Eliminator helmet: $250
Those prices are all before tax/shipping and discounts. I highly recommend Discovery Parts for all the gear besides the harness bar.
Old 05-17-2014, 07:18 PM   #1218
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Price breakdown:
Agreed. Discovery Parts are a great vendor. I got the anchors done on my helmet by them at my first Lemons race. Highly recommended.
n8dog11914 is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
