Old 05-15-2014, 10:02 AM   #2311
OrbitalEllipses
Drives: Attitude
Troof!!
Ricer mod
ftc~brz (05-15-2014)
Old 05-15-2014, 10:03 AM   #2312
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Ricer mod
It is, specially when I crank up the reggeaton songs...
Boooomm, booom boom boooom booooommm...
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Boom (05-19-2014), ftc~brz (05-15-2014), sklimo (05-15-2014)
Old 05-15-2014, 10:07 AM   #2313
sklimo
The Following 3 Users Say Thank You to sklimo For This Useful Post:
ftc~brz (05-15-2014), SmsAlSuwaidi (05-15-2014), Sportsguy83 (05-15-2014)
Old 05-15-2014, 12:40 PM   #2314
ftc~brz
Done
Drives: WRB BRZ
pitbull.......GTFO
my visual erotica is now on overload....
ftc~brz is offline   Reply With Quote
The Following 2 Users Say Thank You to ftc~brz For This Useful Post:
sklimo (05-15-2014), Sportsguy83 (05-15-2014)
Old 05-15-2014, 12:58 PM   #2315
ftc~brz
Done
Drives: WRB BRZ
David, you should be Pitbull for halloween.....that would be epic
The Following User Says Thank You to ftc~brz For This Useful Post:
sklimo (05-15-2014)
Old 05-15-2014, 01:04 PM   #2316
Sportsguy83
Drives: Limited BRZ
DALE!!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Old 05-15-2014, 01:37 PM   #2317
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Now you need to relocate the battery to the other side of the trunk for dat 50/50 weight split. JUNIOR!!!
The Following 3 Users Say Thank You to King Tut For This Useful Post:
ftc~brz (05-15-2014), sklimo (05-15-2014), Sportsguy83 (05-15-2014)
Old 05-15-2014, 01:38 PM   #2318
Sportsguy83
Drives: Limited BRZ
Shiberu should have put dat SW on the passenger side...
Old 05-15-2014, 02:57 PM   #2319
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
My balls are broken.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthony For This Useful Post:
Old 05-15-2014, 03:00 PM   #2320
Sportsguy83
Drives: Limited BRZ
Anthony (05-15-2014), sklimo (05-15-2014)
Old 05-16-2014, 06:28 PM   #2321
Sportsguy83
Drives: Limited BRZ
Originally Posted by FAER View Post
lovin the build.
Thanks man. Went to the Dyno last night to see if it was true @Rev Works Dyno is as heartbreaker as it seems (20%) lower than Dynojet.
I did not run Map4 as I don't think I'll run it again ever without building. ( 460 WHP +20% =552 WHP Dynojet).
However, I did run Map3 17 psi (calculation was 416 WHP +20%= 499 whp Dynojet)....
Well Rev Works Dyno IS as heartbreaker as advertised. I made 496 WHP on that map we had calculated 499....
Dat tune doe... so SMOOTH! @jamesm The Wizard hard at work. @KAB-FRS on the hardware
See below.
I'll get a better pic later tonight.
jamesm (05-16-2014), Muskokan (05-16-2014), Rev Works (05-19-2014)
Old 05-16-2014, 06:51 PM   #2322
jdmblood
jdmblood's Avatar
Drives: white subaru brz
See below.
cant touch the 5hundo range though
jdmblood is offline   Reply With Quote
Old 05-16-2014, 06:53 PM   #2323
Sportsguy83
Drives: Limited BRZ
I already did..read above
Sent from my SM-N900A using Tapatalk
Old 05-16-2014, 07:20 PM   #2324
Sportsguy83
Drives: Limited BRZ
Had the scare of my life last night car wise... Thought I blew it!! After dyno was giving a ride to shop owner. Everything great on map 1, move to map 2 punch it, out of nowhere oil in the windshield, rear view mirror, only smoke could be seen. Oil pressure gauge... 2 psi.... dash light on... Car DOES NOT turn off by button until low speeds... I was frantically hitting it and nothing happened.
I said it blew and he was like nope, has to be a hose... It was one of the oil cooler hose. Pop it back in, fill it with 4 quarts of motul, drive 3 miles home. Go to walmart at 1 am to get simply green to clean it all, move the car to light, spray it. Get on car to move it to my house to hose it with water.. FUCKING hose blew off again. It was cracked.
Spent cleaning till 3 am and still left a bad mess. Got a new smaller filter to allow hose to take different route cut it and push it in and it seems to be holding fine.... What a bad night ending.. I also had to push car by myself and getting it over a steep part of the driveway took a lot of effort.
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
