Old 05-15-2014, 04:30 PM   #15
bfrank1972
Drives: 2013 FR-S Argento
Yup FR-S spring rates are higher in rear and lower in front than BRZ, the car will be noticably more willing to rotate as you approach limits (can be percieved as more turn in 'bite' vs more 'push' with the BRZ). That said, it sounds like you're noticing differences at lower limits too? If that's the case it could easily be down to alignment and tire pressure differences between your cars.
Old 05-15-2014, 04:36 PM   #16
wparsons
wparsons's Avatar
The problem with the spring rate theory is that the BRZ front spring rates are higher than the FRS rates, and that will make the front react quicker and feel more responsive because the weight transfers faster.
The BRZ will push more at the limit and rotate less, but unless you're at the limit it *should* feel more responsive to steering inputs.
flickr
SirBrass (05-15-2014)
Old 05-15-2014, 04:49 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by shattered_memory View Post
A few months ago I test drove a friend's FR-S and noticed a few small things compared to my BRZ. First of all, I did notice that the rear did feel stiffer and slightly more harsh than the BRZ (Hence the stiffer rear spring rates), but I also noticed that the steering feel on the FR-S was more precise. At lower speeds the steering was more direct and responsive compared to my BRZ. Is this steering feel contributed to the stiffer rear spring rate?
Alignment and/or tire.
I've driven multiple of both and have never noticed a difference if all were stock.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 05-15-2014, 04:53 PM   #18
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
That, and the BRZ and FR-S's rear spring rates are the same, IIRC.
^GT5 Replay Photo Mode^
Old 05-15-2014, 08:25 PM   #19
wparsons
wparsons's Avatar
They're slightly different, but not as different as the front rates.
flickr
Old 05-15-2014, 08:27 PM   #20
SirBrass
SirBrass's Avatar
Well, if one goes to spec-r springs, it's the same rates for both .
Old 05-15-2014, 08:32 PM   #21
wparsons
wparsons's Avatar
Wait, were you talking about the swift springs or the stock ones? If you meant the swift springs, the rear rates are the exact same.
flickr
Old 05-15-2014, 08:46 PM   #22
SirBrass
SirBrass's Avatar
I was shifting the topic a bit. Swift sport springs have the same rear rate between them, but the spec-R springs are identical between brz and fr-s.
But on topic is talking about OEM springs.
Old 05-16-2014, 10:07 AM   #23
wparsons
wparsons's Avatar
Ok, I'm on the right page now.
Stock BRZ front rates are stiffer than the FRS rates, and stock BRZ rear rates are softer than the FRS rates.
flickr
Old 05-16-2014, 12:05 PM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
His car is completely stock, but has about 30k miles on the car. Mine is barely hitting 3k miles. Even when he drove my BRZ, he mentioned the car's steering was not as responsive.
Is he on the original tires? If so, it's down to different tread depths. Tires with 9/32" tread depth are way squirmier and less responsive than tires down to 2/32".
shattered_memory (05-16-2014)
Old 05-16-2014, 12:11 PM   #25
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It also could be as simple as having toe-out on the FR-S and toe-in on the BRZ.
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 05-16-2014, 05:42 PM   #26
shattered_memory
Drives: Satin White BRZ Limited
This is another theory that I have as well. Thanks.
shattered_memory is offline   Reply With Quote
Old 05-16-2014, 10:26 PM   #27
Kostamojen
Put the FRS rear springs on the BRZ. Thats what I did for awhile and loved it.
Combine that with front camber bolts and a slightly stiffer front swaybar and it drove perfect.
Steering Wheel trim part number djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 2 07-04-2013 12:20 PM
How's the shifting of MT compared to other cars Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 25 06-07-2012 10:20 AM
Toyota 86 Compared to Original AE86 crunchysmooth Scion FR-S / Toyota 86 GT86 General Forum 6 11-30-2011 03:30 PM
