#1639 |
in orbe terrum non visi
Drives: violent
e85, or not? base stage 1 on e85 could get you a low 12, high 11 on slicks.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#1640 |
On our twins, I think at least half of getting a good 1/4 mile time depends on how hard you're willing to launch the car.
#1641 |
#1642 |
#1643 |
NASA SpecE30 Racer
I assumed 93 octane. He is right you can push the GT2871R to over 400 whp and do 12s no problem on E85.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#1644 |
I ran 12.2 with my base kit
The Frozen North
#1645 |
Radiator and shroud
Is it necessary for no track use to run a fbm radiator and shroud in Texas?
Sorry if it's been asked but I couldn't find
#1646 |
Drives: 2013 Subaru BRZ-S
Hey guys I need your help! my car doesn't seem to be creating any boost. I have looked and made sure my boost side piping is nice and tight. I can hear the turbo spin but my car doesn't want to go. Feels stock if not worse when at high rpms. my AFR gauge shows low numbers (9-10) when full on throttle. please help!
#1647 |
Drives: Pegasus GTS86
Are you running a boost gauge? If not you should. Have you done a leak down test? If not, you should.
#1648 |
As I would love to say I am, my AEM wideband failsafe gauge came with a t-line and hose that is way too small to connect to my larger vacuum line unfortunately. \I just installed the gauge today. Ill have to figure something out about an adaptor. If you could go into further detail about a leak down test?
#1649 | |
When my car did this it was one of the intercooler pipes had come loose.
#1650 |
thanks man, ill take another look at the piping!
#1651 |
DADA
Drives: 2013
[ame="http://www.youtube.com/watch?v=GlIhIWALyFA"]VEX Performance FRS - YouTube[/ame]
#1652 |
Hi. The leak test is quite straight forward. I just got a piece of plumbing pipe that was the same size as the connection to the airbox. (I don't have a FBM kit so you would need to figure out the best place to make the connection).
The pipe was capped off and a tyre valve was inserted into the cap. I then connected and air compressor which supplied a little more pressure than the amount of boost you anticipate making. Any leaks will become very apparent. Any small leaks can be found using a spray bottle with water and detergent to make bubbles. Mechanics who deal with this sort of stuff would probably already have something made up. It is definitely a worthwhile exercise for any new installations even for those people who don't have problems (or realise it yet) Good luck mate. |
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
