#827 | |
AutoX Nut
Drives: 2020 Toyota Supra
It makes me feel a little better that your STI saw some knock on course when road logs looked fine. I'm kind of hoping that the abruptness of AutoX just messes with the knock sensor and probably everyone has the same problem. |
#828 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
On days in the 70Fs, I've seen 220F+ at autocross. Highway temps are in the low 200Fs. I'm afraid to see what my track temps in Florida Summer are, haven't tracked in a while.
Does it really not pull timing for oil temp? Car just feels sluggish after hard runs on a hot day. Maybe it's mental.
#829 | |
AutoX Nut
Even if there isn't automatic timing retardation for oil temps, high ambient temps and a hot engine will still contribute to high intake temps. Those high intake temps will pull timing, so it's highly possible you're noticing that and are not mental.
#830 |
Drives: '87 Corolla GTS, '13 FR-S 6MT
To our fellow rules experts,
Now that the TRD steering wheel is available in the US via release series 1.0, can we swap it into our non release series FRS and remain STX legal? |
#831 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
So, after installing the Bilstein B8 shocks with RCE Tarmac springs, I've decided that reinforcing the drivetrain is my next step. Other than Whiteline, are there any other STX legal bushings that I should look at? Also, any suggestions for motor and tranny mounts that follow the weight rules for mounts? So far from what I have seen A) Whiteline seems to be the only company I have seen that offers bushings without additional metal and B) I haven't seen any weights listed for engine and transmission mounts... and for that matter, I am not sure how much the oem mounts weigh either... Thanks in advance!
#832 |
Drives: 2013 WRB BRZ
I would like to know this too.
Also is it important to add suspension bushings first before the motor/tranny bushings? If so which are most important (maybe subframe inserts first)? |
#833 | |
Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
2003 Honda S2000, SCCA Club Racing T3
2013 Subaru BRZ Limited, SCCA Solo II STX 2008 Honda S2000 CR, SCCA Solo II STR ![]() |
#834 |
Anorexic
Not necessarily. But if you upgrade your trans mount, I recommend upgrading your motor mounts at the same time to divert the vibrations to the frame (instead of the motor). Subframe and steering rack bushings are great!
#835 | |
Drives: BMW 135i, soon to BRZ
What you may end up seeing is people doing package converts, but it's thorough as hell (and eligible for all classes). Also, series 1.0 didn't exist with a 2013 model, so no 2013's are eligible to package convert. IF the series 1.0 releases as a 2014 model, then 2014's can package convert. And then it's still scion only, no Subarus. If it's a 2015 release, and for some reason you'd buy a 2015 FR-S, but not the Series 1.0, but then want to full package convert? Sounds pretty masochistic. Its a steering wheel though, there's not really anything wrong with the twins steering wheel. Try driving an 325 e36 before complaining about steering wheels
#836 |
Dodging cones
The twins have the nicest OEM wheel I've held. NO EFFING BUTTONS!
The new WRX wheel would be perfect with an option for no buttons
#837 |
So elite I'm 1338
Drives: WRB Subaru BRZ
#838 |
#839 |
Anorexic
I forgot about those. Yeah, I believe those are legal.
FYI - I know a lot of STX drivers rocking the Cusco solid mounts, but FT86SpeedFactory confirmed they have slightly more metal content than OEM.
#840 |
Serial Cone Killer
I thought the allowance for motor mounts specifically said material doesn't matter, they just can't weight less than OEM?
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
