Old 05-10-2014, 04:16 AM   #435
CSG Mike
CSG Mike's Avatar
Originally Posted by *LongFella View Post
Any more details you can provide? How? Where? Cost?
Bug me on Monday to check for you
Old 05-10-2014, 01:10 PM   #436
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
You know I will!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 05-10-2014, 05:58 PM   #437
Howardwei
Rotrex oil cooler bottle
Hi,
Does anyone know how to remove the bottle of the rotrex oil reservoir without leaking it everywhere? I can only think of sucking the bottle dry then remove since the system contain more than the bottle could hold and will have some remaining inside the line.
Howardwei is offline   Reply With Quote
Old 05-11-2014, 04:04 AM   #438
CSG Mike
CSG Mike's Avatar
Originally Posted by Howardwei View Post
Hi,
Remove the top hoze, take off the reservoir, put it in a lower position than the rest of the sytem upside down, let the system drain.
Basically you're turning it into a gravity pump.
Old 05-12-2014, 12:05 AM   #439
4032pauln
Drives: lexus
Any updates on the smaller pulley??
4032pauln is offline   Reply With Quote
The Following 6 Users Say Thank You to 4032pauln For This Useful Post:
*LongFella (05-12-2014), dp1 (05-12-2014), jflogerzi (05-13-2014), sdlynx (05-12-2014), sklimo (05-12-2014), spitz (05-12-2014)
Old 05-14-2014, 12:41 AM   #440
bacon_cheese_beer
bacon_cheese_beer's Avatar
Drives: Fr-S
is the oil reservoir designed to leak excess oil of its overfilled, i seem to be leaking oil from the reservoir after driving for 5 minutes, i topped it off prior and now the oil level is at the 'max' line. thanks in advance
"mr.Balloon hands, no way, get real..."
bacon_cheese_beer is offline   Reply With Quote
Old 05-14-2014, 01:12 AM   #441
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I have the KW kit, but same Rotrex blower and reservoir, and am experiencing the same thing. I have siphoned out some SC coolant/oil little by little to the point where I'm right at the minimum level after the car has sat off for a few hours. The Rotrex instructions says to read the coolant level while running the engine between 2k & 3k RPM (iirc) and from what I can tell my level is at about right (half way between min and max) there. Still, I get some leakage from the top of the can occasionally. I think the coolant isn't getting enough cooling in stop & go traffic with it being behind the IC and therefore is steaming up into the reservoir top - but that is just my wild guess. Not sure how many others are experiencing this.
mit_peid is offline   Reply With Quote
Old 05-14-2014, 02:51 AM   #442
CSG Mike
CSG Mike's Avatar
"full" is really about just 1 inch from the bottom of the dipstick, for clarification.
The fluid shouldn't be overflowing at all.
Old 05-14-2014, 04:35 AM   #443
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Ppl always wanting more power.
Are y'all truly revving the crap put of your SC'd cars in every gear and needing more already?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following User Says Thank You to ultra For This Useful Post:
CSG Mike (05-14-2014)
Old 05-14-2014, 09:21 AM   #444
dp1
driving smoother faster
Drives: Sold
Jackson Racing Supercharger Owners Thread
I would like to get a little wider power band with JR SC on AT. P&L 4-1 header and cat + P&L overpipe + P&L front pipe and cat + Perrin 2.5" resonated + dyno tune got rid of the torque dip and work beautifully on power but power surge comes at around 5.5k rpm and I'd love to see it kick in around 4 - 4.5k rpm, especially with taller gears on AT. Hope a slightly smaller pulley would help with this.
Update 7/14: I no longer wish for a smaller pulley. Went to Mike at moto-east for the first time to try a different tune - completely transformed the car. More than enough power for my (street and track) needs and excellent power band.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
CxG (04-03-2018)
Old 05-14-2014, 09:45 AM   #445
sklimo
Honestly I just want to break 300whp on 93 octane. Need the pulley for that
Old 05-14-2014, 11:35 PM   #446
Venator
Venator's Avatar
Drives: Asphalt FR-S
So I will be getting this SC in the coming months and have a problem.... Do I get a clutch or an exhaust? Any advocates out there for either direction?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 05-14-2014, 11:48 PM   #447
*LongFella
*LongFella's Avatar
Which kit? CARB Tune or Do-it-yourself tune kit?
I'm on the stock clutch with the CARB Tune Kit, which I believe is a very conservative tune and I have NO clutch problems.
Being in PA you won't need a CARB tune kit. So I would spend my money on a damn good tune and an exhaust. I doubt you'll need a clutch...
@sklimo chime in my friend. You've got the beast! I'm still on the CARB Tune. Me need MOORREE POWER!
Old 05-15-2014, 12:13 AM   #448
Venator
Venator's Avatar
Yeah I was going to get the tiy and have it tuned, I was worried about slippage on the stock clutch
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
