#1163 |
There are most definitely DOT legal 4 point harnesses, which have a failure point stitched in which allows you to slide down in the seat in the case of a rollover.
http://www.schrothracing.com/tuning/rallye/rallye-4 They're the only multi point harnesses any organizing body worth tracking with will allow without a cage as well. If they allow non DOT multi point harnesses without a cage, I would also see what other bad things they let slide.
#1164 | |
Drives: FR-S Whiteout
| The Following User Says Thank You to solidONE For This Useful Post: | SirBrass (05-14-2014) |
#1165 | |
A roll bar which is completely aft of you and having four points of attachment to the car will offer you protection against the roof collapsing into where your head is with race seats and harnesses. This won't be as good as a six+ point cage with bars along the 'A' pillar (halo, main hoop or left/right type) but still enough to make race seats and harnesses OK in a rollover. This is assuming proper installation, etc. of the roll protection. Realistically a properly installed roll bar will offer you much better protection from roof collapse than a eight cusco cage bolted to plain sheet metal without proper backing plates etc. See this for an example: http://www.topspeed.com/cars/car-new...l-ar80908.html (best link I could find)
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#1166 | |
5 point minimum. -mike |
#1167 | |
-mike |
| The Following User Says Thank You to AZP Installs For This Useful Post: | solidONE (05-15-2014) |
#1168 | |
-mike |
#1169 | |
5 or 6 point NEED a cage, my point was that if anyone allows you on a track with a 5 or 6 point (or even a 4 point without the break away stitching) without a proper (ie teched and passed, not just there for show) cage then you probably don't want to be on the track with them. The flip side is typically true too, that if you have a cage then you NEED 5 or 6 point harnesses. What would you say if someone showed up with DOT legal 4 point belts in a car without a cage? It's safer than stock 3 points, and road legal. What about just the stock 3 points since you say 5 point minimum?
#1170 | |
I would still not allow a 4 point harness no matter the dot legal or not. As for cages they it's follow the NASA ccr so the show cages wouldn't be legal either. As Mike said if you have harnesses you should have a cage, just my feelings on it from years of tracking, officiating, and being in and around race cars and racers. Your question on 3 point I would only allow it in a "stock" interiored car. As I said we follow the NASA ccr at a minimum. Mike |
| The Following User Says Thank You to AZP Installs For This Useful Post: | CSG Mike (05-15-2014) |
#1171 |
Pissin off regressives
Drives: They have engines.
My apologies if it has been asked before, but I had to stop reading after 28 pages.
Do you recommend bracing? (Strut, rear, under) If so, which ones? If you recommend switching bushings to urethane or any other, which ones will go with? I'm not talking brands as much as which ones specifically since there are so many out there including the seat ones (GTSPEC Front Seat Rail Support) which look silly to me. |
#1172 | |
I understand not wanting 4 point belts with a cage, but not allowing a legal 4 point belt in a non caged car seems strange to me.
| The Following User Says Thank You to wparsons For This Useful Post: | SirBrass (05-15-2014) |
#1173 | |
Trust me, I'm the Doctor
Take for example the schroth quick-fit, rallye 3 & 4, rally cross, and auto-control II.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| The Following User Says Thank You to SirBrass For This Useful Post: | kavanagh (05-15-2014) |
#1174 |
Fat on Corn Syrup
I'm not sure how long these harnesses have been out, but they are street legal, and FIA homologized. I understand and appreciate your experience @AZP Installs but would you consider these harnesses unsafe if combined with a harness bar such as this one from Cipher Auto in a car without a cage?
The harnesses have the anti submarine feature sewn into the inboard shoulder strap, which is why I am curious to know your opinion on these without a full cage. I agree that any 4, 5, or 6 point harness that does not allow for the body to flex in the event of a rollover is bad without a cage, but have you seen these particular ones before? The harness bar bolts to the stock shoulder belt point and also the rear seat lap belt outboard bolts. Sorry if I'm beating a dead horse, but my background in physics and mechanical engineering suggests this setup would be safe. What I lack, and look for in this forum, is practical on-track experience. ![]() Feel free to tell me to shut up and get over it - stock interior until full-racecar if that has to be.
#1175 | |
Fat on Corn Syrup
Are you experiencing snap-oversteer? Do you want to? are you autocrossing, or HPDE, and also are you on a short/slow/technical track, or a fast/long/curvy one? Most everyone here suggests driving the car stock, until you identify that your driving ability has surpassed some particular part of the car. Then by understanding what happens to you on track, they can make suggestions to improve the car.
| The Following User Says Thank You to kavanagh For This Useful Post: | akuhei (05-15-2014) |
#1176 |
Drives: First SWP BRZ-L
How long will my stockers last on the track? I've got 6k miles on the car now, tires look relatively un-worn. Three car control clinics and an autocross day on them.
First HPDE of my life tomorrow. Excited, nervous, and curious. Can I run my stockers all summer, or will they be junk after the first day? Planning on 3 or 4 HPDEs this summer. 4 x 25 minute sessions. Stock alignment.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
