Old 05-14-2014, 06:40 PM   #2255
kberkel
kberkel's Avatar
Originally Posted by R L Newb View Post
I probably should have re-read instead of going off my fuzzy memory of some magazine article on contact patches. you're right, it was based on overall diameter not rim diameter.
There are some interesting notes on contact patch when you're comparing stock tire width vs. race tire width and pressure/sidewall differences. http://www.carbibles.com/tyre_bible_pg3.html
They made a good point on the whole nitrogen thing. I'll read through it all later
kberkel is offline   Reply With Quote
Old 05-14-2014, 08:00 PM   #2256
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by Sccabrz192 View Post
You are interpreting it wrong, TIRE circumference, not WHEEL circumference coupled with tire pressure and corner weight makes the difference in contact patch.
That R&T article is junk. Area=corner weight/PSI is BAD approximation.
Wheel dimensions matter, but mostly the width. After that, sidewall stiffness matters a lot more than whether those are 17" or 18".
Here, guys, play with a contact patch calculator based on a fairly decent tire model.
Old 05-14-2014, 08:01 PM   #2257
JDogg
JDogg's Avatar
Drives: 2013 Black Scion FR-S
Anyone going to the xceedspeed BBQ this Sunday?
JDogg is offline   Reply With Quote
Old 05-14-2014, 08:05 PM   #2258
T_Scott
T_Scott's Avatar
Drives: 2013 Raven FR-S
I would like to go, just nobody to go with.
On a side note, does anyone have any lowering springs they would be willing to let go of? I don't like the stock monster truck status of my car currently lol.
Three pedals, six gears, and nothing but time.
T_Scott is offline   Reply With Quote
Old 05-14-2014, 08:16 PM   #2259
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
Drove from Farmington into Downtown Detroit this morning around 9:30 with a WRB BRZ. Glassman plate frame but no plate. Temp reg in the window. If you see this, congrats on the new BRZ!
Sevs753 is offline   Reply With Quote
Old 05-14-2014, 08:21 PM   #2260
JDogg
JDogg's Avatar
Where you from? I'm trying to find or make a caravan to go with from the Northville area.
Old 05-14-2014, 08:28 PM   #2261
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
I'll be going. Seen a cute gal in a WRB BRZ on Beck road yesterday.
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 05-14-2014, 08:39 PM   #2262
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I wasn't trying to say it was a good / accurate article either but the ones they mention do play the bigger roles, beyond that it's just painting monumentally broad strokes to make it seem like he knows more than R&T readers.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 05-14-2014, 08:49 PM   #2263
T_Scott
T_Scott's Avatar
I'm located in Midland
Old 05-14-2014, 08:56 PM   #2264
R L Newb
Drives: LR BRZ Ltd, 06 STi
The point in the articles, one which I never thought about before reading, is width in a tire doesn't always mean more grip or more contact patch.
R L Newb is offline   Reply With Quote
Old 05-15-2014, 10:23 AM   #2265
markitect
Drives: Scion FRS
My experience on wheel size:
The contact patch can be the same regardless of diameter, if you have the same tread width, the pressure you will want will potentially be different..
What you get with a smaller diameter wheel is a bigger sidewall. This does a few things:
1. A bigger sidewall increases the amount of air you put in. This makes adjustment easier(1 psi is a smaller percentage of the total air), but also makes for greater expansion as you tire heats up(you have more air so as it heats up it expands more).
My preference is to have more air volume, you can then make small air adjustments throughout the day, I do this after each run based on marking the tires, although going off tire temp across the tire is more better if you have the equipment. The exact pressures you want depend on if you are doing autocross or a track day, and many other factors.
2. A bigger sidewall also make the tire more flexible. The flexibility will decrease feel, and make it feel slightly less responsive to steering input, etc. It is not affecting traction, just the initial feel as the tire deforms(until you deform it so much you go on the sidewall). This has the side affect of heating up your tires more quickly as well(more stretch=more heat). This to me comes down to personal preference.
3. You will go through tires, and smaller diameter, higher profile are generally cheaper.
I actually got some cheap cheap 16" wheels this year for the track.
markitect is offline   Reply With Quote
Old 05-16-2014, 11:25 AM   #2266
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
Hello there!
That was me. Just got the car on Monday. Glad to be a new entrant in the BRZ group.
NJ10 is offline   Reply With Quote
The Following 4 Users Say Thank You to NJ10 For This Useful Post:
Karigan (05-16-2014), Kayysonie (05-16-2014), OAKOS Automotive (05-19-2014), Sevs753 (05-16-2014)
Old 05-16-2014, 01:01 PM   #2267
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Originally Posted by NJ10 View Post
Hello there!
Welcome NJ10! I'm a big fan of WRB BRZ's. Nice to have you on board.
Hopefully you can attend one of our get-togethers if we can get our act together and organize something one of these days.
Any plans for modifications?
eikond is offline   Reply With Quote
The Following User Says Thank You to eikond For This Useful Post:
Old 05-16-2014, 01:04 PM   #2268
JDogg
JDogg's Avatar
I'm joining up with a caravan leaving from John R and 12 Mile around 8:30am if you're interested.
NorCal (Bay Area) OFF-TOPIC Chat Thread BlaineWasHere Northern California 12912 08-18-2024 04:02 AM
NorCal (Bay Area) DRIVE Chat Thread MyRx Northern California 5559 07-23-2023 02:11 AM
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
Tri-State Chat Thread Jayde NY / NJ / CT / PA 182 05-22-2014 11:14 AM
