Old 05-08-2014, 12:30 PM   #1345
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Originally Posted by draggin_az View Post
i guess the real question is......if 300ish isnt enough hp, is 500hp going to be?
lol true man. It all depends with what your goals are but i dont think you would need to jump all the way to a v7 to make 500 hp with a vortech kit.
If I cant find a way to upgrade my impeller Im probably going to find a bastard v3-sc on one of the mustang forums and try to swap over the volute and impeller.
marcoaferrer is offline   Reply With Quote
Old 05-08-2014, 12:47 PM   #1346
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
i set a goal of supercharging it and i did. then i left for deployment and found out about toni's tune blowing up an engine so went with a local tuner once i got back.
he upgraded the fuel pump and unleashed a little bit more power then it got me thinking, what else can it do?
so i set another goal of 300hp. got the 2.87 pulley, bigger injectors, a retune and i believe we're close. we are currently chasing a cel before throwing her on the rollers do see what it'll lay down with a 93 tune. my flex fuel kit is on the way so if the 93 numbers are favorable, that goal will be 350.......but will it be enough lol.
it seems like im happy with it for a little bit of time but before i know it im screaming for more power.
so it brings me back to my orginal quesiton, will 500 be enough lol.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-12-2014, 06:41 PM   #1347
FR-S Matt
@Brian@Vortech Can you confirm if the intercooler piping clears the Spec D headlights on the passenger side? I read a report about it not clearing (could have possibly been an excuse to not install the headlights in the demo video) but I wanted to confirm to see if maybe you heard any reports about the passenger side piping not clearing those headlights.
I've been eyeballing the Vortech for a long time and my HP goals top out at 300 and this supercharger seems to be the best one reliability wise and cooling wise.
Old 05-12-2014, 06:58 PM   #1348
marcoaferrer
Clear perfectly fine on mine
EDIT: sorry I miss read your post. I didnt know you were talking about the spec d lights. my bad
Old 05-14-2014, 09:27 AM   #1349
diirk
diirk's Avatar
Drives: 4Runner
Ran the car this weekend at a track day. Performance was outstanding based onthe number of cars i was able to pass. LOL.
I did find a little bit of oil inside the engine bay as noted by the attached picture. Seems to be coming from the blowoff valve/breather tubing.
Is this common? Is there a suggested fix?
Thanks
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-14-2014, 09:54 AM   #1350
MyRx
MyRx's Avatar
Thanks
Define common? ~20K miles on mine before getting the Radium dual cans and no more oil buildup on that side nor the PCV side. 20k miles a little too late because while I took my time installing the Koyo rad, I decided to take apart the SC's piping and clean up the oil. Define common, because now my breather remains clean, K&N filter remains oil free and Radium's dip sticks are wet to the touch from the oil/moisture that would have otherwise went thru the pipings/air box. Can't tell how much stuff is collecting in the cans yet but they are doing their job. Get catch cans!
The Following User Says Thank You to MyRx For This Useful Post:
diirk (05-14-2014)
Old 05-14-2014, 11:27 AM   #1351
draggin_az
draggin_az's Avatar
so its common for oil to be blown into the air box?
277hp 93 octane
370hp on E-85
Old 05-14-2014, 02:58 PM   #1352
Dezoris
Dezoris's Avatar
The crank case breather hose is routed into the airbox. Blow by if not caught will blow right into the airbox, blow, piping, IC etc.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
diirk (05-15-2014), draggin_az (05-15-2014)
Old 05-14-2014, 07:18 PM   #1353
ekaj
because racecar
ekaj's Avatar
Drives: 2013 BRZ -- SOLD
If you had to rate this kit's maintenance levels on a scale of 1–10, with 1 being "no maintenance needed at all" and 10 meaning "shit's breaking every day," where would it stand?
2013 Subaru BRZ SOLD
ekaj is offline   Reply With Quote
Old 05-14-2014, 07:36 PM   #1354
marcoaferrer
3
The Following 2 Users Say Thank You to marcoaferrer For This Useful Post:
diirk (05-15-2014), ekaj (05-14-2014)
Old 05-15-2014, 08:35 AM   #1355
draggin_az
draggin_az's Avatar
thanks man.
i would a agree with a 3. this thing is easy to maintain. change the oil every 7,500 miles and clean out the air filter from time to time.
277hp 93 octane
370hp on E-85
The Following 2 Users Say Thank You to draggin_az For This Useful Post:
diirk (05-15-2014), ekaj (05-15-2014)
Old 05-15-2014, 09:37 AM   #1356
diirk
diirk's Avatar
Drives: 4Runner
So with that said it sounds like a catch can or separator is in order.
What's the prefered setup for use with the Vortech?
diirk
Old 05-15-2014, 10:16 AM   #1357
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Is there any known reason that that breather line is routed through the intake piping and not just into the manifold. Im already running one catch can on my Pcv side and would rather just t into that one.
bee_are_zee is offline   Reply With Quote
Old 05-15-2014, 11:27 AM   #1358
Foobar
SLO NO MO
Foobar's Avatar
I thought it was to try and have the air filter catch any contaminates from recycling back in?
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
