Old 05-13-2014, 10:37 PM   #1
pghfan19
Drives: honda civic ex
Confusion related to Nigel fog light set up
I ordered the fog light kit with the on/off switch from nigel-jdmparts and i'm confused regarding how to wire them..I was looking at some posts and pictures on here and i'm still confused..
The first pic is the wire harness that I was sent, the second pic is a wire harness that someone else posted on here, i'm confused because mine doesn't have the ground wire and ignition wire near the switch so i'm unsure how they should be wired or if I have the wiring set up correct. I'm a newb so any help is greatly appreciated!
pghfan19 is offline   Reply With Quote
Old 05-13-2014, 10:48 PM   #2
bfsnail
bfsnail's Avatar
Thats odd. I ordered the same kit and got the bottom harness, not the top one.
bfsnail is offline   Reply With Quote
Old 05-13-2014, 10:50 PM   #3
bfsnail
bfsnail's Avatar
Just try putting the two leads onto the battery and a ground, hooking up a light, and seeing if the switch works.
If it does, you will just have to make sure you turn them off every time you get out of the car...
Old 05-14-2014, 12:22 AM   #4
calibrz
Turbo 86
Drives: GT86
i got my on ebay. works just fine
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-14-2014, 12:59 AM   #5
636
636's Avatar
Drives: '23 CWP BRZ
That bottom picture was mine...that's odd that your harness showed up like that..
636 is offline   Reply With Quote
nigel-jdmparts
Fog Light Kit installed (nigel-jdmparts) Noz Cosmetic Modification (Interior/Exterior/Lighting) 7 12-20-2015 09:10 PM
Free Nigel fog light harness chriscross_tnt Exterior Parts (Aero, Lighting, Etc.) 2 10-27-2013 08:31 PM
SPC RLCA Confusion EN2_Squirrel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-28-2013 07:21 PM
FS: Nigel fog light harness Manny4115 Exterior Parts (Aero, Lighting, Etc.) 3 04-09-2013 12:21 AM
Fog light confusion? PurpleTerds Scion FR-S / Toyota 86 GT86 General Forum 5 08-02-2012 11:07 PM
