#57 | |
Drives: 4 Wheels Auto
Second part, Based on the spreadsheet, in order to hit 60 MPH mark on 2nd gear, some conditions need to be met: 1. the tire circumference is indeed based on the ideal value of 24.62" diameter. 2. the tester actually revved it all the way pass 7300 rpm or be hugging 7450 before up-shift. I think this is not the case where insideline test their sample of BRZ. 3. the other tester who can clock faster 0-60 time may also be using the automatic, as seen in the spreadsheet that it can reach 60 MPH sooner at 7000 RPM. |
#58 |
Kuruma Otaku
Too much reliance on math... Section/aspect ratio is an approximation given different companies manufacturing. They have specific measured dia/circ numbers for specific tires and they don't all match the formula numbers.
Because titanium. |
#59 |
Drives: '13 BRZ Lmtd
[QUOTE=Want.FR-S;171844]For the first part, do you have any link or page where it said it is 23.9"? There might be a different standard used in Europe, or the P type wheel (P215/45/R17). I am guessing this might be the case.
The reduced diameter is not from squish. It is from the difference between official tire specifications and the rough number calculated from the wheel diameter plus the nominal aspect ratio times width. The 1906mm rolling circumference is from official ETRTO tire specs. (I don't expect that tire size standards vary between Europe and Japan and the US. From the wikipedia ETRTO entry it just looks like Europe standardized tire sizes first.) Here is a source for ETRTO standard tire circumference: http://www.club80-90syncro.co.uk/Syn...calculator.htm Here is a calculator for circumference including increase in circumference with speed: http://bndtechsource.ucoz.com/index/...alculator/0-20 Here is a Yokohama tire size chart where you see a circumference of 1906mm for the 215/45R17 tires: http://www2.yokohama-online.com/gb/t...php?page=23084 So, until someone posts a better link to tire circumference info, I think the 215/45R17 tire has a 23.9" effective diameter. [Edit] OK, reading Tirerack's explanation maybe the difference is due to "squish": http://www.tirerack.com/tires/tirete...jsp?techid=203 Looking up the Primacy HP, Tirerack doesn't list a revs per mile number. But, they do have one for the Michelin Pilot Sport 3 in a 215/45 R17 size, and the value is 844. This is a 23.9" equivalent rolling diameter so I still think we should use 23.9" for calculating wheel RPM vs speed. Last edited by DSPographer; 04-03-2012 at 04:11 PM. |
#60 | ||
Just check Michelin's website, the Primacy HP 215/45/R17 has 844 rev per mile. with 24.7" as the overall diameter. Convert that using one mile - 1609.344 m, it comes to 1.9068 m per rev. So we should stick the circumference number for calculation purpose. ![]() I would think there is no need to reverse calculate the *effective diameter* as this may confuse people and trying to reason it with deformation or other effect. In fact, if you know the rev number per mile/km, it is easier to calculate the circumference more precisely. Otherwise, how one could explain the difference between 24.7" and 23.9"? Last edited by Want.FR-S; 04-03-2012 at 04:28 PM. |
#61 |
Drives: BRZ, 2011 Outback 3.6R
Revs per mile by Michelinman.com for Primacy HP 215/45/17 is 844.
#62 | |
#63 | ||
Hot Dog
Drives: quicker than arghx7
Deslock's chart's using an approximate 24" rolling diameter are appropriate for the stock 215/45-17.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#64 |
Exact 6MT speeds with 215/45R17 tires
Since I just calculated the exact 6MT gear ratios I can post the exact speed vs RPM for the standard 215/45R17 Tires using the known ETRTO spec of revs per mile for the tires which is 844.4:
RPM- : 1st- | 2nd- | 3rd- | 4th- | 5th- | 6th- ------------------------------------------------------- 1000 : +4.8 | +7.9 | 11.2 | 14.3 | 17.3 | 22.6 1250 : +6.0 | +9.9 | 14.1 | 17.9 | 21.7 | 28.2 1500 : +7.2 | 11.9 | 16.9 | 21.4 | 26.0 | 33.9 1750 : +8.4 | 13.9 | 19.7 | 25.0 | 30.3 | 39.5 2000 : +9.6 | 15.8 | 22.5 | 28.6 | 34.7 | 45.2 2250 : 10.8 | 17.8 | 25.3 | 32.1 | 39.0 | 50.8 2500 : 11.9 | 19.8 | 28.1 | 35.7 | 43.3 | 56.5 2750 : 13.1 | 21.8 | 30.9 | 39.3 | 47.7 | 62.1 3000 : 14.3 | 23.8 | 33.7 | 42.9 | 52.0 | 67.8 3250 : 15.5 | 25.7 | 36.5 | 46.4 | 56.3 | 73.4 3500 : 16.7 | 27.7 | 39.4 | 50.0 | 60.7 | 79.0 3750 : 17.9 | 29.7 | 42.2 | 53.6 | 65.0 | 84.7 4000 : 19.1 | 31.7 | 45.0 | 57.1 | 69.3 | 90.3 4250 : 20.3 | 33.7 | 47.8 | 60.7 | 73.7 | 96.0 4500 : 21.5 | 35.6 | 50.6 | 64.3 | 78.0 | 101.6 4750 : 22.7 | 37.6 | 53.4 | 67.9 | 82.3 | 107.3 5000 : 23.9 | 39.6 | 56.2 | 71.4 | 86.7 | 112.9 5250 : 25.1 | 41.6 | 59.0 | 75.0 | 91.0 | 118.6 5500 : 26.3 | 43.6 | 61.9 | 78.6 | 95.3 | 124.2 5750 : 27.5 | 45.5 | 64.7 | 82.1 | 99.7 | 129.9 6000 : 28.7 | 47.5 | 67.5 | 85.7 | 104.0 | 135.5 6250 : 29.9 | 49.5 | 70.3 | 89.3 | 108.3 | 141.1 6500 : 31.1 | 51.5 | 73.1 | 92.9 | 112.7 | 146.8 6750 : 32.3 | 53.4 | 75.9 | 96.4 | 117.0 | 152.4 7000 : 33.5 | 55.4 | 78.7 | 100.0 | 121.3 | 158.1 7250 : 34.7 | 57.4 | 81.5 | 103.6 | 125.7 | 163.7 7450 : 35.6 | 59.0 | 83.8 | 106.4 | 129.1 | 168.2 |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 01:22 AM |
| Guesses about Gear Ratios and Wheel Torque | Deslock | BRZ First-Gen (2012+) — General Topics | 4 | 12-01-2011 07:15 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 01:28 PM |
| Top gear USA | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 12-09-2010 12:01 AM |
| Toyota FT-86 weight -- take your guesses | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 03-24-2010 07:57 PM |
