Old 05-12-2014, 10:49 PM   #1
fitcious
Trunk opener button
How do you pop open this assembly? I was turning up my dash board lights and I pushed the wheel in. I want to push it back out. Thanks
Attachment 78367
fitcious is offline   Reply With Quote
Old 05-12-2014, 10:51 PM   #2
DailyDriver
DailyDriver's Avatar
Drives: 10-Series FRS
I would just get a flat head screwdriver with a towel on the end. Then wedge it in and pop it. Or get on the floor and look up and see if you can pop the panel from the back
DailyDriver is offline   Reply With Quote
The Following User Says Thank You to DailyDriver For This Useful Post:
fitcious (05-12-2014)
Old 05-12-2014, 11:10 PM   #3
......or maybe just push the wheel back out from the back .....
Old 05-12-2014, 11:12 PM   #4
DailyDriver
Shhhhh
Old 05-12-2014, 11:27 PM   #5
extrashaky
Drives: 2014 BRZ Limited
The shop manual shows it coming off as a single large piece.
Shouldn't be too hard to get to. The lower dash below it comes off with 2 or 3 bolts and the side panel just pops off in your hand. Looks like it's just one screw in the side of the panel once those are out of the way.
If you ever expect to take pieces of your dash off, I would suggest digging deep into your wallet and scrounging up $7 for the Harbor Freight trim tool kit.
They are sharp enough to get under the edges of trim pieces, but soft enough not to gouge anything. They make interior work so much easier. Most HF stores have them in stock.
The Following User Says Thank You to extrashaky For This Useful Post:
Old 05-12-2014, 11:32 PM   #6
s2d4
s2d4's Avatar
DO NOT DO THIS.
Old 05-12-2014, 11:35 PM   #7
fitcious
Thanks all. I think I'll use the screw driver method. Or I'll take it to our service garage to have it looks at. Hopefully no need for a new part.
Old 05-12-2014, 11:41 PM   #8
s2d4
s2d4's Avatar
DO NOT DO THIS.
Pop the plastic trim off between the dash and the door. Take out a couple of screws or just one iirc and that whole piece comes off.
The Following User Says Thank You to s2d4 For This Useful Post:
Old 05-12-2014, 11:51 PM   #9
fitcious
I'm letting the service garage at work tmr handle it. Lol. I'm surprise the quality of this is not as great as I thought
Old 05-13-2014, 12:52 AM   #10
Well, now, fitcious ...... it's just a poor little plastic wheel, that is designed to go "up and down" .... NOT .... "in and out". It will NOT get brighter by pushing in harder on it....
(jest ah funnen wich ya ..... )
fitcious (05-13-2014)
Old 05-13-2014, 12:54 AM   #11
fitcious
Hahah. Yes, I had a good chuckle from this. But really, I literally put a big if pressure on it to go up and it was pushed in!
The Following User Says Thank You to fitcious For This Useful Post:
humfrz (05-13-2014)
Old 05-13-2014, 01:18 AM   #12
hmmmm.......now, exactly what is a "big if pressure" ..... ??
I'm sorry, I know you meant "a bit of pressure"......it's a slow day here in Puyallup ....
Old 05-13-2014, 01:18 AM   #13
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You should take it to the dealer and have them replace the button... sounds like you got a defective one.
Wouldn't take another chance with it since it COULD occur again.
N1rve
Old 05-13-2014, 01:24 AM   #14
fitcious
Yup I plan to bring it to our service garage at work tomorrow.
Trunk remote or button won't pop open? 914_WHITE_FRS Issues | Warranty | Recalls / TSB 6 07-05-2013 10:08 AM
Black Japan’s Season Opener JDMenrique New England 26 04-07-2013 06:20 PM
Trunk button not working Jahdai42 Issues | Warranty | Recalls / TSB 4 02-19-2013 08:03 AM
Alarm w/garage opener? denverizzles Electronics | Audio | NAV | Infotainment 2 12-03-2012 08:31 AM
Garage opener for Canadian BRZ percyng CANADA 8 05-14-2012 09:22 AM
