Old 03-18-2014, 08:33 AM   #155
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Mine didn't even start slipping until 50lb ft more torque, and that's at the tippity top
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-18-2014, 09:18 AM   #156
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by *LongFella View Post
Any recommendations on which Flex Fuel Kit is the most reliable and easy to install?
The Moto-East FF kit has been rock solid for me on track and was pretty easy to install considering the lines and fittings all came pre-assembled, there's an optional plug and play ECU harness, and the wire crimps are very high quality. Also detailed instructions with plenty of pictures made the install a couple hours by myself, taking my time.
Makes sense, but it's a lot harder to remove a flex fuel kit if you want some warranty work done. The other way is simply flashing back to stock and putting 91 in
The Moto-East kit features quick disconnect lines so it's actually pretty easy to remove those. Depressurize the system, pop the lines off with a quick disconnect tool, and you can reconnect the stock line just as easily as you removed it. The fuel line assembly is secured to the brake lines with zip ties and easily goes in and out as one unit. The ECA gauge can be easily zip tied out of sight in the cabin. If you get the plug and play ECU harness then you may be able to just leave that in and flash back to a stock tune file (assuming you've got regular gas in the tank) and proceed to have your warranty work done. Removing all the wiring isn't a huge deal if you'd rather not risk the dealer finding it, but you'll have to cut your wire crimps for the ECA and redo those when you re-install.
The Following User Says Thank You to ATL BRZ For This Useful Post:
*LongFella (03-26-2014)
Old 03-26-2014, 08:45 PM   #157
jailbot
jailbot's Avatar
Drives: 2000 Impreza RS coupe
Any news on the prototype radiator?
jailbot is offline   Reply With Quote
The Following User Says Thank You to jailbot For This Useful Post:
Anthonytpt (05-12-2014)
Old 05-12-2014, 03:02 PM   #158
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Wow. Such quiet. Much eager. Very anticipate.
Anthonytpt is offline   Reply With Quote
The Following User Says Thank You to Anthonytpt For This Useful Post:
racecaresuaceb (07-07-2014)
Old 05-12-2014, 10:06 PM   #159
CSG Mike
CSG Mike's Avatar
Big plans
Old 05-13-2014, 10:50 AM   #160
Anthonytpt
Anthonytpt's Avatar
I hope CSG is preparing to unveil its doge livery. Much win.
Old 06-04-2014, 09:46 PM   #161
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Big plans
I was wondering though - what kind of diff fluid are you guys using? Still stock?
I am unsure if its entirely necessary to change out the diff factory fill. I've seen nasty pics of the drain plug, but do you guys use something other than OEM?
unsurety is offline   Reply With Quote
Old 06-04-2014, 09:54 PM   #162
CSG Mike
CSG Mike's Avatar
We use Motul Gear300LS
Metal paste on the magnetic drain plug is normal.
unsurety (06-04-2014)
Old 06-05-2014, 02:17 PM   #163
Dezoris
Dezoris's Avatar
Why are you running the LS in a Torsen without clutch packs?
I meant to ask before.
Old 06-05-2014, 03:04 PM   #164
ATL BRZ
ATL BRZ's Avatar
I believe their car is running a Cusco differential.
Old 06-05-2014, 03:19 PM   #165
Dezoris
Dezoris's Avatar
Well they are fancy pants!
Old 06-06-2014, 01:14 AM   #166
CSG Mike
CSG Mike's Avatar
The fluid feels slightly different.... it's hard to quantify.
Old 08-11-2014, 09:08 PM   #167
CSG Mike
CSG Mike's Avatar
So, we have the OS Giken LSD in the car, and it's obviously working, but I want to really be pushing it to test conclusively.
Just waiting for the latest revalve on our SRCs to get back to us now...
Old 08-12-2014, 12:38 AM   #168
B L U E S L A T E
Drives: BMW E84
I just sold my PS4 to someone claims to be working/affiliated with OSG... He even said to ask him if I needed their LSD. I'd have said yes, but it wasn't free. LOL
B L U E S L A T E is offline   Reply With Quote
CounterSpace Garage (CSG) juliog User/Vendor/Sponsor Reviews, Feedback, Comments 11 10-21-2013 04:08 PM
Track day giveaway by CounterSpace Garage CSG Mike Southern California 43 04-19-2013 11:12 AM
CounterSpace Garage forwallblakmail User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-12-2013 04:31 PM
CounterSpace Garage BRZ 2:00 lap at Buttonwillow 13 CW CounterSpace Garage Tracking / Autocross / HPDE / Drifting 11 03-07-2013 10:07 PM
CounterSpace Garage A++++ Asphalt~86 User/Vendor/Sponsor Reviews, Feedback, Comments 2 01-29-2013 01:18 AM
