#29 |
Drives:
Uhmmm why not use an impact wrench?
Sent from my iPad using Tapatalk |
#30 |
That Guy
Drives: 2013 asphalt FRS MT
#31 | |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I suggest pulling the fuel injector relay as stated earlier and blipping the starter. That's what I had to do on an old Outback I had. |
#32 | |
Drives: Subaru BRZ (6027xx) Premium Manual
Is that even possible with a push-to-start button? I've never tried but I would assume the starter would keep cranking until the engine starts, which would be... never in this case?
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
#33 |
Drives: JRSC'd Asphalt FR-S
Have your engine kinda warm and it'll help break it loose super easy.
#34 |
Drives: Ultramarine FR-S (MT)
I had a friend stomp on the brake pedal (in addition to the ebrake), very easy install.
| The Following User Says Thank You to Books For This Useful Post: | Fly Guy (05-16-2014) |
#35 | |
Me and a bunch of other guys on here should feel stupid for not thinking of that first. ![]() Anyway, I asked the most responsible person in my vicinity (my 8 year old son) to step on the brakes and it did the trick! Also I had to take out the crankshaft pulley spacer because I'd fudged up (put the pulley the wrong way, spacer came out with the pulley after that) and feared the worst after reading some horror stories but with the help of a mirror, it only took me 5 minutes to align it properly. Once again, kudos to the twins community for helping a noob mechanic in his less-than-finest hour.
#36 |
Drives: 2014 Scion FRS
you learn something new everyday dont feel bad ive done alot of stupid things when working on my cars in the past glad people in the forums helped you out I just ordered my own perrin crank pulley so I may get into the same situation
| The Following User Says Thank You to Panda Mao For This Useful Post: | tbertran (05-14-2014) |
#37 |
I just welded two bolts to a steel bar to hold the pulley in place while hitting it with a breaker bar, easy fix and it works every time!
| Tags |
| crank pulley, installation |
| What is best crank pulley? | Mixlplix | Engine, Exhaust, Transmission | 49 | 10-28-2017 05:44 PM |
| Perrin crank pulley / Beatrush alternator pulley | Krimlin | Engine, Exhaust, Bolt-Ons | 7 | 08-26-2013 10:12 AM |
| Steering Loosen up after break-in? | Accathla | BRZ First-Gen (2012+) — General Topics | 16 | 11-22-2012 11:45 AM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 07:45 PM |
