Old 04-03-2012, 12:41 PM   #57
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
I was thinking the cupholders would make a good place to anchor one if you didn't want to hinge it. Then you could just toss it on a seat when you want to get to the cup holders.
It looks to me from the photos on the frs site that the cup holders in the frs center console area are removable to begin with, or adjustable at the very least as marinjim mentioned.
This being the case, it shouldn't be too hard to get a low armrest with a molded bottom to slide right in where the cup holder insert is, or something along those lines. Granted then you'd have to find a place to temporarily place your cup holder insert, so eh.
Seems like whatever is done, it should end up being relatively cheap or rather, 'affordable'[TM].
Spd229 is offline   Reply With Quote
Old 04-03-2012, 01:04 PM   #58
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I'd personally like one since I plan on using it as a DD, so it would be nice to rest my arm somewhere while on the freeway. I wonder if Subaru will have it as an option later. The newer WRX's have a very nice sliding armrest/center console storage lid that can slide forward so you can rest your arm while cruising or slide back to give you clearance so your elbow doesn't bump it while working the shifter. They were offered as an option in the 2010's but I guess they are standard now.
Old 04-03-2012, 01:09 PM   #59
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Originally Posted by marinjim View Post
My feelings exactly. I don't think the cupholders are anchored but are removable and have a couple of positions where they lock to prevent front to back movement (based on photos).
Us old guys need to stick together although I'll make you feel young as I'm 61 .
Yeah, being 63 I like a place to rest my arm...and there are cupholders in the doors.
russv is offline   Reply With Quote
Old 04-03-2012, 01:42 PM   #60
I was thinking more using the cup holders (or one of them) as the female portion of a connector mated to the bottom of the arm rest insert. Then, if you want the cupholders you remove the armrest.
Something along those lines.
