Old 05-12-2014, 01:38 PM   #1135
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by dp1 View Post
I wanted to give it a wide margin to see if anything would go wrong after the big build and to check out the dynamics safely.
That's very smart. Anything come up with temperatures, leaks or any other glitches, or was it all good?
dradernh is offline   Reply With Quote
Old 05-12-2014, 03:47 PM   #1136
kavanagh
Fat on Corn Syrup
Originally Posted by DarkSunrise View Post
Mind sharing your camber specs and tire pressures? Those sidewalls look like they're in relatively good shape compared to mine.
We're on stock suspension with no camber adjustments (yet) running 17x8 rims with PSS 225/45 and running between 37 and 39 hot pressures. We're running on a pretty short/technical track and not a long/fast one. Wild Horse Pass East and West are both about 1.2 miles and see a top speed around 87. Very fun for learning technical aspects of driving. I recently learned that drivers from around the country come to WHP West for practice since it's so technical.
Here is my 4/28 run at WGI, driving relatively slow since it was my first time with FR-S on track to get a feel for it. JR SC, Sprint BBK, Ohlins R&T, Toyo Proxes RA1 235/40R17, -3.4f -2.7r camber, 2 deg caster added, no toe, JR oil cooler, P&L 4-1 + Perrin 2.5" resonated, dyno tune by JR. Tires looked like new when I got off - could go 10+ mph faster in most corners...going to NJMP this weekend with NASA, and back at WGI on 7/8-7/9 with SCDA.
@Prime Motoring did a great job with the build.
So awesome to see another Automagic on the track!!! I really think people are starting to recognize the beauty of this particular transmission, and I love seeing it used! Have you been following any of the developments from SSP in this thread? http://www.ft86club.com/forums/showthread.php?t=51851
We're interested in seeing results of the Stage I valve body upgrade soon.
Old 05-12-2014, 03:57 PM   #1137
DarkSunrise
DarkSunrise's Avatar
Awesome, thanks. That's actually very close to what I'm running (215 Sumitomo HTR ZIII on 17x8 wheels, stock suspension, stock camber, 37 psi hot) on a short technical course. I'm seeing a lot of outer-shoulder wear on my front tires. I'm guessing my Sumitomos have much softer sidewalls than your PSS. I just bought some whiteline front camber bolts so hopefully that'll help.
2022 BRZ Build
2013 FR-S Build
Old 05-12-2014, 04:24 PM   #1138
dp1
driving smoother faster
Drives: Sold
The only glitch was two small trans fluid leaks at two different SSP trans cooler fittings near pump and rad. They were not mounted in recommended locations because of JR oil cooler and JR SC cooler, so don't know if it was due to faulty fittings or mounting in non-standard location, with increased vibration. Had entire SSP trans cooler system taken off the car few days ago, and put in a stock pan with new seal. Probably would have been fine in stock mounting location...would be helpful for others to get feedback from those who installed it and tracked it. Shop contacted SSP but they wouldn't take it back, even with restocking fee. Was fine after shop near the track re-tightened everything up. Will put it up for sale soon. Everything else worked like a charm, love the setup.
dp1 is offline   Reply With Quote
Old 05-12-2014, 04:47 PM   #1139
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Update on temps.
A was inadvertently left on during my morning session.
Afternoon coolant stayed at 198 and oil peaked at 270. Oil cooler going in before Njmp next weekend.
Look forward to seeing you guys out there.
Mike
AZP Installs is offline   Reply With Quote
Old 05-12-2014, 05:22 PM   #1140
kavanagh
Fat on Corn Syrup
I'm sure the bolts will help - they're on our short list as well. Maybe another pound or two of pressure? Worth trying since it's free.
Old 05-12-2014, 05:22 PM   #1141
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Thongpocket View Post
After running Rd ATL I feel I may need to revise my wheel and tire combo. My 17x8 rpf1's and RE11's did good. But I feel I need a bigger tire in the back. My power level is low but I just couldn't get the car to rotate as much as I would like with the throttle. Specifically on turns 1, 5 and 7. I still need a lot more experience but I also felt that my -2F and -3R camber worked well out there. I was running a starting pressure of 31psi but went down to 29 psi and got much better grip. My first lap was 2:06 and my final and best was a 1:56. Attachment 78272Attachment 78273
Sent from my XT1080 using Tapatalk
I'm willing to bet that your -3 rear camber vs your -2 front camber has a lot to say about why you were having trouble making it rotate under throttle. Try less rear camber and more front camber.
Old 05-12-2014, 05:51 PM   #1142
kavanagh
Fat on Corn Syrup
A question for Mike and anyone else who wants to chime in...
Racing harness suggestions?
I've read through these forums ad nauseum (CG Lock, don't-run-a-harness-without-a-cage, 4 vs 5 point, anti-submarining, etc...), but what are you guys actually using? We'd like to keep the stock seats for daily comfort and don't care about access to the rear seats (the "shelf"). We don't mind wearing the harnesses on a daily basis. Looking for something safe that will keep us planted in the seat more firmly. So far we've been using the 'pull it fast so the seat belt locks' method, which sort of sucks.
Old 05-12-2014, 05:58 PM   #1143
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Well my stock pads lasted the first day but likely need to be replaced now! 160km total of track time with no power mods but lots of suspension wheel and tires mods and 5x20 minute sessions and they just barely began to fade on the last 2 laps of my last session.
7300km on the car now and its time for brakes
BRZZZZZZZZZZ is offline   Reply With Quote
Old 05-12-2014, 06:01 PM   #1144
gramicci101
Off Topic
The problem with racing harnesses and stock seats is that the stock seats and stock restraints are designed to give in the event of a collision and harnesses are not. So you'll be harnessed in all tight and secure, but your seat will be bending and folding without you. This would be even worse in a rollover that violated the structural integrity of the roof.
Alternately, you could swap in a fixed-back seat for track days and run harnesses with that. Which is fine, unless you have another rollover and the roof is crushed, because you'll be strapped in tight, bolt upright and not able to flex, while the roof comes down around your head.
So let's get a rollbar and keep the roof where it's supposed to be, right? You could. And swap in a racing bucket and harnesses for track days, but keep the OEM stuff for DD. Now what happens if some drunken idiot smashes you at a red light? You're riding in your OEM seat because you're not on the track, and the OEM seat gives in a collision. Your head gets intimately acquainted with the rollbar, and you're not wearing a helmet because you're not on the track. Rollbar padding only goes so far.
That's why they all recommend sticking with OEM restraints unless you're going 100% racecar.
Old 05-12-2014, 07:21 PM   #1145
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Check out my build thread: http://www.ft86club.com/forums/showt...96#post1677996
I'm running Schroth Profi II ASM 4-point harnesses with a street legal push release. The shoulder harnesses will be wrapped around my Agency Power bolt-in harness bar and will allow a HANS to be used. The harnesses are safe for use with stock seats with the anti-submarining belt and both sanctioning bodies I track my BRZ with (PCA and Hooked on Driving) allow it in their rule books. It's not ideal but it's definitely safer than the stock three points. The folks at Discovery Parts and HMS Motorsports agree.
Old 05-12-2014, 09:24 PM   #1146
CSG Mike
CSG Mike's Avatar
I wouldn't recommend a harness, unless you plan on caging the car, and getting buckets and a HANS type device. This effectively eliminates the car from street duty.
We use an OEM interior. Try sitting closer to the steering wheel, or using a CG Lock.
Old 05-12-2014, 09:24 PM   #1147
CSG Mike
CSG Mike's Avatar
We have brakes that need a good home
Old 05-12-2014, 09:35 PM   #1148
gramicci101
Off Topic
Is there any kind of adoption fee involved?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
