Old 01-24-2014, 01:33 PM   #29
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Originally Posted by Noz View Post
The front line ruptured where it connects to the suspension.
It is possible that whoever installed them did not adjust them properly before mounting the wheel and calling it a day. Did they do a full lock - to -full lock test? My Goodridge lines are sized correctly for the application.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 05-12-2014, 11:51 AM   #30
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
Do NOT buy the Goodridge lines. Buy the Stoptechs.
I ran the Goodridge lines for about 9 months with only 1 track day and 1 autocross day and they failed on me a couple weeks ago. I was driving normally on the street and pressed on the brakes going down hill. The pedal went all the way down like how it feels when you're bleeding the brakes. Not a fun feeling. The front line ruptured where it connects to the suspension. It looked like it was caused by a design flaw. The lines were too short causing too much of a crease at the connection points and ended up rupturing at a stress point. I swapped to the Stoptechs and they fit much better. They were a bit beefier, longer and had no stress points.
I Have the Goodridge SS brake lines also on my BRZ and am scared everytime I jack my car and take off the front wheels because the brake line is so tight and "holds" the suspension from going lower (I should have took a pic). I then rush to pry the disc/lower suspension tab up with a 2x4 to loosen and give room to the SS line. It seems like the line (in its mid section sleeve bracket) takes full "up side" motion when the suspension bottoms down but fails to give it back when you jack the car in the air (wheel goes down and suspension trying to reach full motion down). I definitly need to do someting about this before it ruptures or weakens on my car too...Was Goodridge acknowledging a defect or made their lines longer or more easy flowing in the sleeve/bracket mid section?
JSUB is offline   Reply With Quote
Old 10-02-2014, 09:30 AM   #31
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Any update on this? I just got the lines...this is giving me some hesitation to install.
1Cor10:23 is offline   Reply With Quote
Old 10-02-2014, 01:41 PM   #32
Trac Toy
Trac Toy's Avatar
been on my car for two years now, no issues... plenty of track time to boot.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
The Following User Says Thank You to Trac Toy For This Useful Post:
1Cor10:23 (10-02-2014)
Old 10-03-2014, 11:01 AM   #33
JSUB
JSUB's Avatar
Goodridge sent me a new set of lines (well appreciated!) via my Auto part retailer and the problem seems solved. My part guy sold plenty and never had a problem with them he says.
Don't know if there's two different sets out there for sale but my new ones are thicker (the stainless steel mesh is coated) so the lines don't move at the middle bracket level therefore don't shift lentght one side so adjustment stays the same so far. All good. Brake pedal feel is top notch with them.
The Following User Says Thank You to JSUB For This Useful Post:
1Cor10:23 (10-03-2014)
WTB: OEM stock Brake Lines 86_ZN6 Brakes, Suspension, Chassis 3 03-12-2013 01:55 AM
Hawk brake pads and Goodridge stainless lines... seven Brakes, Suspension, Chassis 3 03-05-2013 08:07 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Goodridge Stainless Steel Brake Lines LavosTRD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-29-2012 06:37 PM
