Old 05-12-2014, 12:30 AM   #169
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
You mean the v2 kit? Why? They've fixed the issues with the kit & the V3 is more than adequate for my future power goals.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-12-2014, 05:16 AM   #170
Sterz
Great White
Drives: 2013 Whiteout FRS
All right guys, Yesterday I attended FT86 Cup at Streets of Willow CCW. I had never seen heat issues...before that day. As soon as I did my first two sessions I started seeing the coolant temperatures start to reach 210F. When I did my third session I saw it peak to almost 230F on my hot laps. Luckily I did not suffer any damage to the fans, but I had a feeling if I ended up staying for the last session than it would have melted them. Oil and Intake temps were perfectly stable.
I am going to order a 20amp 12" fan for the left side of the radiator, to see if I can pull some more air into that thing. Other than that everything performed well and I had a blast. Had a pretty high MPH spin that was the most awesome/scariest thing ever, luckily nothing was damaged at all.
Definitely have to take care of this heat, or I might consider switching to supercharger.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 05-12-2014, 07:33 AM   #171
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
UNDER 230 isn't dangerous
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Sportsguy83 (05-12-2014)
Old 05-12-2014, 12:06 PM   #172
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is what I was thinking.
Old 05-12-2014, 12:17 PM   #173
OrbitalEllipses
Drives: Attitude
Car will blow up. Warning! Danger to manifold!
Old 05-12-2014, 12:40 PM   #174
retrosmiths
Drives: Scion FR-S Whiteout
I was there too
I got to 260F in Buttonwillow, not really bad for the engine according to most people, but it will lose power.
I installed an oil cooler and got to 228F max in SoW.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
The Following 2 Users Say Thank You to retrosmiths For This Useful Post:
rb6freak (05-12-2014), SirBrass (05-12-2014)
Old 05-12-2014, 01:15 PM   #175
Sterz
Great White
My point was that I was reaching 230F after 2 laps. If I had hot lapped for all 8 in the session I'm sure that I would be seeing temperatures that are starting to get pretty dangerous.
Old 05-12-2014, 01:48 PM   #176
CSG David
CSG David's Avatar
Originally Posted by retrosmiths View Post
I was there too
That is oil temperature. @Sterz is talking about coolant temperature.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
retrosmiths (05-12-2014), Sportsguy83 (05-12-2014)
Old 05-12-2014, 01:49 PM   #177
Sterz
Great White
Yeah, My oil temp didn't reach over 230F all day.
The Following User Says Thank You to Sterz For This Useful Post:
CSG David (05-12-2014)
Old 05-12-2014, 02:15 PM   #178
retrosmiths
Oh, my bad
2013 Scion FR-S
Old 05-12-2014, 02:20 PM   #179
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yeah, My oil temp didn't reach over 203F all day.
Your oil temp never reached 203F at the track? Or did you mean 230F?
HRTROB is offline   Reply With Quote
Old 05-12-2014, 02:23 PM   #180
CSG Mike
CSG Mike's Avatar
Adding a few bits of information for everyone who's not familiar with your car.
- @Sterz was running on wastegate pressure, which is his *lowest* output calibration.
- The car is running E85
- The car has a FB Radiator, SPAL fans, and a FB shroud
- Ambient temperature never went over 73F the whole day
TL;DR: The car is NOT trackable in current condition, even with E85 and cooling mods. Additional (minor) tweaks were recommended to get the coolant temps under control.
Old 05-12-2014, 02:31 PM   #181
mike the snake
One thing that no one has mentioned is if they have replaced any of the air dams that get removed when you install an aftermarket radiator.
The stock radiator has foam air dams that help duct air through the radiator, and all these go bye bye when installing aftermarket radiators, leaving a lot of area around and above the radiator that air can simply go around, instead of through the radiator.
Replacing/fabricating the air dams/ducting so the air is directed through the radiator I think is one of the last pieces of the puzzle.
The Spal fans and shroud make a big difference, but a LOT of air can go around and above the radiator without the air dams in place.
The Following 3 Users Say Thank You to mike the snake For This Useful Post:
CSG Mike (05-12-2014), OjiGeorge (05-13-2014), SirBrass (05-13-2014)
Old 05-12-2014, 02:34 PM   #182
mike the snake
Has anything been done regarding eliminating the engine bay hot air? Vented hood? Modded skidplate? Fender garnish vents?
Without Something to eliminate the hot engine bay air, I'd expect the same results.
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
