Old 05-11-2014, 06:12 PM   #1
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Unable to loosen crank pulley, even with 6 foot break bar!
I'm sure I'm exposing myself to some spirited banter but I'm at my wit's ends...
I want to replace the OEM crank pulley and have carefully studied the DIYs I found, overall it should be a very simple operation. But...
Car's in 6th gear, I have my 24" break bar and, since that wasn't enough, a 6" piece of heavy galvanized aluminum who probably weighs around 10-12 pounds. I have tried numerous times to give it a good tug like all DIYs say but it's not loosening up.
Instead the crank is slowly turning with my tugs. It is definitely resisting (as opposed to, say, having the car in neutral) but it feels like working against a very strong rubber band.
What am I missing?
PS: I'm a healthy 6"2, 185 pounder who should, theoretically, be able to do this.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 05-11-2014, 06:13 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
pull the E-brake harder. Your torque is going towards rocking the car back and forth. Completely limiting tire movement will break it. I had similar issues...
Old 05-11-2014, 06:15 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
use a much much shorter bar and smack it with a hammer. different type of force. Also make sure you're going the right way.
Old 05-11-2014, 06:16 PM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Put your weight into it!
N1rve
Old 05-11-2014, 06:21 PM   #5
pche
Guy on internet
Drives: Slowly
Lefty loosey
pche is offline   Reply With Quote
Old 05-11-2014, 06:27 PM   #6
tbertran
tbertran's Avatar
I'm doubting everything I'm doing right now but not the direction...
Been hammering at it like one of you suggested, either I'm a wuss or my hammer is too light (it's a rhetorical question, fellas...)
Gonna try and find something to block the wheels to limit movement.
Old 05-11-2014, 06:31 PM   #7
Reaper
Reaper's Avatar
Drives: violent
seriously, 18 inch breaker bar plus 22 pound sledge should do it. The drivetrain wont be able to respond fast enough to absorb the impact and it should break free.
Old 05-11-2014, 07:36 PM   #8
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by tbertran View Post
What am I missing?
The right tools!
I had this same issue and couldn't break it loose with the ebrake maxed out to the point where the boot separated from the trim. The clutch was continuing to slip with 6th gear fully engaged, no matter how blunt I was with my force on the breaker bar.
I gave up, drank a beer and ordered a Grimmspeed pulley tool and once it arrived I was able to easily break the crank bolt loose using two breaker bars and an extra pair of hands.
http://www.grimmspeed.com/crank-pull...l-tool-subaru/
Great tool, highly recommend it.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DAEMANO (05-13-2014), tbertran (05-11-2014)
Old 05-11-2014, 07:48 PM   #9
tbertran
tbertran's Avatar
Im on track with your plan... Name:  ImageUploadedByTapatalk1399848497.386596.jpg
Will look into the tool. Thanks.
The Following User Says Thank You to tbertran For This Useful Post:
ATL BRZ (05-11-2014)
Old 05-11-2014, 09:44 PM   #10
stevesnj
stevesnj's Avatar
Get a 3/4 inch breaker bar and rest it against somewhere where it won't move and give the starter a quick turn. Should come loose easily.
Old 05-11-2014, 09:46 PM   #11
connorlug
Drives: #1553 10 Series FRS
yup lay the breaker bar against the pavement where it wont smack into anything else and blip the starter. problem solved
connorlug is offline   Reply With Quote
Old 05-11-2014, 09:59 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
Don't do this.
The Following 2 Users Say Thank You to Calum For This Useful Post:
was385 (05-12-2014), YouLikeFresca (05-12-2014)
Old 05-11-2014, 09:59 PM   #13
briantran123
Drives: fire storm frs 6mt
i used a small breaker bar and slapped a lacrosse stick on it. its a bitch, had to give it a few tries. itll pop eventually, i was doubtful too. im 5'5 and 140lbs, it should come off haha
i stood on the left side (facing the car) and just pulled. if it didnt go the first time, id release it a little then just yank the fuck out of it. youll know when it pops.
when i did it, the crank was going with me too. i even moved the whole engine. youre doing it right from my view. its just being a bitch
briantran123 is offline   Reply With Quote
Old 05-11-2014, 10:02 PM   #14
Calum
That Guy
Are you just turning the disk against the clutch springs? When I was putting mine on I had to pull against the springs until they binded and then I was able to break it loose.
crank pulley, installation
What is best crank pulley? Mixlplix Engine, Exhaust, Transmission 49 10-28-2017 06:44 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 11:12 AM
Steering Loosen up after break-in? Accathla BRZ First-Gen (2012+) — General Topics 16 11-22-2012 12:45 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 08:45 PM
