Old 04-22-2014, 11:02 PM   #127
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by BRGT86 View Post
what?
Guys have gone to great lengths to delete the factory third brake light. There is room to snake a lead up there. Incorporate a third brake light into the base and clean up the roof and the rear deck at the same time.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
racecat (04-23-2014)
Old 04-23-2014, 04:23 PM   #128
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Originally Posted by drtepper View Post
Alright, so it doesn't seem like a g37 antenna will work. the housing is just way too small for all the junk in the brz base. Essentially the g37 antenna housing is only meant for sat radio/nav but the brz's housing is for both sat and fm radio so.. twice the stuffings. Here are the pics i got from my experiment today.
looks like we either need to find another car that uses a larger flat type antenna to mooch off of or fabricate our own non-shark-fin type shells to go over the stock housing. Any ideas?
This is a great follow up to my DIY post on #42. The multiple soldering points is useful if you're going to stack more functionality modules ie sms gps module to know where your car is.
Awesome write-up, thank you! Mods please make this available in the DIY section of the site...
Has this been done yet? I think its a definite alternative to the large sharkfins.
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 04-24-2014, 03:14 AM   #129
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
I really don't feel like going through this whole thread and finding the company name where can I get this I want to buy it now I've been waiting for something like this!!!!
sweetfrs is offline   Reply With Quote
Old 05-10-2014, 01:06 PM   #130
big3
Drives: Subaru BRZ Limited
Hey all,
I decided to finally pull the trigger and do this mod. I cannot stand the look of the stock antenna. I decided to go a different route than everyone- I decided not to unsolder/ resolder any of the connections. It took a bit of patience but I was able to disconnect the 3 terminal from the plug.
Since I have a BRZ, I opted to stay with the antenna internals I had (minus sat radio- don't care about it). With some small modifications, everything went great. Sorry for the links for photo's for some reason, it wouldn't post them.
To remove the terminals from the plug, you really just need patience. It took about 35 minutes from start to finish. The '3rd' plug (tiny one between the two antenna plugs) was the hardest. If you look very carefully at the front you can see exactly where you can stick a needle (yes I used a sewing needle) and lift. The releases the plug for you to pull out.
First modification I made was to the board. I cut two of the bolt holes to allow it to fit into the cover. The board would be plenty snug and would not need to be screwed down.
https://www.dropbox.com/s/p65wnqo29f...510_123158.jpg
I pushed it into the top case and noticed it would sit perfectly so I cut (dremel) out the 4 posts that held in the original sat. antenna.
https://www.dropbox.com/s/p0n4vh97xk...510_123120.jpg
All installed and back together!
Here are some pictures!
https://www.dropbox.com/s/3dx7lj9ge2...510_132449.jpg
https://www.dropbox.com/s/zvtx7mjgv3...510_132456.jpg
https://www.dropbox.com/s/c46g1kaul6...510_132504.jpg
big3 is offline   Reply With Quote
The Following 4 Users Say Thank You to big3 For This Useful Post:
Assunta (05-11-2014), FearBoy (06-27-2014), Lonewolf (05-10-2014), OICU812 (05-11-2014)
Old 05-10-2014, 05:53 PM   #131
Lonewolf
Lonewolf's Avatar
Drives: Moped
@big3
How is your reception now?
Old 05-11-2014, 08:45 PM   #132
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
No one makes em for this car yet. It's using other cars antennas and DIY gig at moment.
Old 05-12-2014, 06:51 PM   #133
big3
@big3
Its alright. Almost every start up (but not all which is interesting on its own) it says 'antenna error', or p'lease check antenna' (cannot remember which). This is most likely because I left the Sat radio antenna unplugged and out of the car. I may see if I can get rid of the message or plug it back - if I can secure it from rattling around in the headliner.
There is one station that used to always come in HD but now doesn't (it is far away and comes in like crap now). I honestly don't know if it is because I have it plugged in to the wrong side, or if it really needs the 4 inch antenna. I did not mark the terminals when I removed them from the plug.....would need someone with a BRS to tell me where they go. I also try and avoid using the radio because I hate listening to the same crap over and over. I did this mostly for cosmetic reasons.
The Following User Says Thank You to big3 For This Useful Post:
Lonewolf (05-22-2014)
Old 05-16-2014, 05:10 PM   #134
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
Subscribed to this thread so I can jump in on the first order. Like others, the Beatsonic solution is way to big and doesn't suit the car (personal preference).
Vis101 is offline   Reply With Quote
Old 05-16-2014, 05:36 PM   #135
stevesnj
stevesnj's Avatar
Im just deleting the whole antenna. i don't like the look of it at all be it shark, pole, low profile. Now just have to figure how to do it. :P
The Following User Says Thank You to stevesnj For This Useful Post:
Chad86 (06-18-2014)
Old 05-22-2014, 06:24 PM   #136
big3
Can someone with a BRZ tell me which antenna (Sat. vs am/fm)terminal goes into which side of the plug? My reception has been really spotty- and I think I have it connected incorrectly.
Old 05-22-2014, 06:31 PM   #137
ftc~brz
Done
Drives: WRB BRZ
Originally Posted by kappaknight View Post
+1 on this. Saw it on the Porsche Panamera and it looked good!
best looking thing about that travesty
+1 for interest on this
ftc~brz is offline   Reply With Quote
Old 06-18-2014, 12:35 AM   #138
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
I'm in the same boat as you. I am having my car wrapped in XPEL on Friday. I want to find some sort of plug in white to match the car and stop water and rust...
Any ideas? Someone needs to come up with this. The roof will look so much cleaner. We shouldn't be listening to the radio with this car anyways!
Looks like I am getting closer to a solution. I will have to visit the local hardware store and check out the plumbing and screw section.
Flush, threaded hole plug and a sealant washer. Will have to get a Whiteout plug.
Link to the source of someone's wiper plug solution: http://www.motoringalliance.com/foru...-delete-2.html
Chad86 is offline   Reply With Quote
Old 06-18-2014, 07:07 AM   #139
Cridland
Cridland's Avatar
Drives: 2013 Whiteout FRS
I just vinyled my roof and didn't reinstall an antenna
Sent from my SGH-I337M using Tapatalk
Cridland is offline   Reply With Quote
The Following User Says Thank You to Cridland For This Useful Post:
Chad86 (06-19-2014)
Old 06-18-2014, 07:56 AM   #140
stevesnj
stevesnj's Avatar
That looks good, but sealed up with windshield adheasive should keep it watertight for good.
ftc~brz (08-23-2014)
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 12:44 PM
Flat black BRZ BRZranger Cosmetic Modification (Interior/Exterior/Lighting) 6 06-27-2012 03:23 PM
Flat Black BRZ Toods BRZ First-Gen (2012+) — General Topics 4 06-20-2012 12:25 AM
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! xcelir8brz Electronics | Audio | NAV | Infotainment 2 06-04-2012 11:44 PM
I'm going to try my hand on a flat 4 4agze Other Vehicles & General Automotive Discussions 2 04-08-2011 07:46 PM
