Old 05-07-2014, 09:31 PM   #29
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Need to see it on a FRS too!
Everyone knows those are the only ones you see on the track ripping it anyways...
dem00n is offline
Old 05-08-2014, 11:12 AM   #30
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Originally Posted by JohnJuan View Post
If I were to buy one, would there be a way for me to contribute real-world data for the downforce measurements on the splitter? I like your analysis, but I think it would be cooler to get data that takes all of the car's shapes into account.
The time and money in order to do this would not make it possible for most. You would either need access to a wind tunnel, or very sensitive load sensors with a data logging system.
eric6 is offline
The Following User Says Thank You to eric6 For This Useful Post:
JohnJuan (05-08-2014)
Old 05-09-2014, 08:33 AM   #31
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by JDKane527 View Post
Looks sweet! On the website, it is named the "Street Performance". Will there be a race version?
I saw this and forgot to comment. If there is a race version, the street version will be able to be converted to race version. So there won't be a worry of buying the street version and regretting waiting for the race version.
plucas is offline
The Following 2 Users Say Thank You to plucas For This Useful Post:
JDKane527 (05-09-2014), Wonderbar (05-09-2014)
Old 05-09-2014, 10:35 PM   #32
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i definitely appreciate the data. i was kinda hoping it would be around $170~ being plastic. heavy ass plastic lol
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline
Old 05-10-2014, 03:50 PM   #33
eric6
eric6's Avatar
The material isn't plastic though. Plastic would deform significantly at 40 lbs of down force. We looked into various materials and this was the only cost effective material that we thought most customers would be willing to buy. $170 wouldn't even cover the cost for a single splitter. We keep all materials and manufacturing in the United States. This makes it harder to compete with manufacturers that farm it out to other countries.
This material is strong enough to hold up 150 pounds or more, and in fact I stood on the front of my car to prove it. The issue is it attaches to the bumper, which is plastic and bows down. We will remedy this issue with the race version using additional reinforcement that attaches to a more rigid part of the car structure. This reinforcement will then carry the bulk of the load generated by the down force. The street splitter is perfect for auto crosses and people who want an aesthetic upgrade that actually works.
I realize this is not the most appealing splitter on the market but I can assure you that no other splitter produces down force similar to this one. If you look at the designs out there and understand the fundamentals behind a splitter, it is fairly easy to tell that most of the other splitters on the market are either purely cosmetic, or mostly cosmetic with a splash of performance.
eric6 is offline
Old 05-10-2014, 03:53 PM   #34
gramicci101
Off Topic
You could keep the same mounting point, just put a brace on the inside of the bumper that would tie in to something sturdy. Then bolt straight through the splitter, bumper, and brace. It would be helpful if the brace had a captive nut on it.
gramicci101 is offline
Old 05-10-2014, 04:06 PM   #35
8686
8686's Avatar
Drives: 86
I am now more interested in the race version
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline
The Following User Says Thank You to 8686 For This Useful Post:
TouchMyHonda (06-11-2014)
Old 05-10-2014, 04:46 PM   #36
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Does it have the extra bumper mounts like the APR one? I can never remember what they're called. The little piston looking things.
Nevermore is offline
Old 05-10-2014, 04:53 PM   #37
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Has this been tested at speed? I've already ordered it but I'm questioning if I should bother installing it before next track day or if it will just end up ripping off
JDKane527 is offline
Old 05-10-2014, 06:07 PM   #38
eric6
eric6's Avatar
I have had it into the triple digits multiple times, the splitter is held in very firmly. If it's coming off, your bumper is coming off. It has been curbed, bumped, stood on, and driven at high rates of speed. Here is a video of the splitter in action at 100 MPH.
[ame="https://www.youtube.com/watch?v=kLwSrouI71U&list=UUpVmSjcwyzze1YGEsCuVfXA"]Splitter R&D - YouTube[/ame]
We are working on a cost effective solution for the race version to ensure that the splitter remains parallel with the ground at high rates of speed associated with racing.
The race version will be an add on to the street splitter. It is currently in the works.
eric6 is offline
The Following 2 Users Say Thank You to eric6 For This Useful Post:
JDKane527 (05-11-2014), JohnJuan (05-16-2014)
Old 05-16-2014, 02:24 AM   #39
JDKane527
JDKane527's Avatar
Received the splitter yesterday, and got around to installing it today. Install is pretty straight forward, the only difficulty I found was getting the 25mm bolts with spacers to thread, a longer bolt would make this easier.
This generates downforce. I removed the foam behind the front bumper some time ago. Took the car out for a drive, got up to 90mph, didn't hit triple digits though, and the top clips on the passenger side next to the headlight started popping out. I'll have to try installing the foam this weekend and see if that helps support the bumper. Tie rods or some other support to the chassis would help.
Update: I believe that last time I installed the bumper, I didn't bank the bumper towards the car when tightening the top mounting bolts. I loosened those bolts slightly and lightly pushed the bumper in and retightened. End result is success, hit triple digits and securely mounted.
FT86SF Splitter by jdkane527, on Flickr
The Following 7 Users Say Thank You to JDKane527 For This Useful Post:
eric6 (05-16-2014), Fly Guy (05-17-2014), FT-86 SpeedFactory (05-16-2014), jack43 (05-16-2014), plucas (05-18-2014), Pseud0logik (05-16-2014), Teseo (11-09-2014)
Old 05-16-2014, 11:12 AM   #40
calibrz
Turbo 86
Drives: GT86
the lip looks so BIG
10 - 1 = 0
real math
calibrz is offline
The Following 3 Users Say Thank You to calibrz For This Useful Post:
JohnJuan (05-16-2014), Teseo (11-09-2014), TylerLinders48 (05-18-2014)
Old 05-16-2014, 11:39 AM   #41
8686
8686's Avatar
Drives: 86
It is a positive for me
8686 is offline
Teseo (11-09-2014)
Old 05-16-2014, 01:27 PM   #42
gramicci101
Off Topic
It looks to be about an inch thick? Is that right?
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
What front splitter? Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-30-2014 06:20 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 09:03 AM
BRZ Front Splitter Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 43 01-26-2014 03:29 PM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 05:41 PM
