Old 05-10-2014, 12:26 PM   #323
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by SmsAlSuwaidi View Post
Popped @delicoustunings 400whp cherry
I'll have a write up about how we did it, how bill is the man, and how great @MAPerformance is.
Don't forget this would not be possible without the Mustang heart breaker dyno at @Infamous Performance facility. Big thanks to Mike at Infamous for staying late last night to finish both vehicles.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
whataboutbob (05-14-2014)
Old 05-10-2014, 01:13 PM   #324
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
What's your opinion of an aftermarket OP with the NA Stage2 tune? (or actually, your opinion on the OP in general).
Would it help anything significant? How much more whp do you think you can gain with the addition of an aftermarket Op on Stage2?
It looks like the Op doesn't really restrict anything compared to an aftermarket one - especially since the stock one doesn't have anything like a stock low-flow cat nor resonator or anything and isn't really that small in diameter, nor is it really that crooked nor sharp bent (oem one looks like it has pretty smooth/decent bends after you see pics of it with its' heat shields off).
fooddude is offline   Reply With Quote
Old 05-10-2014, 02:22 PM   #325
DeliciousTuning
On a boosted setup you may see some improvement, but the only piece that will really net you some worthwhile power on NA as far as exhaust is the manifold itself. The OP simply isn't worth the cost.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
fooddude (05-10-2014)
Old 05-10-2014, 04:19 PM   #326
fooddude
Thanks for answering all my Qs
The Following User Says Thank You to fooddude For This Useful Post:
Old 05-12-2014, 11:36 PM   #327
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
For those of you installing the delicious ECBS, here's where the lines are run:
(the ports are numbered on the boost controller)
1-wastegate actuator (the gold bulb looking thing)
2-nipple on the side of the turbo outlet housing
3- vent to atmosphere or back to the airbox side of the turbo
If for some reason yours isn't numbered, 1 is the port by itself, 2 is on the other side at the
bottom, 3 is above 2.
I used a rivnut to add a threaded spot to bolt it to the bracket from the Grimmspeed pulley cover. You cant see it at all when it's back together. The zipties will be replaced by fuel injector clamps when they arrive
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
DeliciousTuning (05-13-2014)
Old 05-13-2014, 10:27 AM   #328
protpibe
protpibe's Avatar
The reason I posted that is because, like a lot of people, I just googled how to install a random 3port Boost Solenoid.
I came across this:
I figured "Score!" and rushed outside to install it. After easing into the throttle in 3rd gear to ensure it was connected properly, my boost gauge shot up to about 15psi before I let off.
Obviously there was an issue with the install. So I went back to google and clicked on "view page" for that diagram and saw this just below it:
That could of been embarrassing. For reference, Image #2 is the correct configuration
onzippy (05-13-2014)
Old 05-13-2014, 03:08 PM   #329
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
im getting awesome gas mileage on my tune!
600 - 650 kms (375-400 miles) to a tank, cruising at 110km/h (67~mph) with the car LOADED. I mean, like 500lbs or more of extra weight.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 05-13-2014, 07:52 PM   #330
Victor Draken
Drives: Toyota Gt86
LOL??
I cant do more then 425km
When I'm lucky... With a full tank.
Victor Draken is offline   Reply With Quote
Old 05-13-2014, 07:53 PM   #331
protpibe
protpibe's Avatar
My mileage is crap because I can't stop myself from flooring it
The Following 4 Users Say Thank You to protpibe For This Useful Post:
CSG Mike (05-15-2014), OjiGeorge (05-23-2014), whataboutbob (05-14-2014)
Old 05-13-2014, 09:19 PM   #332
Deadspool
Much title. Wow.
Deadspool's Avatar
Originally Posted by Victor Draken View Post
LOL??
shitty pic, but 503.5km, barely a needle below quarter.
Old 05-13-2014, 09:28 PM   #333
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Lol I barely get 200 miles per tank with the innovate supercharger. Most of my driving is in town though.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-13-2014, 09:29 PM   #334
Deadspool
Much title. Wow.
Deadspool's Avatar
im fullblown, 10psi, 50 trim.
Old 05-14-2014, 04:25 AM   #335
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Im running the FBM kit w a GTX2867. Car is running Canada 94 octane. Have the FBM rad, and going to be installing an oil cooler in short order. Can you PM me with what I'd be looking at for a proper dyno tune? Really would like to run RR7, as I have my AEM Uego WB conncted to the sendary O2 wire running to the ECU for logginf in ECU Tek. When I''m on the trottle my AFR drops to 9.. which just feels too low for me.. especially on 8lbs.
On the plus side, all my white paint on the back side of my car is upgraded to make my car two-tone.
PM me for options and opinions.. much thanks!
OjiGeorge is offline   Reply With Quote
Old 05-14-2014, 09:11 PM   #336
DeliciousTuning
Just an update to you guys we may be a little late in responding the next few days depending on how events play out. We've had several wildfires break out in San Diego County today and Bill is currently evacuating his family out of their home. Hopefully I don't have to go anywhere, but for you all this may mean that any updates or answers to your questions could potentially be delayed. We do apologize and hope you all understand. We will be back up to full operation as soon as these fires are out and we both have homes to go back to
Sincerely,
The Following 8 Users Say Thank You to DeliciousTuning For This Useful Post:
8686 (05-15-2014), Calum (05-15-2014), Circuit Motorsports (05-15-2014), CSG Mike (05-14-2014), Ethan (05-15-2014), Sportsguy83 (05-15-2014), whataboutbob (05-18-2014), xjohnx (05-15-2014)
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
