Old 05-09-2014, 11:28 PM   #15
beagoodruslan
beagoodruslan's Avatar
Drives: Suburu BR-Z - Silver
Anybody know if these will work the same as @DeOppressorLiber 's? Or are they different? http://www.ebay.com/itm/LSJ-8-Pin-Th...b4ee50&vxp=mtr
beagoodruslan is offline   Reply With Quote
Old 05-10-2014, 01:13 AM   #16
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
No idea what the pin-outs for these look like. The description states that they are for a chevy colbalt, so I don't think they will work at all. You may risk burning out your $1300 headlamps hooking these up..
Tuan is offline   Reply With Quote
Old 05-29-2014, 08:57 AM   #17
jadewbj
jadewbj's Avatar
Does anyone know if @DeOppressorLiber is still making them?
jadewbj is offline   Reply With Quote
Old 05-29-2014, 09:53 AM   #18
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
He is in the military and might not be in position to responds as quickly as before. Great guy and great product though.
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
Calavera is offline   Reply With Quote
Old 06-11-2014, 04:19 AM   #19
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Awesome stuff!
I have a EUDM GT86 with 8-pin headlights and ordered a Spec-D headlights for FR-S which will come with 6-pin sockets. Dear @DeOppressorLiber if you or anyone else can produce a harness to plug-in these headlights without rewiring everything - I'm happy to pay a good price!
Efferalgan is offline   Reply With Quote
Old 12-30-2014, 02:02 AM   #20
VakaGT
VakaGT's Avatar
Drives: None
bump still available?
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 12-30-2014, 05:00 AM   #21
hahaman86
Drives: 2013 Scion FR-S 10 Series #2013
I'm no wiring guru by any means but in the diy it says something about mounting a resistor after repinning the harness. Does this wire require a resistor to work or is it straight plug and play? Sorry if it's a dumb question I've been looking to do this mod on my 10 series for some time now thank
hahaman86 is offline   Reply With Quote
Old 02-14-2015, 09:58 PM   #22
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
I believe you may misread. You have to remove the DRL resistor that's already on the car before hooking everything up.
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
MemphisR (03-19-2015)
Old 02-14-2015, 10:20 PM   #23
AVodka14
AVodka14's Avatar
I see what you are asking. They are talking about adding a resistor to the high LED to reduce it's power output.
Old 03-28-2015, 07:48 PM   #24
f-tech
f-tech's Avatar
Drives: stock
where can I buy this plugs
f-tech is offline   Reply With Quote
Old 04-12-2015, 05:46 PM   #25
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Does he make a 6pin-6pin? for the 10 series/monogram lights?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 04-13-2015, 09:24 PM   #26
MemphisR
Memphis
MemphisR's Avatar
@indesign
Did you have to tap into the DRL module wires?
Old 04-13-2015, 11:14 PM   #27
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Originally Posted by MemphisR View Post
@indesign
According to the guy who made the harness, you're not supposed to run it with the DRL module, so I took the DRL module out. I think the harness makes the LED strip run off the parking lights instead.
I am not sure if he makes a 6-pin to 6-pin harness.
Old 04-14-2015, 10:16 AM   #28
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Are they still being produced? I am trying to put BRZ headlights on my FRS.
drew_kar is offline   Reply With Quote
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 01:15 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 03:19 AM
WTB: Subaru BRZ Headlight Harness Parts enderr Exterior Parts (Aero, Lighting, Etc.) 3 08-28-2013 05:39 PM
Lighting Harness wawro569 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-09-2012 11:28 AM
