Old 05-06-2014, 12:58 AM   #1765
steve99
Drives: FT86
Originally Posted by mightyt73 View Post
I use 93 from Exxon. Maybe I will try a different station. I'm guessing as long as it doesn't happen a lot I will be fine?
personally I don't like to see iam drop on good 93+ fuel, but stock tune will do it occasionally and some aftermarket tunes as well.
I doubt it will do damage, but I have fixed it in my car by pulling a small amount of ignition timing.
Old 05-08-2014, 01:14 PM   #1766
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
so ive rescaled this maf so that its dam near the command af the whole power band but soon as ltfr gets going it pulls -2 in injection mode 2 and in direct only it adds .78% ive limited learning to 2% both ways but its swinging my af to 13.4 way past the set number. im bout to jus disable all ltft learning .
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 05-08-2014, 01:22 PM   #1767
steve99
Drives: FT86
Sounds like you got the CL scaling done ok but the OL scaling at the higher end of maf flow rates is out ??
did you use the vgi utility ?
Old 05-08-2014, 01:46 PM   #1768
Kodename47
Kodename47's Avatar
Drives: UK GT86
Any idea how close your PI/DI errors are?
Any idea how good the CL scaling is? Is it temperature related?
LTFT can't be generated when the car is in OL, only CL.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-08-2014, 02:20 PM   #1769
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i only adjusted higher rates. i dont know what vgi utility is but yikes wouldnt import my logs so i just free handed it till they were near commanded af with no trims
IG-Joey_Soul
Old 05-08-2014, 02:21 PM   #1770
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i dont know how to check injection errors. and its not temp related. ive only scaled open loop
IG-Joey_Soul
Old 05-08-2014, 02:31 PM   #1771
steve99
Drives: FT86
Might be worth have a look here
http://www.ft86club.com/forums/showthread.php?t=64790
Vgi's utility will directly import your logs from oft or tactrix and produce maf scaling saves heaps of time
Old 05-08-2014, 02:58 PM   #1772
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you've only done OL then that's likely why. It's the error in CL that's creating the LTFT.
How I do the PI/DI is to run 100% of either and then do logging as if I were doing CL and then plot both sets of errors on a graph. When I get a chance I'll link on that thread to a spreadsheet to import and compare.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-08-2014, 03:37 PM   #1773
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ok cool . idk if changing the di pump had anythjng to do with it. i wasnt doin much logging before that
IG-Joey_Soul
Old 05-09-2014, 11:12 AM   #1774
germgerm
germgerm's Avatar
Drives: whiteout frs
http://datazap.me/u/germgerm/oft300?...ta=1-7-8-10-12
Here's my data log running oft300 would appreciate your guys input.
germgerm is offline   Reply With Quote
Old 05-09-2014, 03:43 PM   #1775
celica73
Installed my OFH last night, here's the first data log with about 35 miles on the current flash (OFT Stage 2 UEL, version 1.59)
http://datazap.me/u/celica73/oft-stg...log=0&data=1-9
It starts with 1-3 redline shifts each time. A little cruising then a 3rd gear pull to redline from about 2000 rpm.
Old 05-09-2014, 04:38 PM   #1776
steve99
Drives: FT86
Looks pretty good.
LTFT good
AFR bit rich (WOT) but that's pretty standard with OFT tune (on the safe side)
Bit of knock above 6400 rpm judging by sharp drop in kc learned values, if you log "Knock Correction" (FBCK) and FLCK (fine learning knock control) you will see it easier . Drop off the VVT intake and exhaust parameters.
Old 05-10-2014, 05:19 PM   #1777
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
here is my datalog
http://datazap.me/u/walla-walla/stag...log=0&data=1-9
Stage 2, with Crawford BPB, 91 octane, and mod on the tune for some Pops (see http://www.ft86club.com/forums/showthread.php?t=61069 )
so, how is it looking?
Walla Walla is offline   Reply With Quote
Old 05-12-2014, 10:12 AM   #1778
Sniper2606
Sniper2606's Avatar
I think its time for OFT along with a nice turbo kit.
Ill even drive from OKC to CALI to lend you my turbo brz for testing
@ shiv@vishnu
Sniper2606 is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
