Old 05-08-2014, 07:45 PM   #463
DC2R
Drives: 2014 Scion FR-S
Originally Posted by xjohnx View Post
any of you guys have any luck getting DashCommand to work with this head unit yet? Under the DashCommand settings when i try to select the OBD2 adapter (that i have paired with the head unit already), it won't let me select it.
For those of you that are unfamiliar with DashCommand, It's similar to torque, but much easier on the eyes. You can watch the video below to see how the default interface and layout looks.
Did you side load dash? None of my favorite apps show up in play store. Also anyone have any luck running paid version of Swype?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-08-2014, 07:51 PM   #464
xjohnx
Grip>Slip
xjohnx's Avatar
Nope, straight from the play store.
Old 05-08-2014, 08:02 PM   #465
DC2R
Oh ok I thought you were referring to
https://play.google.com/store/apps/d...s.dash.android
Old 05-08-2014, 08:03 PM   #466
xjohnx
Grip>Slip
xjohnx's Avatar
Nope, this.
https://play.google.com/store/apps/d...ce.DashCommand
Old 05-08-2014, 11:06 PM   #467
DC2R
So I take it nobody has a working ODB2 dongle, huh?
Who's hooked up reverse cam? This one seems like a good value but does'nt seem to be a good fit for FR-S since you would need to route wire elwhere. Any suggestions. I don't feel like spending over $50 on a cam
[ame="http://www.amazon.com/dp/B00BUJ6MW0?t=slicinc-20&tag=slicinc-20&ascsubtag=69d574f7ae454079a91bd7a399686169"]Amazon.com: TaoTronics® TT-CC22 Bar Type Car License Plate Mount Rear View Backup Camera (Waterproof IP67 / Color CMOS / 170-Degree Viewing Angle / Distance Scale Lines / Zinc Metal / Black): Car Electronics[/ame]
$24 with coupon code
Old 05-09-2014, 07:48 AM   #468
xjohnx
Grip>Slip
xjohnx's Avatar
Plenty of working obd2 dongles. I have 3 different ones that all work with Torque. DashCommand can't recognize them though. I'm working with DashCommand's developers to see if they can fix it.
Old 05-09-2014, 08:28 AM   #469
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
[ame="http://www.amazon.com/gp/product/B008U1MOM8/ref=wms_ohs_product?ie=UTF8&psc=1"]This one[/ame] works fine (with Torque).
milhouse is offline   Reply With Quote
The Following User Says Thank You to milhouse For This Useful Post:
DC2R (05-09-2014)
Old 05-09-2014, 08:30 AM   #470
milhouse
Because Racecar
milhouse's Avatar
Does anyone know whether its possible to make PowerAmp the default audio player? I sideloaded and its working fine, but the Unit starts playing from the USB drive using the built-in app whenever the car starts. The built in player actually isn't bad, but lacks the equalizer of PowerAmp, which makes a big difference.
Old 05-09-2014, 09:35 AM   #471
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by ir1064 View Post
still haven't hear anything from Ca-Fi yet, but i'll post here as soon as i get the update news.
does any one able to use DoubleTwist on their unit? all i want is a music player that can sync my iTunes playlist.
If you find something that does this, let us know. I used SyncTunesWireless to sync my iTunes playlists to my Nexus, and then I copied the files exactly as they were from my Nexus to the SD card for my Ca-Fi. I don't know if SyncTunesWireless lets you choose where it syncs the music, but even if it does, it takes forever to run it (even if you're only adding a few songs). Definitely need something better. DoubleTwist looks interesting. What is wrong with it?
Prog is offline   Reply With Quote
Old 05-09-2014, 09:36 AM   #472
Prog
Prog's Avatar
I don't think it's possible without rooting the device. I hate the built-in apps. I stay in Podcast Addict and PowerAmp. Mine doesn't automatically play anything when I get in the car (but you could use Tasker to make it automatically play something in PowerAmp, which is probably the next best thing).
The Following User Says Thank You to Prog For This Useful Post:
enjoi23 (05-11-2014)
Old 05-09-2014, 09:47 AM   #473
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Thinking about getting this OBD2 adapter: [ame="http://www.amazon.com/Switch-ELM327-Bluetooth-Diagnostic-Scanner/dp/B00BL3KQZO/ref=pd_sbs_auto_8?ie=UTF8&refRID=0N2ASASXTW5891RYM ZGR"]Amazon.com: Switch ELM327 Bluetooth OBDII OBD2 Diagnostic Scanner CAN ELM 327 Scan Tool Check Engine Light Car Code Reader: Automotive[/ame]
Low profile and a bluetooth switch to turn off when not using it.
Deathalo is offline   Reply With Quote
Old 05-09-2014, 10:48 AM   #474
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Deathalo View Post
Thinking about getting this OBD2 adapter: Amazon.com: Switch ELM327 Bluetooth OBDII OBD2 Diagnostic Scanner CAN ELM 327 Scan Tool Check Engine Light Car Code Reader: Automotive
Note that from the reviews, the on/off switch only controls the bluetooth transmitter, not the entire unit.
Old 05-09-2014, 11:03 AM   #475
Deathalo
I saw that, but the same reviewer noted in his comments that it does appear to be off after turning it off. Either way, I only care about the bluetooth being shut off when I don't want it on, if only to keep some random people from connecting to it.
Old 05-09-2014, 05:48 PM   #476
DC2R
Thanks for link. I think I'll buy that adapter. Been having nothing but problems. Already had to factory reset once to fix stick volume control. Sucks with no root. Been spoiled by titanium backup.
About half the apps I load from play store or apk force close. Also wish we could kill the main screen that comes on when you hit home.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
