Old 05-08-2014, 09:42 PM   #827
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by Wepeel View Post
I've seen oil temps around 220-230 on a hot day during autocross, not a whole lot hotter than what you'd see on the highway, and nowhere near what you would see on a track (not sure if they pull timing either).
Have you had a chance to log the stock tune to see if it behaves the same way during an autocross run? I know in my STI the normal road log (pull from 2000 to redline) rarely showed any knock events but during my autocross runs I'd get -1.4 and -2.8's popping up, FBKC and FLKC, and really nasty stuff bouncing the limiter (up to 8 degrees of correction). Never saw IAM drop though.
I never got any AutoX datalogs while I was on the stock tune, so unfortunately, I don't have any comparisons. I may try flashing back to the stock tune next time we have an event with fun runs and see how that looks.
It makes me feel a little better that your STI saw some knock on course when road logs looked fine. I'm kind of hoping that the abruptness of AutoX just messes with the knock sensor and probably everyone has the same problem.
jprice130 is offline   Reply With Quote
Old 05-08-2014, 09:51 PM   #828
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
On days in the 70Fs, I've seen 220F+ at autocross. Highway temps are in the low 200Fs. I'm afraid to see what my track temps in Florida Summer are, haven't tracked in a while.
Does it really not pull timing for oil temp? Car just feels sluggish after hard runs on a hot day. Maybe it's mental.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-08-2014, 10:28 PM   #829
jprice130
AutoX Nut
In the current RomRaider defs, I have not seen any timing compensation for oil temps. The ECU could have a compensation for it but it's just not exposed in RomRaider (obviously still learning as I go here).
Even if there isn't automatic timing retardation for oil temps, high ambient temps and a hot engine will still contribute to high intake temps. Those high intake temps will pull timing, so it's highly possible you're noticing that and are not mental.
The Following User Says Thank You to jprice130 For This Useful Post:
Kido1986 (05-09-2014)
Old 05-12-2014, 11:50 PM   #830
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
To our fellow rules experts,
Now that the TRD steering wheel is available in the US via release series 1.0, can we swap it into our non release series FRS and remain STX legal?
RiskyTrousers is offline   Reply With Quote
Old 05-13-2014, 06:18 AM   #831
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
So, after installing the Bilstein B8 shocks with RCE Tarmac springs, I've decided that reinforcing the drivetrain is my next step. Other than Whiteline, are there any other STX legal bushings that I should look at? Also, any suggestions for motor and tranny mounts that follow the weight rules for mounts? So far from what I have seen A) Whiteline seems to be the only company I have seen that offers bushings without additional metal and B) I haven't seen any weights listed for engine and transmission mounts... and for that matter, I am not sure how much the oem mounts weigh either... Thanks in advance!
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-13-2014, 08:48 AM   #832
autoXracer
Drives: 2013 WRB BRZ
I would like to know this too.
Also is it important to add suspension bushings first before the motor/tranny bushings? If so which are most important (maybe subframe inserts first)?
autoXracer is offline   Reply With Quote
Old 05-13-2014, 08:59 AM   #833
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Perrin makes the only STX-legal motor mounts. The Whiteline trans bushing mount is your best bet. Also, look into Whiteline's steering rack, subframe, and diff bushings.
2003 Honda S2000, SCCA Club Racing T3
2013 Subaru BRZ Limited, SCCA Solo II STX
2008 Honda S2000 CR, SCCA Solo II STR
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
Turkish (05-13-2014)
Old 05-13-2014, 09:00 AM   #834
PoorMansRacing
Anorexic
Not necessarily. But if you upgrade your trans mount, I recommend upgrading your motor mounts at the same time to divert the vibrations to the frame (instead of the motor). Subframe and steering rack bushings are great!
The Following 2 Users Say Thank You to PoorMansRacing For This Useful Post:
autoXracer (05-13-2014), Turkish (05-13-2014)
Old 05-13-2014, 11:19 AM   #835
mrazny
Drives: BMW 135i, soon to BRZ
Has nothing to do with STX. There simply is no ST allowance for Airbag steering wheels. None.
What you may end up seeing is people doing package converts, but it's thorough as hell (and eligible for all classes). Also, series 1.0 didn't exist with a 2013 model, so no 2013's are eligible to package convert. IF the series 1.0 releases as a 2014 model, then 2014's can package convert. And then it's still scion only, no Subarus. If it's a 2015 release, and for some reason you'd buy a 2015 FR-S, but not the Series 1.0, but then want to full package convert? Sounds pretty masochistic.
Its a steering wheel though, there's not really anything wrong with the twins steering wheel. Try driving an 325 e36 before complaining about steering wheels
mrazny is offline   Reply With Quote
The Following 2 Users Say Thank You to mrazny For This Useful Post:
PoorMansRacing (05-13-2014), RiskyTrousers (05-15-2014)
Old 05-13-2014, 11:47 AM   #836
Kido1986
Dodging cones
Kido1986's Avatar
The twins have the nicest OEM wheel I've held. NO EFFING BUTTONS!
The new WRX wheel would be perfect with an option for no buttons
The Following User Says Thank You to Kido1986 For This Useful Post:
Old 05-13-2014, 11:50 AM   #837
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I personally like flat bottom steering wheels.
Old 05-15-2014, 12:46 AM   #838
Kostamojen
Are the Group-N mounts not legal? Im pretty sure they are.
Old 05-15-2014, 09:20 AM   #839
PoorMansRacing
Anorexic
I forgot about those. Yeah, I believe those are legal.
FYI - I know a lot of STX drivers rocking the Cusco solid mounts, but FT86SpeedFactory confirmed they have slightly more metal content than OEM.
Old 05-15-2014, 04:26 PM   #840
Turkish
Serial Cone Killer
Turkish's Avatar
I thought the allowance for motor mounts specifically said material doesn't matter, they just can't weight less than OEM?
... his name is...
C'THULHU
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
