Old 04-30-2014, 04:37 PM   #533
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Stance coils: 6k/7k
4 clicks from full stiff front. Full stiff rear.
I'm going to go to new Stance coils with swift springs in the future most likely. 8k/9k springs.
Old 04-30-2014, 05:05 PM   #534
TmP
TmP's Avatar
Drives: A bunch of 'em...
Anyone running Megans?
(Mentally prepares for shitstorm)
TmP is offline   Reply With Quote
Old 04-30-2014, 09:25 PM   #535
executivekoala
executivekoala's Avatar
Drives: fr-s
Originally Posted by TylerLieberman View Post
Stance coils: 6k/7k
Is your ride rough, My rear is 4 clicks from stiff and its FIRM
executivekoala is offline   Reply With Quote
Old 05-01-2014, 07:47 AM   #536
diss7
Drives: AE86, 2x GT86, TE27
My spring rates are 7 all around, but they're too soft IMO. I'd like to try 9 or 10
diss7 is offline   Reply With Quote
Old 05-05-2014, 04:18 PM   #537
executivekoala
Drives: fr-s
So I'm thinking of running 235/40 federals in the front and 205/45/17 federals in back. Any thoughts. Looking for more front grip and less rear
Old 05-08-2014, 01:40 AM   #538
Crazy Drew
Drives: Smells like tires when I drive
Not to thread jack but wanted to say what's up to everyone and thanks for all of the useful information in the thread. I was heavily involved as a "drift car" builder years ago but fell away from the scene. Now that I've got an FRS I'm getting back in to it. Coilovers are here, now it's just time to make up my mind on wheels and install diff risers and increase the steering angle.
How do y'all feel about an 8.5+22 for inner clearance? I'm thinking I'll have miles of room but haven't spent any real time under the car yet.
*edit* Also, is anyone running a hydro/dual rear caliper setup yet? I saw it mentioned in a couple posts from @THA STI GUY but never saw anything materialize. If not I can pull my car apart next weekend (garage still full/unpacking from recent move) and take some measurements. I'll post the CAD drawings on here and people can get them water/laser/cnc cut to their desire.
Crazy Drew is offline   Reply With Quote
Old 05-08-2014, 09:02 PM   #539
THA STI GUY
DRIFT BUILD
THA STI GUY's Avatar
Drives: 2013 FRS
Its funny you mention that i was just going to post about it in my other thread i ended up picking up a hydro ebrake handle and two wilwood calipers from a guy in denver off his drift car. I will be building some brackets to make these calipers work on my car only crappy thing is unless someone buys the same cailpers as me the design wont will work as well but at least you guys will have a rough draft after i get mine dont and see how i plan to do mine. may still be a couple weeks before i start on that project because i just picked up a full blown turbo kit and i in the middle of installing that and getting tuned in the next couple weeks before the season realy starts up here.
couple pics of the goods i picked up
2013 FRS Rocket bunny- PETE
THA STI GUY is offline   Reply With Quote
Old 05-08-2014, 09:24 PM   #540
Crazy Drew
Neat, I'm curious to see what you come up with. The brackets I'll post on here will be for OEM calipers as honestly they should have enough braking force, if not the bolt on brembos sure will. I'm supposed to go look at a brembo set pulled off a totaled 09' STI this weekend, if they aren't trashed I'll pick them up. I was just going to reuse my OEM rears for the hydro ebrake.
The ASD handles are nice. If you haven't used one before I'm sure you'll like it.
With my driver skill level right now I'm sure I won't be able to utilize the car to it's fullest extent, even right now. I'm just seriously opposed to drum ebrakes.
Old 05-09-2014, 10:04 AM   #541
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
The Drifting Thread
If a cad design came out using two oem calipers that would be phenomenal. You can pick oem ones up for cheap with people upgrading now
In ref to your question. I'm running a 8.25 +25 and haven't seen any issues
Ryaquinn is offline   Reply With Quote
Old 05-09-2014, 10:09 AM   #542
diss7
8.5 +22 is fine for inner clearance and will look nice.
Hydro handbrake isn't needed. Mine has yet to let me down and I've done 10 or more drift days. My ae86 has a dual caliper setup hydro handbrake, and I don't think the oem handbrake in the gt86 is much different.
Hydro handbrakes are for cars with piss weak oem handbrakes, ae86, schassis etc.
Old 05-09-2014, 10:16 AM   #543
diss7
There's actually a section at one of the variations my local track runs where I've just gone round a fast left hander at top of 3rd, and linking in to a tighter left hander. I use the handbrake to scrub off speed, and if I try to use 3rd again it bogs down no matter how much I kick it.
So what I do is when I've got the car scrubbing and in the line I need, I leave the oem handbrake locked up, quickly do my change into 2nd, so once I'm then done with scrubbing and back in gear, I'm in the gear I need to be.
Wouldn't be able to do that section without that wee trick.
Won't be so much of an issue with turbo, I'll just hold 3rd easy. But NA, you don't have too much of a window where 3rd can be used.
Old 05-10-2014, 02:27 AM   #544
Crazy Drew
Thanks for the advice. I'm almost 100% of my experience is S chassis with, like you said, piss poor oem handbrakes that are crazy expensive to replace shoes on. I'll probably still draw up the brackets but not make this a personal priority yet.
Thanks for the info. I'll post the cad drawings in a week or so once I get some garage space opened up from my recent move. I get bored at times and enjoy drafting/design.
Old 05-11-2014, 10:58 PM   #545
TmP
TmP's Avatar
Picked up the car, getting used to it.
Love the chassis, hate the engine.
Couple minor things like the accelerator pedal don't seem to fit the otherwise awesome cabin either. Not sure about you guys, but me no likey for heel-toe.
What else... Gas mileage is good, even going at 180+ kph for extended period of time still gets 22 mpg. Not sure what top speed is, but 200 k (120 mph) is a piece of cake and car doesn't feel like it's working hard.
Not sure why the cruise won't work over 90 mph... that's a PITA, but oh well.
First extremely basic mods on the car. Can't wait to find time to take it to the track and really get to know the car, but overall happy with the addition.
Going to make for a nice drift build, that's for sure!
Old 05-12-2014, 12:28 AM   #546
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Adjust brake pedal high for heel and toe. Take's 5 minutes.
Mars2 is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
