Old 04-07-2014, 06:31 PM   #211
johnnyfast11
Drives: none yet
nvm.
johnnyfast11 is offline   Reply With Quote
The Following User Says Thank You to johnnyfast11 For This Useful Post:
AdrianG (04-07-2014)
Old 05-08-2014, 05:20 PM   #212
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Dezoris View Post
Yes you can keep the 2nd can unhooked or leave it off the bracket all together. but if you wanted to hook it up the attached picture is the breather tube.
Sorry for the crap picture
I am about to install the second can since I recently finished installing my Kraftwerks kit so a quick question;
When adding the "breather side can" did you simply extend the hose that goes into the breather tube and put into the inlet of the can and add the hose from outlet side to the breather tube back?
Please correct me if I am wrong so is this the correct route?
Engine >can inlet>can outlet> breather tube (in my case cold air intake)
Thanks in advance
glamcem is offline   Reply With Quote
Old 05-08-2014, 08:21 PM   #213
Dezoris
Dezoris's Avatar
Thanks in advance
Engine tube (Port Behind AC Compressor) > Can Inlet > Can Outlet tube to Air intake.
I ran new hose from breather port to can then new line to intake airbox on vortech.
The Following User Says Thank You to Dezoris For This Useful Post:
glamcem (05-09-2014)
Old 05-09-2014, 11:23 AM   #214
glamcem
glamcem's Avatar
It's really hard to access behind AC compressor at this moment since the SC, pulleys and bracket needs to come off but I think I can just use the hose that goes into the Air intake (which I already extended by using the 90 degree plastic barb with .5" extension hose) and another hose from the can to the intake as you mentioned.
Thanks again
The Following User Says Thank You to glamcem For This Useful Post:
Dezoris (05-09-2014)
Old 05-09-2014, 12:02 PM   #215
Dezoris
Dezoris's Avatar
Thanks again
Yeah that's fine as long as the hose does not have an obstruction you are good, that line is not under vacuum like the PCV line so its no issue.
I really like how clean that install is.
Old 05-09-2014, 12:19 PM   #216
glamcem
glamcem's Avatar
Thanks, I really took my time and read everything carefully, my tuner (moto-mike) sent me the revised tune so I am planning the flash the ECU again today.. so hopefully I can take my car for a dyno session within the next couple of weeks and of course some track events planned ahead so it should be a good track season this year.
Old 06-07-2014, 02:34 PM   #217
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Has anyone had an issue with the side barb fitting getting in the way of the dipstick on the inside? I just got my kit 2 weeks ago and am installing it today, and there isn't enough clearance on the INSIDE of the can for the dipstick to go in straight. If you have the dipstick in first, and then screw in the barb fitting on the side, you wont be able to get the dipstick out at ALL. ANYONE else seen this? Driving me crazy, because it's pretty much an install stopper...
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 06-08-2014, 12:18 AM   #218
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Post pics, installed mine in 15 min no problems. Sounds like you just have to adjust the hose fitting?
FRSfan111 is offline   Reply With Quote
Old 06-08-2014, 03:30 AM   #219
Gopherboy6956
Figured it out. Radium sent me the incorrect fittings. They are sending me new ones asap. I ended up filing down the current ones for the time being. I'll post pics tomorrow.
Mark - When you installed you Vortech, did you use the pcv check valve that comes with the kit? Or did you just leave the hoses as is for the catch can setup? The Vortech Instructions want me to place it between the top of the engine (passenger side) and the engine, which the catch cans now get between.
Thanks!
Old 06-08-2014, 05:11 AM   #220
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Thanks!
I have a Vortech SC and Radium catch can. I installed the check valve as per Vortech's instructions. You will have to get a pair of 1/2" to 3/8" hose reducer in order to hook up the lines to the catch can with the check valve in place.
It would then go like this:
PCV valve --> 3/8" hose --> hose reducer --> 1/2" hose --> Radium catch can top inlet
Radium catch can side outlet --> 1/2" hose --> hose reducer --> 3/8" hose --> check valve --> stock PCV hose --> intake manifold
Be sure to use clamps on everything, especially the one going to the PCV valve
HRTROB is offline   Reply With Quote
Old 06-09-2014, 10:06 AM   #221
Gopherboy6956
So where the heck did you find hose reducers then? Don't want to order online and wait - but can't figure out where to start looking in town...
Old 06-09-2014, 10:16 AM   #222
Gopherboy6956
Also - in this photo - the check valve goes in the line i've marked with an X correct? And it would be oriented like this Catch Can ------> Car Right?
Thanks!
Old 06-09-2014, 03:37 PM   #223
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I had to get them from ebay. I couldn't find any at the local hardware store. Just search ebay for "3/8 1/2 hose reducer"
Old 06-09-2014, 04:28 PM   #224
Gopherboy6956
Well I actually lucked out today. Walked in to Menards (where i always shop anyways) and low and behold - BAM
http://www.menards.com/main/plumbing...648-c-8553.htm
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
