Old 05-08-2014, 03:59 AM   #309
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
What kind of oil temperatures have you been seeing on your cars?
mnsayer is offline   Reply With Quote
Old 05-08-2014, 10:59 AM   #310
mkivsoopra
On a warm day, I've seen 250F just from driving spiritedly on the street.
mkivsoopra is offline   Reply With Quote
Old 05-08-2014, 11:07 AM   #311
sw20kosh
Drives: 2013 Black FR-S
195-205 on the street. It likes to stay in equillibrium with coolant temps which are 195 ish.
With ambient temps of 60F: 215F after doing 20 or so 3rd gear WOT pulls to collect logs (with maybe 1 min cool down time in between each).
Robispec cooling system.
The Following User Says Thank You to sw20kosh For This Useful Post:
Sportsguy83 (05-08-2014)
Old 05-08-2014, 11:12 AM   #312
kanundrum
Drives: 2013 Whiteout FR-S
I have data logged 129c which eqals 264F
Old 05-08-2014, 11:41 AM   #313
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It's absolutely incredible how this radiator/oil cooler combo works. I've pushed my car REALLY hard and see similar results.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
sw20kosh (05-08-2014)
Old 05-08-2014, 12:33 PM   #314
sw20kosh
I assume a lot of you guys went with the Exedy Stg 1 clutch/lightweight flywheel that ptuning recommends...
Did you notice significant increase in NVH (noise vibration and harshness) transferred to the cabin? It is very very prominent upon deceleration with the transmission engaged. Seems to be worse right around 3k.
I am thinking about uninstalling my whiteline diff bushing inserts to cut down on this NVH.
Old 05-08-2014, 12:34 PM   #315
jamesm
any lightweight flywheel is going to rattle like hell, particularly in the situation you describe and even worse at idle with the a/c on. i've yet to see one that didnt.
Old 05-08-2014, 12:47 PM   #316
mnsayer
mnsayer's Avatar
The ambient temps here is around the 113F now and im seeing oil temps of 275F. Its only going to get hotter here will reach 125F probably next month
The oil Im using is Castrol EDGE 5W-40
The Following User Says Thank You to mnsayer For This Useful Post:
kanundrum (05-08-2014)
Old 05-08-2014, 01:02 PM   #317
Sportsguy83
Drives: Limited BRZ
You need to get an oil cooler soon.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
kanundrum (05-08-2014), mnsayer (05-08-2014)
Old 05-08-2014, 01:05 PM   #318
mnsayer
mnsayer's Avatar
Waiting on the Ptuning oil cooler
The Following 5 Users Say Thank You to mnsayer For This Useful Post:
bjun (05-08-2014), buddy32 (05-08-2014), kanundrum (05-08-2014), ptuning (05-08-2014), Sportsguy83 (05-08-2014)
Old 05-08-2014, 01:31 PM   #319
ptuning
ptuning's Avatar
Drives: White FR-S
I know Pat asked me to chime in on further details of our oil cooler system. I have some time to do that today. Just give me about 30 minutes or so, since I'll need to write it up first LOL.
- Toan
ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to ptuning For This Useful Post:
mnsayer (05-09-2014), Sportsguy83 (05-08-2014)
Old 05-08-2014, 01:33 PM   #320
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
- Toan
My only question is if it will have provisioning for an oil temperature/pressure sensor for a gauge. Thanks!
rb6freak is offline   Reply With Quote
Old 05-08-2014, 02:20 PM   #321
ptuning
ptuning's Avatar
Drives: White FR-S
I'll see if I can ask MrC to develop an optional oil temp sensor adapter.
- Toan
The Following User Says Thank You to ptuning For This Useful Post:
rb6freak (05-08-2014)
Old 05-08-2014, 02:24 PM   #322
ptuning
ptuning's Avatar
Drives: White FR-S
As you all know our PTUNING Oil Cooler System features an oil/water Laminova core. There is nothing unusual about our turbo set-up that would have prevented us from developing a simple air/oil cooler system like others have done. In fact, we use conventional air/oil coolers on our other turbo setups (S2000, tC). The only reason we opted not to go this route on the FT86 is because of the engine/bodylayout. This car has a very small frontal opening in addition to a short front bumper overhang.
A regular air/oil cooler system either needs to block the intercooler or go between the intercooler and condensor. Either way it ultimately ends up blocking the radiator, which is a big deal on this car, since the frontal opening on the bumper cover is rather small to being with.
The other option would be to place an air/oil cooler in the fenderwell in front of either wheel. The problem we saw with this was, due to the short bumper overhang, fitment was very tight and it is difficult to direct much air from the frontal opening off to the side and into the cooler. Furthermore, it requires swiss cheesing your fender liner in order to obtain proper air flow through the cooler. Sure, it's possible to cut a giant opening in the fog light opening to direct air to the cooler, but not everyone will be okay with modding their front bumper cover like this. Also, we wanted to keep both sides of the bumperwell area open for future development of a brake duct system for customers looking to seriously track their cars. It's also why we tucked our WMI pump and washer reservoir into the cubby hole under the factory bumper beam supports.
Now, on to our oil/water cooler system. We developed a custom bracket system to allow our Laminova cooler to bolt to exising holes in the chassis so that no drilling is required (easier said than done LOL). We also positioned it in a way to allow us to run the shortest possible oil cooler lines from the engine to the oil cooler as well. Between the very short oil lines and the inherent free flowing laminar fin design within the Laminova core, overworking the oil pump and/or oil pressure drop will not be a concern.
Unlike some other implementations of the Laminova core, we do not depend on fittings welded to either side of the radiator end tanks to provide water cooling to the core. This method is definitely not very efficient since the amount of coolant flowing through the core will be minimal. In addition, the hot coolant that has not had a chance to pass through the radiator is being used to cool the oil.
Our design uses the full flow of coolant exiting the lower radiator hose AFTER it has been cooled down by the radiator. Doing this requires us to mold custom silicon hoses though. Our unique hose routing ensures that the engine is allowed plenty of freedom of movement without putting any strain on the lower radiator hose.
Lastly, the design of the Laminova core allows for full, unimpeded flow of coolant through its core. You will not be putting any additional strain on the factory water pump by running the engine coolant in line with the Laminova core.
Hope this explanation helps.
- Toan
The Following 9 Users Say Thank You to ptuning For This Useful Post:
AllDayJonRay (05-08-2014), CxG (08-03-2015), Darryljr11 (05-08-2014), Deadpool_25 (04-26-2015), kanundrum (05-08-2014), mkivsoopra (05-10-2014), mnsayer (05-09-2014), rb6freak (05-08-2014), sw20kosh (05-08-2014)
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
