#239 |
Drives: SWP BRZ LTD
I think it is safe to assume the steering wont have miata feel to it, but wont be bad.
#240 |
Señor Member
Drives: white BRZ 6MT
I wonder if the steering in the Type V had a better feel than the standard one everyone else got.
#241 |
Drives: '23 BRZ
Lack of steering feel in the S2k is often overstated, IMO. Not as much feel as a manual-rack 240Z, that's for sure! And obviously not as good as a manual-rack Elise. But as good as or better than most FR cars out there (MR/RR cars have the advantage of less weight on the front wheels => less assist required). I'll be happy if the FR-S/BRZ steering is as good.
#242 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I think in my drive of the S2K the steering wasn't bad at all but I never drove a Lotus for comparison. I guess I am not that finicky unless steering feel is too light.
#243 |
Drives: '06 AM V8V Coupe
One of the cool things about electric assist, power steering can be turned off with a switch, no need for steering pump pulley modification
#244 |
Drives: auto
More evidence this car has exactly what the S2000 lacked:
From http://www.insideline.com/subaru/brz...nd-video.html: "Steering, which is electrically assisted in a rapid 13.1:1 ratio, is immensely feelsome and exact, imparting the front tires' grip status precisely to its driver's brain stem. It is perhaps the best electric steering in any car" |
#245 | |
My VTEC fluid is full
Drives: EFF JAY
#246 |
Drives: auto
Can't wait to test drive one. For now, I read
#247 | |
Drives: 01' S2000; 05' WRX
What people don't understand about electric steering is that one of the reasons that it is there...is that it does nothing. The motor is completely deactivated once you hit a certain speed. The feel you get going around corners is influenced by the castor and rim size on the vehicle. I have all sizes of tires, both hydraulic and electric power steering. Take this as truth from me: steering feel is subjective and can be changed by changing the sidewalls of your tires. Journalists typically mistake the yaw characteristics for steering properties. How a car rotates is not related to its steering system. This whole subject is both simpler and more complex than what you have been hearing from journalists for years. The truth and my prediction: the S2000 steering is the most accurate while also having bushings that allow some of the vibrations to be absorbed for highway driving, compared to most other system on the market. (Lotus uses harder bushings that have to be replaced regularly, by design) I think the FT-86 will be almost exactly the same as the S2K, with its similar EPS, what I assume its castor settings are, and what its tire sizes will be. (Continuing my prediction) The yaw characteristics of the FT-86 variants will be different than the S2K, with its Impreza based suspension, and will be much more forgiving on drivers who are new to RWD.
#248 |
Mr. Sarcasm
Found this little gem - http://www.autotrader.com/fyc/vdp.js...standard=false
#249 | |
The BRZ is in town, here are my posts about it.
The Subaru factory rep was taking pictures of my STI seats in my S, and was surprised at how much of a difference it made. Most of the Subaru guys around here are not to excited about this car. I should get to drive it in a couple weeks. Hopefully the factory rep can make it out on drives in this area.
![]() Last edited by AaronCompNetSys; 04-02-2012 at 10:16 AM. |
#250 |
Drives: EFF JAY
I thought it would be smaller than the S.
But more importantly, you have STi seats on your s2k? Are they the JDM recaro STi seats? The USDM STi seats (both GD & GR) are one of the worst - non supportive seats to come in a "performance" vehicle. |
#251 |
I still really have to go out and drive an S2000 (maybe try AP1 and AP2 just to be safe), but I think I'll be much happier with the BRZ. Convertibles just ain't my thing, and I know I can't afford to shell out for the ultra-sexy Spoon hardtop.
I've never been big into Hondas, either. From my perspective, every time I needed a winter beater, I figured I could spend a couple thousand bucks on a FWD Civic, or a Toyota MR2 which was mid-engine, RWD, weighed about the same, and got similar fuel economy. Maybe not as fast and not nearly as much aftermarket support, but I could never get myself to go with a Honda. Maybe a drive in an S2000 will be the thing to change that!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#252 | |
http://www.s2ki.com/s2000/topic/8247...i-seat-in-s2k/ Nothing else is quite like the top down experience of an S2K on a perfect day. Try one with an experienced driver and be prepared to have your socks knocked off, its abilities are far beyond any normal car and most drivers. Every spring, its like magic to put the top down for the first time. Shortly after is followed by sideways in my case...
| Thinking of Buying either MR-2 Spyder or an AP1 S2000 | FT///R86 | Other Vehicles & General Automotive Discussions | 33 | 12-29-2011 12:53 AM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
| The Real S2000 Successor | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 10 | 02-12-2010 01:21 AM |
| Honda S2000 Mugen Hard Top Headliner | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 3 | 01-15-2010 01:43 PM |
