Old 05-07-2014, 12:26 PM   #673
FR-S Matt
Originally Posted by BatStig View Post
I was rocking the OFT for a few weeks before the EcuTek. Car runs soooo much better with a custom tune. Can feel it up top, down low, everywhere. Butt dynos don't lie.
Not every car is the same. That's my beef with the OFT. Is it terrible? Not at all, they're decent off the shelf tunes. Ecutek lets you customize based on YOUR bolt-ons and how your car runs which is why in my opinion, it makes it worth it over the OFT.
Old 05-07-2014, 12:31 PM   #674
Shit Luck
Drives: red frs
you can have an OFT tuned on a dyno also, you just need a tuner that will work with it. Most tuners only use ECUTek because its more profitable for them.
Shit Luck is offline   Reply With Quote
Old 05-07-2014, 12:32 PM   #675
FR-S Matt
Very true.
Old 05-07-2014, 12:38 PM   #676
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Exactly. When I got my JDL EL, it definitely felt better with the OFT but they don't have a tune for a long tube catted EL header. Stage 2 is apparently too aggressive for a header with cats. There was a lot left on the table. If I had the time/patience/energy to learn to tune I would have done it myself. Since I don't have any of those things I let @OPSash do his magic and now my tune is optimized for my JDL EL catted headers. Car runs like a champ!
BatStig is offline   Reply With Quote
Old 05-07-2014, 01:05 PM   #677
FR-S Matt
Yeah, I had @nelsmar clean up Toni's BS tune I wasted $300 on. He didn't change too much timing on it and raised the rev limiter to 8000 rpm. Car feels so much better and we're on revision #17 now I think? Just a few more logs till its complete before it will take 100-200 logs just to squeeze out maybe 1-2 more HP.
Old 05-07-2014, 08:40 PM   #678
Turdinator
Señor Member
Turdinator's Avatar
You can custom tune with OFT... The OTS tunes Shiv provides are really just base maps, albeit good ones.
1974 TA22 Celica
2013 86 GT
Old 05-07-2014, 08:43 PM   #679
FR-S Matt
So can you take an OFT to lets say an Ecutek tuner and they tune with them in the same manner or are the platforms for tuning completely different? Granted they probably won't do it since they're in the business for money, but still. I suppose that really encourages people to learn themselves too which brings Ecutek's price down as well.
Old 05-07-2014, 09:08 PM   #680
Turdinator
Señor Member
Turdinator's Avatar
OFT uses romraider to alter the maps. They may be labelled slightly differently and there won't be the Race Rom stuff that Ecutek does but it is otherwise the same. Whether you can convince your tuner to use it is the only issue.
1974 TA22 Celica
2013 86 GT
Old 05-07-2014, 09:33 PM   #681
Shit Luck
Drives: red frs
You can do almost everything ECUtek can do. Romraider isn't the only option for editing maps, I had tunerpro or something like that to edit mine. Any tuner should be able to tune with it, however will they is a different story.
The Following User Says Thank You to Shit Luck For This Useful Post:
Turdinator (05-07-2014)
Old 05-08-2014, 11:58 AM   #682
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Quote for JDL UEL headers please.. 20901 @Jesse@JDLAutodesign
Marcoscrdo is offline   Reply With Quote
Old 05-08-2014, 12:06 PM   #683
jamesm
While everyone is correct in saying that for an NA application (that being the key differentiator) OFT can do everything Ecutek can do, the idea that somehow ecutek is more profitable to tuners is off-base. Tuners charge labor, and that labor is the same regardless of what the user prefers to tune with. I tune both Ecutek and OFT, and there is no financial advantage to me for either platform. The margin on selling licenses is basically nothing, and most users nowadays already have them anyway.
I do, however charge more for OFT tunes just because the software is much less refined and the process takes a lot longer. You can basically do 4 ecutek runs for every 1 OFT run (using map switching). The flash/file transfer eats up about 4x as much time, and you have to flash again between each run. On the dyno it's particularly painful, as they don't stop charging you while it's flashing (which is also true of ecutek, you just do it much less often and it's much faster).
So yeah there's no functional difference to an NA car (aside from RaceRom special features, which only matters to some people), but there's no financial benefit either way. People who refuse to tune it have other reasons, likely software/support concerns.
The Following 6 Users Say Thank You to jamesm For This Useful Post:
Captain Snooze (05-09-2014), DBW (05-27-2014), Fast_Freddy (05-21-2014), HatchetBurial (05-08-2014), SirBrass (05-09-2014), Turdinator (05-08-2014)
Old 05-08-2014, 09:10 PM   #684
speargunsandracecars
Drives: 2014 BRZ
Any sound clips of this exhaust yet?
speargunsandracecars is offline   Reply With Quote
The Following 2 Users Say Thank You to speargunsandracecars For This Useful Post:
HatchetBurial (05-10-2014), Lawnik (05-09-2014)
Old 05-09-2014, 12:56 AM   #685
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Gshoxx View Post
Got my jdl uel and op installed todAy .. Turn out raspy because of my custom magnaflow catback.. Any suugestion on how to take away the raspiness? All in all very satisfied with the flawless finish of the headers.. Thanks jdl
Hemholtz resonator in the front pipe.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 05-09-2014, 12:59 AM   #686
SirBrass
SirBrass's Avatar
He probably cleaned up your MAF scaling, cam phasing, and timing. MAF scaling being right is very influential on smoothness & "betterness".
The Following User Says Thank You to SirBrass For This Useful Post:
FR-S Matt (05-09-2014)
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
