Old 05-06-2014, 06:17 PM   #1
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Raceseng Shock Tops Questions - 1" or 2"
I've been noticing quite a bit of rear driver-side noise indicative of my RCE Tarmac II Clubsport coilovers hitting the bump stop. My car is lowered somewhat, but not terribly much. I'd say about an inch currently.
I'm interested in the Raceseng Shock Tops, but I'm curious as to how to decide on the proper size. The RCE Tarmac 2's are KW V3s with RCE 400 lb springs (7.1kg).
What is the maximum recommended travel for the KW V3's? Obviously ride height adjustment is crucial to knowing how much travel you have, but are there some visual cues or measurements I can take to help put with this decision?
I do track this car quite a bit in NASA, so I'm concerned about extending too far and ruining the coils prematurely, or upsetting the performance of the coil altogether.
Anyone have experience with these on the track or street?
http://www.raceseng.com/shock-top-2-...baru-brz-2013#
@Raceseng
@Racecomp Engineering
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 05-06-2014, 07:10 PM   #2
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
http://docs.kwsuspension.de/ea-KWGFwEA-h68658004.pdf
This is the V3 installation guide. This may or may not be of use to you.
eyedeez is offline   Reply With Quote
The Following User Says Thank You to eyedeez For This Useful Post:
TrogDor the Burninator (05-06-2014)
Old 05-06-2014, 09:28 PM   #3
wparsons
wparsons's Avatar
The bump stops should be quite silent when you hit them, and they're progressive rates so it shouldn't be a solid thump.
Further, if you're actually hitting the bump stop, those upper mounts won't help you at all with fixing this issue. You'll either need to raise it up or run higher rate springs. I suspect it might be something else that you're hearing though, possibly the end links hitting the LCA?
Now, if you were bottoming out the shock internally before hitting the external bump stop these would definitely help.
flickr
Old 05-06-2014, 10:36 PM   #4
Hmmmm ... now I'm wondering if my shock isn't extended high enough ... as in time of their installation. How far does the shock normally extend up past the rear shock tower?
I have some image searches to perform apparently. I'll post a pic of my current install height shortly.
Old 05-06-2014, 10:58 PM   #5
An inch drop isnt a problem. I would double check your install....top nuts may be loose?
Anyway, the 1 inch drop raceseng rear mounts would be my choice if your sticking with an approx 1 inch drop from stock.
- Andy
wparsons (05-07-2014)
Old 05-07-2014, 12:11 AM   #6
So I checked the left rear shock mount for any play / looseness ...
It wasn't loose. However when I tried to loosen the top nut (locking nut) it would not loosen, instead it just turned the entire shock piston.
Sooooo ... what does that mean exactly?
I made sure I wasn't just turning both nuts at the same time with my deep socket ...
Here is a pic of the shock mount from the trunk:
Old 05-07-2014, 07:50 AM   #7
wparsons
wparsons's Avatar
Did you do the initial install yourself, or have a shop do it?
You probably need a pass through socket on the nut, and then either an allen key or smaller socket (depending on the shock design, stock is an allen key) to keep the shaft from rotating.
flickr
Old 05-07-2014, 08:31 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i asked the following question in the "suspension model" thread but no one answered.
by raising the bumpstop engagement in such a way you're also raising how high the wheel can go in the wheel arch
which also affects how high the LCA/UCA has to move up, a theoretical inch or even two higher than it was inteded for.
also generally the bumpstop is an integral part of the system.. especially in a coilover. If you move it up an inch or two, that's an inch or two of coil bind.. can the coils themselves handle it or will they be compressed?
they probably did the math... but i'm not seeing these issues discussed... and i think it should... and that this would be highly application specific.
The Following User Says Thank You to 7thgear For This Useful Post:
Wepeel (05-07-2014)
Old 05-07-2014, 09:20 AM   #9
Wepeel
Drives: '13 BRZ Ltd
I know I brought this up before. Depending on the setup you could be putting yourself into a position of coil bind. Maybe not, but it's something I would definitely do the math on with perch height, spring travel, block length, damper stroke, etc etc etc.
Wepeel is offline   Reply With Quote
Old 05-07-2014, 10:12 AM   #10
That's normal....
Give us a call and Myles can probably help you troubleshoot the noise...they should be silent especially with stock tops.
- Andy
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions... NickFRS Forced Induction 40 05-10-2013 01:55 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions NickFRS Forced Induction 0 05-01-2013 07:22 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
