| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#7771 | |
Drives: 2013 BRZ Limited WRB
| The Following User Says Thank You to Simon99 For This Useful Post: | chanomatik (05-06-2014) |
#7772 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
What kind of bulb are you using? I've got a 194 5-Diode Led bulb in there and I find it isn't the brightest and I'd like something a bit brighter.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
#7773 |
Drives:
Finally finished my fiberglass box. Sounds better then any wood box I've owned.
Sent from my XT1080 using Tapatalk |
#7774 |
F Z1LLA
Drives: Lexus IS-F Series 2
They're all over ebay and BaysonR sells them on ebay also
2URGSE |
#7775 | |
Drives: '13 BRZ Ltd WRB
I need to get my butt in gear and attempt one of these. That big wooden box is always in the way.
#7776 |
Drives:
I used Velcro so then if I need to get to my spare then I can get to it. And FYI, from start to finish its gonna take you 2 whole days
| The Following User Says Thank You to Collin_812 For This Useful Post: | 2point0 (05-07-2014) |
#7777 |
Drives: Black BRZ
Installed the K&N drop in filter today. definitely notice an increase in throttle response. Hard to say whether or not it gave me a power boost though
#7778 |
Drives: 2014 Limited Subaru BRZ DGM
First Oil Change. Installed Fumoto 108 Valve from Quickvalve. Plus a K&N HP1004 filter. Had to jack my car up a mile to get my jack stands under it. Top mounted filter makes changes stupid easy.
#7779 | |
Are you 20/20?
Drives: Hopes and dreams
You have a quick review for me yet?
#7780 |
Off Topic
@GrimmSpeed hood thingies, courtesy of @FT-86 SpeedFactory. Pay no attention to the shitty cell phone pic quality.
| The Following User Says Thank You to gramicci101 For This Useful Post: | FT-86 SpeedFactory (05-07-2014) |
#7781 |
Drives: 2014 BRZ 6MT WR Blue Met
Hit 1111 on the odometer on sat night, was gonna put up a pic I snapped, apparently I must've forgotten how to do so because this insert url crap is kicking my ass.LOL
#7782 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
The bilsteins are nice and firm, they have a break in period so they should smooth out fairly soon. So far I have dropped 0.6" in the rear and 0.4" in the front. The car is more planted and seems to actually have significantly more grip with the stock rubber. As reference, on a 90 degree turn I would squeal the tires at 25+ mph, now they're squealing at around 35+ mph and I haven't had a slide yet (fastest 90 degree turn so far pre-alignment has been 40mph). I told myself no hard driving until the alignment, but that lasted about as long as the breath it took to say that to myself lasted. The springs are quite nice too. The balanced spring rates seems to have taken away a significant amount of oversteer but it is too early to tell if I now have understeer or what. A good autox session should illuminate that subject. If the car was purely DD, I would probably have stuck with the stock dampers and used less stiff lowering springs such as RCE yellows. For a sports car (vs sporty car) this is actually what I expected stock to feel like prior to test driving. More and more I am liking the stock rubber better than I originally did, this new suspension has firmly planted that feeling in me (pun intended).
That is my quick review. I will have a more thorough review once I have had an alignment to ensure toe is ok and I have annihilated enough cones to know what I should tinker with next.
#7783 |
Drives: '19 Crosstrek
I just have the standard halogen bulb and I find it bright enough for me. You could probably swap them out for 912 or 921 Led bulbs along with the proper socket.
| The Following User Says Thank You to chu.waht For This Useful Post: | Cjymiller (05-07-2014) |
#7784 | |
Seriously! I need to invest in (or make) some race ramps so I don't even have to bother with a jack for oil changes. But that valve is one of the best inventions ever. I will put one on every car I own.
| The Following User Says Thank You to 2point0 For This Useful Post: | Churnobyl (05-07-2014) |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 08:53 AM |
