#1093 | |
Drives: 2013 SWP BRZ
The Touge Factory brake cooling kit has been fantastic; I am running OEM rotors (or Centric blank OEM replacements). I'm running R-comps with RCE T2 coilovers at a heavy braking track (Sebring) and am not getting ANY fade at all with the brake cooling kit, and I am an advanced driver and I am really pushing the car hard. I got a bit of a spongy pedal on Day 2 this past weekend at Sebring due the brake fluid I was running, but I was trying Cobalt XR1 pads for the first time (most aggressive compound) as well as having a 200lb passenger the entire day. No more RBF600 for me; Torque RT700 or SRF from now on. The caliper piston dust boots look brand spanking new since I have been using the titanium shims at every event. I tried running without them one time and the boots cracked a bit, so I replaced them during a caliper rebuild and have run the ti-shims ever since. Track pads last me 3 to 4 track days, and 4 is cutting it close. Each day is 4 to 5 sessions that are 30 minutes each. The OEM or OEM style blanks are holding up great; after about 8 total track days I toss the fronts, as they have normal heat checking on them, but it's too cheap of a replacement part to risk running a long time on them. I've been stock piling OEM rotors, and just got a pair for $20 for the fronts with about 5k miles on them, since everyone is jumping to a BBK. I won't go BBK until/if I go FI. That's just me.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#1094 | |
Again, will you suffer a catastrophic failure? Probably not, but as your system ages, your risk will slowly increase. We suffered a catastrophic failure at Super Lap Battle last year in one of our S2000s. This car had brake ducting, but was readily boiling RBF600. We compensated by using a higher grade fluid. The S2000 was running 255/40/17 Hankook RS3, and at the time, made around 375whp. Total cost of the failure: - On pace to set class record (by a good margin); DNF because of the failure, and no official recorded result - A damaged custom made 17x10 +44 Volk CE28N - A destroyed AP Racing CP8350 Caliper - A destroyed Essex brake caliper bracket - A shattered AP Racing rotor
#1095 |
Drives: 2023 BRZ
David, thanks for sharing that. My sessions are no more than 20 minutes. I typically run four sessions per day. Based on the three days I have so far on the BRZ, I'm guessing my DTC-60s will last 7 or 8 days. The rotors show no significant wear.
#1096 | |
Strictly speaking, from a ROI perspective, a used AP kit still has equity, and can be readily sold. We upgraded from a Sprint to Endurance on our 2014 BRZ, and had no issue selling our used Sprint kit. Our sale price was $1850 with a fresh rebuild and a fresh pair of rotors, and it was gone in days of the posting. That being said, I still have a stock system on my S2000 (but I replace the lines every 15 track day or so). My excuse is that my wheels won't clear a BBK. |
#1097 |
Drives: FR-S Whiteout
You guys destroy brakes... Do you guys ramp up the brake pressure and trail off, or just stomp it then trail off entering turns?
I gradually increase and decrease brake pressure. Too little and too gradual, apparently. I've only managed to fade my stoptech pads once coming into the skidpad at SoW going CCW.... ONCE! |
#1098 | |
Please let me know if you do decide to test temps using temp paint and heat strips! |
#1099 | |
I used to buy Brembo blanks in bulk for ~55 each. |
#1100 |
Drives: 2023 BRZ
Right now Conti DWS. I know...I know....but they were free.
I've used RA-1s in the past. I have experience. I'm just too cheap to buy the right tires when I can use the wrong ones for free. I figure I'll burn through them this summer and get some NT-01s or similar next spring. I plan on using temperature indicating paint at an event in July. |
#1101 | |
Drives: WRB Subaru BRZ Limited
#1102 | |
![]() I have experience with DWS... I feel like I'm gonna die cuz there's no grip when it's dry... but it's an amazing rain tire. I'm impressed. |
#1103 |
Drives: 86
Interesting. I recently rebuilt my front calipers and found out one dust boot had some cracks on it. On the other hand, if I add titanium shims, I assume the pads and rotors will run hotter..?
#1104 |
Drives: 2023 BRZ
#1105 |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
