Old 03-29-2012, 02:54 AM   #127
Racecomp Engineering
Hey guys this is Myles. I can tell you that this car is very awesome. The handling STOCK is amazing. I have listened to and watched threads and people talk about theory this and blah blah blah but I can tell you that VERY little is needed on this car to be an "off the charts" handler.
The difference that the springs made was subtle at first but when pushed its AMAZING. The car is much flatter but was super FLAT stock. I strongly feel that TIRE choice will be one the key factors in this cars handling.
For my car I have Whiteline ball joints planned and RCE plates with our lowering springs and our sway bars. Yes we have already started working on GTWORX/BILSTEINS for this car as we have already developed shocks for the WRX, STI and LEGACY co-branded with Bilstein.
One thing is for certain, those who lower it alot......will have an intimate relationship with the bump stops ! This car has LESS travel than an Impreza ! More than ever FUNCTION will be the focus as many will do mods to this car that HURT handling.
Stock shocks handle the new springs very well. I cant say more because of the dates involved and I am still under an embargo for dates.
I will post a review shortly. I posted a lot of pics on our facebook page already.
Myles Williams
Racecomp Engineering / GTWORX
Old 03-29-2012, 02:56 AM   #128
Oh and Whiteline camber bolts ( smaller ones) will allow for a good amount of front camber changes.
Bump travel sucks but droop is good. Responsive shocks will be the key here.
Mw
Old 03-29-2012, 03:10 AM   #129
OrbitalEllipses
Drives: Attitude
Does the embargo/NDA preclude you from saying anything about when it will be lifted?
Old 03-29-2012, 03:15 AM   #130
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 03-29-2012, 03:43 AM   #131
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
so with just Racecomp camber plates and springs the car should be fine for everday use? That's exactly what I have in mind.
poormans_LFA is offline   Reply With Quote
Old 03-29-2012, 09:09 AM   #132
RaceR
Drives: 2010 Cooper S, 74 Beetle
Hi Myles,
Thanks for your great review of the BRZ.
Suspension setup on the BRZ should in theory have more understeer compared to GT86. Seems several car reviews agree although differences are most likely to be subtle.
What are your toughs on the stock balance?
What are your toughts on your current setup with the lowering springs, balance wise?
Would you aim for the same balance, or remove some understeer and make it easier to get sideways with your lowering springs?
Due to the cars suspension geometry it seems like camber plates are a must if lowering it?? Will that be your main/your customers way to adjust balance if wanting to do so? Adding some extra camber on the front compared to what gets added to the rear if wanting less understeer?
Ofcouse we could take dampers, swaybars etc into the equation, but lets keep it as simple and as stock as possible.
Thanks
RaceR is offline   Reply With Quote
Old 03-29-2012, 10:26 AM   #133
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Damn, this sounds great! Can't wait to get some of these parts when I pick up my BRZ!
- The Ancient BRZ Sacrament
by Zaku
Old 03-29-2012, 01:12 PM   #134
skeeler
skeeler's Avatar
Drives: Miatas of Various Kinds
Originally Posted by Turbowned View Post
This is apparently without jack & tools, but usually manufacturer's listed weight is dry weight, so 2762 for a Premium and ~ 2780 for a Limited (before fluids?), and this is showing 2714 with full fluids and no jack/tools (13 gals of fuel weighs about 65lbs, for reference).
In the US, manufacturers---no apostrophe---quote curb weight, which includes fuel and all other fluids.
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
skeeler is offline   Reply With Quote
Old 03-29-2012, 01:15 PM   #135
skeeler
skeeler's Avatar
Are stock class SCCA autocross rules that you can now change the rear OR front swaybar? Bumping up to a stock STI bar may be a very cheap and effective upgrade for that crowd, as previously stated. Hm, I need to research autocross clubs around my area...
As of 2012, yes, you remove or replace the front OR rear ARB, but not both. The STI rear bar is quite a bit stiffer than the FR-S/BRZ bar is, so it may push the car too far into oversteer. (Of course, I'm running an RX-8 bar on my STR-prepped NC Miata, so I'm not saying the SRI rear ARB won't work out.)
Keep in mind that a lot of clubs use their own rules, rather than the SCCA's.
Old 03-29-2012, 01:34 PM   #136
S2kphile
Resident HoneyBadger
S2kphile's Avatar
Drives: Toyota Tacoma TRD Off-Road
Sweet I'm looking forward to see a shocks/springs combo that improves handling while lowering to flush status & having enough rebound travel with a passenger & couple of bags in back ie no rubbing or feeling harsh bumps.
S2kphile is offline   Reply With Quote
Old 03-29-2012, 01:58 PM   #137
skeeler
skeeler's Avatar
Originally Posted by Draco-REX View Post
Many people do quite well in MacPherson strut cars. Subaru likes to use long control arms, so camber loss is minimized. If you consider the range of motion you're likely to encounter, especially in modded form with higher corner rates, the loss of negative camber will not be that great.
Originally Posted by 7thgear View Post
the only thing MacPherson struts are going to do in place of a double wishbone is change the way you approach car setup.
Originally Posted by old greg View Post
With MacPherson Struts the roll center will always move more than the CG. A well designed multilink/SLA suspension can completely eliminate roll center migration, and anything halfway decent will at least be a lot better than struts in this regard. The concern that I would have is that any sort of drop will increase the front roll moment but not really affect the rear, which will lead to a change in lateral load transfer distribution. With a mild drop this should have about the same effect as installing a slightly wimpier front sway bar which may or may not be a good thing depending on how you feel about the stock setup. Either way, a slightly stiffer front sway bar would probably suffice and may be a better option than extended lower ball joints (which might cause a tendency to lift the inside rear tire mid-corner if used on a car with nearly stock ride height). You'd also probably want a bit more total roll stiffness and/or a bit more static negative camber up front, to counteract the slight compromise you'd be making to your front camber gradient.
Thanks for your feedback on the Mac struts. I must admit that I dont have any experience with setting up strut cars for competitive driving, and it sounds like setup is more complicated for strut cars.
Old 04-01-2012, 05:02 AM   #138
CSOCSO
Drives: Scion Tc
very safe drop. needs waaay more than that.
Originally Posted by Enzie View Post
CSOCSO for president of ft86club hater bashing committee!
CSOCSO is offline   Reply With Quote
Old 04-01-2012, 10:25 PM   #139
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Needs? for looks? Or for performance?
It doesn't need to be lower than that for performance IMO.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-02-2012, 11:20 PM   #140
Alfie
Alfie's Avatar
Drives: Sheeveek Si
40mill- 40mill- 40mill !!!
____"In essence they're identical, and identically excellent." Ollie Marriage TOP GEAR____
Alfie is offline   Reply With Quote
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 04:35 AM
Any thoughts on my "mini" engineering and business plan.? KidWonder Off-Topic Lounge [WARNING: NO POLITICS] 24 12-29-2011 02:16 PM
BRZ engineering video shown at Tokyo Motor Show. Japanese translation needed please. tranzformer BRZ First-Gen (2012+) — General Topics 16 12-16-2011 06:50 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 01:52 PM
$95 Track Day@Willow Springs March 11 Louie Southern California 0 01-23-2011 02:38 AM
